AMD wins!
    • 31200
    AMD wins!
    Intel has fucked everybody again!!
    are you ready for a 50% performance drop? - your gonna get it once Hyper-threading is removed.
    https://www.theregister.co.uk/2019/0...g_mitigations/
  • diif
    • Feb 2014
    • 6978
    • England
    Re: AMD wins!
    In the real world it's about 10% with a maximum of 30% if it's the ideal workload.
      • 31200
      Re: AMD wins!
      sure it is.
      even browsers are multi-threaded and exploit HT and multi-core cpu's now.
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16958
        Re: AMD wins!
        My CPU's are so old, I can care less.
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • BigTroll
          • Sep 2010
          • 1317
          • LAMBDA SOND
          Re: AMD wins!
          Yep I feel like a winner everytime I use my AMD RYZEN!!
          My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
          • diif
            • Feb 2014
            • 6978
            • England
            Re: AMD wins!
            Originally posted by stj
            sure it is.
            Not disagreeing things use HT but suggesting half will be lost is way off.
            It's going to be more noticeable in data centres though that's more where the ideal workloads are seen.
            • RJARRRPCGP
              • Jul 2004
              • 6304
              Re: AMD wins!
              Reminds me of the "Bush Jr." era, where some people had HT-phobia. IIRC, back in the Pentium 4 era, (they were AKA "Pee 4") some people were telling other people to disable hyper-threading, accusing hyper-threading of causing malfunctions, LOL
              ASRock B550 PG Velocita
              Ryzen 9 "Vermeer" 5900X
              Arc A770 16 GB
              eVGA Supernova G3 750W
              Alienware AW3423DWF OLED
              • BigTroll
                • Sep 2010
                • 1317
                • LAMBDA SOND
                Re: AMD wins!
                Interesting, I know a few years back I was running a optiplex 280 with a geforce 100 OEM card and I had put in a 3.2ghz CedarMill pentium 4. Playing youtube and watching taskmanager it was hitting 100% cpu and causing the video to drop frames where it was running great a few days ago. Noticed that the CMOS battery went dead and hyperthreading got disabled, turned it back on and with hyperthreading enabled cpu usage went down to 80-85% on youtube and the video playback was smooth! this was in 2014 or so when trying to use a P4 with the modern internet was on its way out.
                As a side note I usually always bought i5 cpus as I could never justify the price premium of the i7 just to get hyperthreading and a slightly higher clock. this thread makes me feel better about that decision.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  Re: AMD wins!
                  People are confusing threading (software concept) versus threading (hardware concept). Disabling hardware multithreading will not make software threading take twice as long to complete.
                  The speed penalty depends on the application and the OS scheduling. The 10-30% is about right from my experience though even this is optimistic. As regards to BT's experience, this is because of poorly written "multithreaded" OS/applications, usually because the scheduler improperly can't or won't relinquish control to other threads, and having hardware threading will see a huge apparent increase in throughput because now the crap OS/software is letting hardware run the other thread.
                  Of course having another core is much better than a SMT thread. But I have seen the actual throughput increase before and it is real and I use it when I can when throughput matters. The largest measurable increase I've seen was running one of those distributed clients from distributed.net which is completely CPU bound (no network or disk usage) and saw that 25%-odd throughput increase when using both threads on a P4. Of course each individual thread took significantly longer to complete, but there was a significant throughput increase.
                  Again on an ideal OS and properly written software, you will see very little speed loss with the disabling of hardware multithreading, especially when the software is waiting for user input most of the time. But bad software that's completely chomping the CPU will see a penalty.
                  • RJARRRPCGP
                    • Jul 2004
                    • 6304
                    Re: AMD wins!
                    Fun fact: Goldeneye chomped on the Nintendo 64 CPU! (And it probably does chomp on the CPU more than Perfect Dark!)
                    Arc A770 16 GB
                      • 31200
                      Re: AMD wins!
                      apple says 40%,
                      so probably similar for Linux.
                      although mine is on an AMD dual core.
                      • mariushm
                        • May 2011
                        • 3799
                        Re: AMD wins!
                        For people that are not up to date ... new exploit found for Intel computers ... again related to HT/SMT ... NOT present in AMD and ARM processors
                        They called it Zombieload
                        Wired: Meltdown Redux: Intel Flaw Lets Hackers Siphon Secrets from Millions of PCs - https://www.wired.com/story/intel-md...cution-buffer/
                        Bleeping Computer : New RIDL and Fallout Attacks Impact All Modern Intel CPUs - https://www.bleepingcomputer.com/new...rn-intel-cpus/
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          Re: AMD wins!
                          Maybe not? I wonder if Netburst's HT has the same flaw? What about Nehalem/Westmere EP (both of those have HT as well)? I know you have both still in service (as I do I). Westmere and Nehalem are not on the microcode fix list (on the "no changes" list), Which would imply the issue sandy bridge and later (which is on the fix list)... but as old as they are, it could be a case of "nobody uses those, aww f*ck it". Dunno.
                          Fix list referenced attached, which came from this advisory from Intel:
                          https://www.intel.com/content/www/us...-sa-00233.html
                          I only have 3 potentially effected systems in service: One netburst (irwindale), one Westmere EP, and one ivy bridge (main personal laptop, a tricked out Latitude E6430). I don't plan on disabling HT... unless I see concrete proof that said platform is indeed affected.
                          sigpic
                          (Insert witty quote here)
                          • Topcat
                            The Boss Stooge
                            • Oct 2003
                            • 16958
                            Re: AMD wins!
                            My Harpertowns don't support HT....hmmmm I still have a paxville system in operation and several westmere's though.... I never did bother with spectre patches though....all my westmere systems aren't accessible to or from the outside world.....
                            Team : 49813
                            Join in!!
                            Team Stats
                            • lti
                              • May 2011
                              • 2557
                              Re: AMD wins!
                              The list of affected CPUs includes CPUs without HT.
                              I have two affected CPUs. One is a Core i5 without HT, and the other was always unusually slow in every application except benchmarks.
                              Sometimes I wonder what would happen if I bought a Ryzen instead of the i5. Would I like it?
                              • Dan81
                                SNES-powered
                                • Oct 2013
                                • 1866
                                Re: AMD wins!
                                Meanwhile, I'm smiling with 2 i3 CPUs (i3 540 and i3 3220), both with HT
                                Main rig:
                                Gigabyte B75M-D3H
                                Core i5-3470 3.60GHz
                                16GB DDR3-1600
                                Samsung SH-224AB DVD-RW
                                Delux MG760 case
                                • RJARRRPCGP
                                  • Jul 2004
                                  • 6304
                                  Re: AMD wins!
                                  Uh, reminds me of the earlier Pentium I stuff, even when it apparently carried on until at least 1995 or real close to 1995. (the floating point bug)
                                  But I don't think it's quite as bad as that. But still bull! The floating point bug, would definitely make people required to throw their processors away! IIRC, Intel said that the 133s and higher, don't have the hardware bug.
                                  Arc A770 16 GB
                                    • 31200
                                    Re: AMD wins!
                                    that FP bug thing was the thing that set me against Intel,
                                    i always used cyrix or amd when i could after that.
                                    it wasnt the FP bug, it was the "go fuck yourself" type response from intel that was the decider.
                                    i obviously wasnt wrong - they still have the same response to users!
                                    • Topcat
                                      The Boss Stooge
                                      • Oct 2003
                                      • 16958
                                      Re: AMD wins!
                                      Cyrix.....ohh the memories....memories of horrible performance, instability, and simply not working....I think I'd take the FPU bug. AMD wasn't much better back in those days. Today OTOH, if I had to build a new system for myself, AMD would certainly be on the table of consideration (whereas in the past it wouldn't be).
                                      Team : 49813
                                      Join in!!
                                      Team Stats
                                        • 31200
                                        Re: AMD wins!
                                        my cyrix systems were fine,
                                        there was an old rule - not cpu specific.
                                        the rule was: avoid pc-chips and other "cheap" chipsets like the plague!!
                                        i remember they had lots of issues if you tried to use the then-new pci slots for example.
                                        and amd k6-2 chips were great.
                                        • sigmeyer
                                          Toshiba 50UL4B63DG faulty screen?
                                          by sigmeyer
                                          I got this 50 inch tv the screen starts off with almost nothing visible but the top part of it , and it would slowly kick in and the picture would be visible , but then over time it would go greyish with the top of it mostly intact. I did have instance where the screen would be fucked like that and i would touch the cpu and memory to see if it would react and a couple times it would screech on the speakers and restart. After that it would show a better picture somewhat but afterwards i touch the cpu and not much is achieved. Im wondering is this a screen fault or should i pursue this with a donor...
                                          08-30-2025, 08:13 AM
                                        • Behemot
                                          Need Catalyst 15.6 for Win 7 x86-64
                                          by Behemot
                                          Anybody has? I don't even have the strength to whine about how EVERYBODY on the whole fucking planet is so dumb to only REPEAT link to frelling AMD site WHICH CEASES TO EXIST after few months instead of HAVING the stinking file to download FROM THEIR OWN SERVER, for fucks sake. Would laugh if it did not make me cry So after quite intensive search, this thing seems to be impossible to find. For the record - 15.7.1 is totaly fucked up for DXVA, 15.6 is latest reported working one.
                                          This is actually quite interesting that AMD always FUCKS UP some driver line, usually...
                                          02-10-2019, 06:56 AM
                                        • surfer349
                                          LG Gram 13 Battery not charging, USB-C nor DC plug
                                          by surfer349
                                          Looking for advice.
                                          https://www.amazon.com/gp/product/B078WRN1S8/
                                          I have this LG Gram 13, from 2020. Recently, it seems that the battery simply won't charge. It's drained down to 0%, and will now only turn on when plugged in, either through USB-C or the DC charger plug.
                                          I've opened the back to look for anything obvious but it all looks fine. I tested the voltage on the DC charger and its all fine.
                                          What next? Is it possible the battery is fucked? I've read there are control circuits on the battery itself that regulates charging. Can that...
                                          10-03-2023, 09:42 AM
                                        • CapLeaker
                                          Astron RS-7A/10A not regulating output voltage low
                                          by CapLeaker
                                          Either I am getting old or dumb, probably both.
                                          This “simple” linear power supply is driving me insane. Should be easy, right?
                                          Here is the story. Got that Astron RS-7A or 10A as stone dead. I mean turned on and got 0.00V not even an mV on the output. Why dat? Darn electrolytic output capacitor shorted at the binding posts. No, problem… new one in stock and mounted.
                                          Turned the PSU on again and now I got 0.1V on the binding posts. Everything clear like sunny day and replaced the LM723 regulator IC in the socket. Had it made, I thought....
                                          09-17-2023, 08:33 PM
                                        • jesi
                                          need help with hp laptop 16867-1
                                          by jesi
                                          hi there
                                          no sound on this crap laptop giving me headaches
                                          mb 16867-1 nba_rockets_mb 448.0by04.0011
                                          need schematic and alc1305h ic i think
                                          many thanks
                                          03-25-2019, 07:17 AM
