LG Gram 13 Battery not charging, USB-C nor DC plug
  • surfer349
    • Oct 2023
    Looking for advice.
    https://www.amazon.com/gp/product/B078WRN1S8/
    I have this LG Gram 13, from 2020. Recently, it seems that the battery simply won't charge. It's drained down to 0%, and will now only turn on when plugged in, either through USB-C or the DC charger plug.
    I've opened the back to look for anything obvious but it all looks fine. I tested the voltage on the DC charger and its all fine.
    What next? Is it possible the battery is fucked? I've read there are control circuits on the battery itself that regulates charging. Can that be replaced or does the whole battery need to be replaced? Is there maybe a software thing that needs to be audited?
  • mon2
    • 14632
    Re: LG Gram 13 Battery not charging, USB-C nor DC plug
    Most laptops will offer a diagnostic tool to allow you to gauge the health of the battery and should display the # of charge cycles. Just installed 'vantage' on my Lenovo yesterday that performs the above tasks.
    LG should have a similar tool for your laptop model on their website. Start with that tool to determine the present condition of the battery pack.
    If convenient and available, source a known good battery from Amazon (risk free) for testing. Keep it or return it at your discretion.
    If the next battery also fails to charge, then you will have to review the battery charger IC on this logic board. Once that component is identified, we should be able to perform some tests with a multimeter to better understand why the charging function is failing.
    Batteries, if left dormant will often fail to charge = deep discharge.
    Update this thread as you proceed to diagnose your unit.
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • Julian Bailey
      HP ProBook 445 G8 Battery not charging
      by Julian Bailey
      Hi all
      We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
      The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
      I have gone around the board with a MM and cant find anything
      Windows shows the battery fine,...
      10-11-2024, 10:34 AM
    • piernov
      Laptop battery charging circuit
      by piernov
      1. Some theory
      1.1. Introduction
      Almost every laptop has a charging circuit of some sort, that does a few things:
      • Manages switching between AC adapter and battery power
      • Manages battery charging and generates power rail to charge battery
      There are 2 different designs to handle switching between AC adapter and battery power and feeding the system:
      • Hybrid power boost (HPB) and traditional circuits without power boost (see Warning in HPB section)
      • Narrow VDC (NVDC)
      Texas instrument has a nice overview of these technologies with some more details at https:...
      11-15-2020, 01:31 PM
    • kodox
      ThinkBook 15 G3 ACL Not Charging Battery - LA-K602P Board
      by kodox
      since i couldn't find schematic or boardview for this model (LA-K062P), i use closest board model found here https://www.badcaps.net/forum/troubl...-and-boardview
      the schematic share same marking for each component, using same PD-Controller, same BQ25710, the only different is the battery cell used. LA-K061P uses 3S battery while LA-K062P use 4S battery per schematic.
      what i've done:
      - flashing...
      12-29-2024, 02:49 AM
    • Iherduleikgemz
      Asus FX505DY - Battery not charging - BQ24780S
      by Iherduleikgemz
      Hello everyone
      I have been working on this laptop mentioned in the title, it initially had a shorted capacitor. After I replaced it, the thing started working again, but there is still another problem. The laptop was running off a charger, the battery was reporting 96% charge... but when I unplugged the charger, the laptop died. I've measured the battery voltage - 0V. I think it is locked. (Screenshot from batterymon, below).
      I've ordered a new 3rd-party battery, but I think there's something wrong with it too - the laptop boots, but the battery isn't charging. Also,...
      01-13-2025, 03:54 PM
