Topcat's Other Misc Weird Build Thread
  • 370forlife
    Large Marge
    • Aug 2008
    • 3113
    Supermicro says Nocona or Irwindale only. These things are such a pain to install with the heatsink brackets I made anyway 😅.
    I did figure out the bios flashing. I found a utility from AMI to do it. It flashed successfully. The version number is still the same, but the build date is about 2 years newer. Anyway, it didn’t fix the issue with the sound card.
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16997
      • Badcaps.net Founder
      #182
      Originally posted by Topcat
      If anyone remembers the C7X99 from THIS POST, keep that in mind for the next few weeks.....a build is developing! 🙊
      Click image for larger version  Name:	C7X99_1495.jpg Views:	45 Size:	399.9 KB ID:	3447879
      Ok, I promised a build, and it's been a little slow this week in the shop, so I started it yesterday.
      The case for this is going to be that XPS 630i that was dropped off. As mentioned before, it didn't have the water cooling option like the last one I got had. The water coolers for these are simply non-existent, you'll never find one; atleast the OEM one.... Since this isn't going back together in its original state, I'm not too worried about originality in a any way!!
      ...so let's begin!!
      First up is to remove the HDD cages, they are being deleted. Came from a smoker's house. That dust is sticky, stinky, and corrosive!
      The old guts. Works, but not being reused.
      The corrosive nicotine sludged dust ate the paint off the front mesh....
      We'll get back to the paint later....but for now, lets shift gears to my cooling idea. The cooler I chose was an Asetek 650LX, for skt2011/2066. These were used for servers in datacenters. Thick core radiator.
      After trimming up the lower 120mm fan shroud, the radiator attached to it nicely
      Spacers to shim the radiator out to the outer lip of the shroud.
      ...and attached!!
      Very nice fit. Like it was born there....but now you know why the HDD cages were deleted.
      Fan installed.
      Now disassembly for cleaning.
      Now for cleaning.... The best way to remove a COA....soaked in warm water for a good hour, it just falls off....otherwise you're poking & scraping....and frucking up the plastic..... This way, it just falls off....and a clean microfiber cloth with some mineral spirits on it to dissolve any remaining glue....and gone without a trace!
      Now to touch up the mesh that the corrosive nicotine sludge dust ate up....
      Like it never even happened.
      Tested the lights....they work.
      That's where I left off for today....and most of you probably think it's just a matter of reassembling...well, it's not!! More later!
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      • 370forlife
        Large Marge
        • Aug 2008
        • 3113
        I remember seeing those Dell XPS and the similar Precision machines in MaximumPC back in the day and drooling over them. So cool looking.
        • 370forlife
          Large Marge
          • Aug 2008
          • 3113
          A new (to me) soundblaster PCI512 came in and it worked immediately, so there was some sort of weird low level incompatibility with the X-Fi and the X6DAL-TB2 motherboard.
          I also designed and 3D printed a cowl for the two heatsinks to have a single 120mm fan pulling air through both at the same time. That fan ejects straight into the rear 120mm case fan, which I also upgraded to a 38mm thick Nidec TA450DC to help pull more air though the case and especially over the ram and northbridge. Keeping CPU temps around 75C at full chooch now which I am really happy with.
            • Jul 2011
            • 6083
            • Soldering Junkie
            #185
            Nice work
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16997
              #186
              I just thought I'd cap off the XPS build. Everything worked....but not without a weird quirk. I added 64gb of PC4-3200 and saw it's only running at 2400, which is stock speeds for a v4 e5-2600 series xeon. All attempts to bump the RAM clock up to 3200 failed; BIOS would not lock in the settings and I noticed the really good overclocking tabs in the UEFI were missing.... Board had the latest BIOS on it....so I emailed a contact I have at Supermicro. He reveals that when Xeon CPU's are used in this board, all overclocking abilities are disabled and can not be enabled. The only way I can get the overclocking functions is to swap the Xeon out for a skt2011 I-series.... I'm not going to do that, so I'll just live with the RAM not running at its capacity....
              Anyway....
              Flash off....
              Super cool lighting....
              My plan was to take the removable side panel and cut a window in it.....but some other stuff came up, so that got scrubbed for now....no idea when/if I'll ever get back to it....
              Supermicro C7X99-OCE-F skt2011
              Xeon E5-2687W v4 @ 3GHz 12C 24T
              ASETEK 650LX Liquid cooler
              64GB Gskill Ripjaws RAM
              EVGA 1070TI GPU
              Dell M.2 adapter w/ 1TB M.2
              Win10 Enterprise
              • estabilito
                Svod 4 i2c weird problem
                by estabilito
                hi - i have problem with my svod 4 programmer - when im trying to read kbc ic using i2c protocol - im doing it like soldering wires sda scl + gnd to the points on battery socket using schematic of laptop board - but the programmer see weird chip id like B4B4B4 and when im clicking read it takes very long like 15minutes and then programmer read useless things like the name some FFFF's and B4's - programmer work only when i press "read id" on svod4 app and in the same time i turn on power to the board - otherwise when i first turn on PSU, wait 15sec then svod see this weird things.
                05-07-2026, 11:16 AM
              • Loki_Fido
                (Weird) BIOS info for HP Pavilion Aero 13-be1021AU
                by Loki_Fido
                Hi folks,
                This HP Pavilion Aero 13-be1021AU came to me for a repair. And it seems to have a weird BIOS chip. (Pic attached)
                I asked my CH341A to read it and doesn't even know what to do with this. We are both very confused.
                BIOS - XMC 25RU128CH10 (1.8v)
                What the heck is this? I looked all over the MB. This is the only bios.
                When I asked the NeoProgrammer to detect it, it just pops up an empty screen, and asked me to enter the bios number. And when I did, it doesn't do anything. NeoProgrammer showed me just this SPI ID: 204418. Don't know what...
                03-20-2025, 01:57 AM
              • Dobrowol
                Dell Latitude 3520 help with bios build/repair
                by Dobrowol
                Hello. Ive got problem with Dell Latitude 3520. After power on, no display and fan goes crazy. Standard job, I exported a clean bios from update via pfs extract.
                Steps i done and results:
                I exported a clean bios from update file via pfs extract.
                1. Build clean bios with clean ME, PMC, PCH in flash image tool.
                Result: Dead
                2. Build clean bios with no changes in ME, new PMC, PCH
                Result: Dead
                3. Build old bios with clean ME, new PMC, PCH
                Result: The same
                09-22-2023, 02:43 AM
              • Boardview and Schematic Bot
                ACER Revo M2-601 Revo Build i3-6100U Specification for Upgrade or Repair
                This specification for the ACER Revo M2-601 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Revo M2-601 boardview and Revo M2-601 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ACER Revo...
                09-12-2024, 03:28 PM
