another watercooling disaster.
  • sofTest
    • Aug 2008
    • 361
    Re: another watercooling disaster.
    Safe liquid cooling.
    Be a mensch
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Originally posted by sofTest
      I was wondering when someone would come up with that gimmick to clean out idiot's wallets.
      [It's a radiator mounted in a tank of water. - Big fat hairy deal...]
      Back around '99-'00 they were charging $1000's for these cases with built in refer units in the bottom to cool those HOT HOT P3's.
      Then back in '97-'98-ish it was Peltier Coolers.
      [They even had them for those 486 infernos.]
      So tell me....
      If it's 'Total Submersion' ,,, then why do they need tubes.
      Incidentally. True natural circulation doesn't work very well with water as the fluid because water will stratify into different temperature layers and not mix. You need some form of agitation to prevent stratification.
      Mann-Made Global Warming.
      - Dr Seuss
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Hey! - They still make 'em!
        http://www.trustedreviews.com/periph...ted-PC-Case/p1
        They got cheaper..... Want one?
        - Dr Seuss
        • Wizard
          • Mar 2008
          • 2296
          Hot P3?
          In all the time I worked on P3 based all the way from coolest 533 (15W socket type) to hottest PIII 1.13 and any Tualatin based CPUs, I had no issues with cooling even with retail heatsinks. What on earth what you having problem cooling these? It is all in the heatsink and how well PC's air flow is. Doesn't have to be hurricane-force wind.
          The hardest to cool was Athlon socket 462 and P4 prescott. But the basic rules of good heatsink and PC air flow still applies. Majority of these I used retail heatsinks for Intel CPU and for Athlon, I used copper bottom with alumium fins (compressed type) not the shrived or stamped fins. Heatpipe heatsinks are also good if it is quality design.
          Cheers, Wizard
          • 370forlife
            Large Marge
            • Aug 2008
            • 3112
            http://www.thedungeonlanparty.com/Pi...8/SANY0131.jpg
            Cheap way, fish tank with a motorhome trans cooler, the liquid is wire EDM fluid.
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              #26
              explains why my phone survived 3 dunks in the stuff.
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                #27
                Originally posted by Wizard
                Hot P3?
                I think PCBonez was just kidding there .
                http://www.trustedreviews.com/perip...ated-PC-Case/p1
                That's just a step before people will buy whole refrigerators/freezers for their computers.
                • sofTest
                  • Aug 2008
                  • 361
                  #28
                  So tell me....
                  No, everything except the HDs is submerged in the fluid. From the article in Norwegian I read about this, they thought the fluid to be some kind of perfluorocarbon, my be 3M fluorinert. That might explain some of the price on the rig, as it costs almost US$400 per litre. If true, and as it's used to cool Crays, it can't be all useless, if you got to much money to put in a rig.
                  Be a mensch
                  • 370forlife
                    Large Marge
                    • Aug 2008
                    • 3112
                    Ya, we did that at our local lan party.
                    http://www.thedungeonlanparty.com/Pr...0Immersion.htm
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      Hot P3?
                      ~ Just making fun of the advertising from back then.
                      - Dr Seuss
                      • nat0snake
                        • Dec 2008
                        • 4
                        #31
                        This reminds me of the time I was building my PC last year. The sales person at Tiger Direct kept forcing it on me to buy the on sale watercooling DYI kit. I just kept telling him
                        Electronics + Water = good chance of BAD
                        I obviously did not buy it......
                        • Wizard
                          • Mar 2008
                          • 2296
                          #32
                          heh ok now I see what you mean about the mocking the P3. Heh!
                          Cheers, Wizard
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            I think it's a hoot that they still push this stuff.
                            CPU heat/watts peaked at about 800FSB P4 Prescott / Socket 604 Xeon in the 120-160 watt range [both of which could be cooled well enough with a decent air cooled setup] and then heat dissipation dumped to like 40-65 watt range with the Core Architecture.
                            People have the fast = hotter idea locked into their brain and since Netburst based CPU's went away it simply isn't true anymore.
                            There are dual core Xeons that only use 35-40 watts and most common C2D are around 65 watts.
                            Cooling chips like those is a breeze [pardon the pun] and you just don't need anything fancy or exotic.
                            - Dr Seuss
                            • Krankshaft
                              • Jan 2007
                              • 2328
                              If I had to make these water cooling systems leakproof (or as close as humanly possible).
                              I'd use copper tubing with soldered joints. All metal and none of that plastic crap through and through. I say solder because compression fittings suck and leak easily if not installed properly.
                              You could flare the tubing as a close second to soldering.
                              • ratdude747
                                Black Sheep
                                • Nov 2008
                                • 17136
                                what if you used plastic and silicone sealant?
                                sigpic
                                (Insert witty quote here)
                                • Phaihn
                                  • Jan 2009
                                  • 842
                                  I've considered that.
                                  My Computer.
                                  AMD APU A4-3300 2.5ghz 1mb cache
                                  Motherboard GigaByte GA-A75M-S2V
                                  Kingston HyperX Blue DDR3 8GB (2x4GB)
                                  SB Audigy 2 ZS [B800] Sound Card
                                  500GB WD Caviar® Blue™
                                  1 Terabyte WD Caviar® Black™
                                  2 Terabyte WD Caviar® Black™
                                  • pfrcom
                                    Oldbie
                                    • Jun 2006
                                    • 1230
                                    Already done with blade servers in data centres - rack looks like a refrigerator for servers with all the cooling coils & stuff in it
                                    Knurr CoolTherm Server Rack
                                    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
                                    • bussincaps
                                      MacBook Pro Mid-2014 A1398 Retina LED Controller Connector [First Repair (Disaster)]
                                      by bussincaps
                                      Hello All,
                                      tl;dr: minimal electronics experience and my first repair, lifted 8 pads off the laptop display LED controller board when attempting a connector replacement, options are attempting pad repair or jump wiring.
                                      Laptop Model: MacBook Pro 15 Mid-2014 Retina, A1398 MGXA2LL/A
                                      eDP Display: Samsung LSN154YL01-A02, assembly sold as Apple part 661-8310
                                      Soldering Equipment: Hakko FX-888D w/ T-18 tips (Chisel, Conical, Bevel types)
                                      I needed to replace the 30-pin I-PEX Cabline connector (labeled J8300 in the Apple 820-3662 mainboard schematics),...
                                      08-03-2023, 12:57 PM
                                    • nobbnobb1
                                      DIY NAS Service Life (Hardware)
                                      by nobbnobb1
                                      So I'm probably a decade behind on this, but my current NAS is a low power machine I built in 2009. It was originally running Windows Home Server, then eventually I migrated to Windows 10 using Storage Spaces for my drive expandability and redundancy. Despite being slow for W10, I love the familiarity and functionality so I never bothered getting into NAS specific OS.
                                      Hardware wise, it's got 4x drives but the hardware is all super low draw, so the Antec EarthWatts EA380D power supply is barely above ambient. This PSU is apparently known for capacitor issues but when I went in to...
                                      09-25-2023, 04:35 PM
                                    • vbogoev
                                      GYSMI 160p welder transistors shorted
                                      by vbogoev
                                      Here I have GYSMI 160p welder with no output. Otherwise the machine is starting, the fan is spinning, but the output is zero... I disassembled the welder and found the problem. 3 out of 6 transistors are shorted, and 3 pairs of 4 resistors are burned... There's also 1 burned "ultra fast diod" on another board that is connected to the transformer. My question is how can I identify these burned resistors, I have no idea what value they should be, also I am not able to find any image of the board over the internet... The other part numbers are clearly visible, so I...
                                      08-31-2023, 03:53 PM
                                    • courtcircuit
                                      Onkyo TX-NR801e No sound
                                      by courtcircuit
                                      Hello
                                      Got his monster in a waste.
                                      It was probably dropped there due to the fact that no sound gets out, nor speakers, nor headphone
                                      Everything seems to work. Just have to clean the volume encoder, but the remote is fully controling it.
                                      Relays are closing (it looks like from a first look into the beast) that there are a lot of them.
                                      When I switch it from standby to live, they react, I can hear a little static noise in the headphone. the same when switchin it off.
                                      Ive seen that a lot of similar devieces from onkyo suffers from...
                                      08-18-2023, 10:32 AM
                                    • N²x²N
                                      ASROCK K7VT4A PRO repair
                                      by N²x²N
                                      Hello!
                                      I bought this board but isn't powering on. Seller told me it was fine and stable.
                                      Got it for a dime but it supports NX models.
                                      Ths cpu it came with works fine and the 2gb are error free (2x1gb).
                                      https://www.asrock.com/mb/VIA/K7VT4A%20PRO/#BIOS
                                      I inspected the board many times and no component gets crazy hot, not even lukewarm; no traces are cut or damaged.
                                      Battery is fine on its circuit.
                                      The ASM1117 outputs 3.5V instead of the usual 3.3x I saw in many other boards.
                                      https://pdf1.alldatasheet.com/datasheet-pdf/vi...
                                      05-11-2023, 05:09 PM
