Compaq hard drive down for the count
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    I believe the hard drive went bad in this computer. A compaq presairo sr1703WM, the hard drive is a seagate 7200.7 80gig.
    When it tries to boot, it goes "click click click clickkkkkkkkkkkkk click click click clickkkkkkkkkkk...."
    Eventually tells me that it has a invalid boot.ini, then tries to boot from C:\windows, but then crashes and restarts.
    The motherboard is a Asus A8AE-LE, ATI radeon xpress 200 chipset with a sempron 3200+ socket 939, and a measly 256MB of hynix ddr-400.
    Going to suggest a new hard drive, and also to replace the bestec in this machine.
    What do you think of this power supply? The customer wants it to be cheap, but not 'cheap'.
    http://www.newegg.com/Product/Produc...82E16817171028
    It OEM's to AcBel, so its not entirely cheap, and I figure for $35, its gotta be at least a decent 300W actually in there.
    Or should I just got with something like a 300w FSP, which are about $30?
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: Compaq hard drive down for the count
    BTW, the caps are all UCC KZG's and Rubycons.
    • 370forlife
      Large Marge
      • Aug 2008
      • 3112
      Strange, I whipped out the DMM to check the voltages on the psu, especially the 5vsb.
      When I read it, it was not shorted and running, I put the leads to the 5vsb and the negative next to it, and it read 4.11V. Thats not right, I checked the other rails, and they read 12.28 and 5.12 with just a hard drive attached. In spec, so why is the 5vsb so low, and yet the computer still starts? Or is my DMM probably wanky? Its a Equus innova 3320.
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        your hard drive has a head crash. I personally like seagate, so this is disturbing
        a 300 watt should be okay as long as they dont use a REALLY fast gpu or do a lot of optical burning.
        beware- cooler master power supplies have lousy caps, or so i have heard.
        try geeks.com - they sometimes have good brands (stay away from the a-power, but to say that is preaching to the choir, i know)
        hope all works out
        sigpic
        (Insert witty quote here)
        • 370forlife
          Large Marge
          • Aug 2008
          • 3112
          I'm thinking about just getting a delta off ebay for cheap, usually pick them up for about $10 for a good 300W w/ sata connectors, which is good because the replacement HD is a sata hard drive.
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            yup, deltas are good
            sigpic
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              Well the hard drive is most likely broken (probably a head crash). Still, have you tried hooking it up to a good PSU? I doubt this will do anything, but maybe there's a slight chance the Bestec is being screwy.
              As for PSUs, you can find quite a few good ones on newegg for $35. Going from memory, there's a 400w HiPro with free shipping for that price, a few 300-350w FPSs, and a 300w Seasonic with APFC for a few $ more. Of course, the Cooler Master is probably ok too.
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                cooler master= bad caps
                look at the picture of the cables. the sata wire look a bit thin
                the text bleow the chart on the label says "the +3.3v & +5v & +12v1 & +12v2 COMBINE shall not exceed 401.5 watts"
                first, 401.5<460 - bad info
                second, notice that i bolded COMBINE, not "combined". looks like engrish to me
                go with the delta. full of nippon chemicons, rubycons, and/or nichicons. just bought a 350watt one at my local computer shop today. much better quality
                sigpic
                • Wizard
                  • Mar 2008
                  • 2296
                  early in the socket 7 days when K6 got hot as well as athlon cpus, I had diffcult time finding good heatsinks (back then, Intel's retail CPUs was a fortune to buy. Coolermaster was only choice that had enough fins surface area and good delta fans (if you look where to look for, hard to mistake a delta fan for what it is!). But rest of coolermaster heatsinks/fan combo are grabage.
                  And still is. Once I had choice of good heatsinks like Alpha PAL series other than coolermasters and other heatsinks with copper base, went I go! No more coolermaster at all. Intel retail heatsinks for C2D are decent enough for normal use now.
                  Cheers, Wizard
                  • 370forlife
                    Large Marge
                    • Aug 2008
                    • 3112
                    Delta usually uses Ltec and capxon in their lower end psu's, but they have very good protection circuitry, so if one goes screwy, it can't really cause any major damage.
                    I just bought a delta 300w off ebay, it is a higher end 300w of theirs, has huge heatsinks, a little pcb just for the input filter and rectifier, the main caps are two nichicons and the secondaries are all Ltec except for one rubycon.
                    Thinking I may buy the other one from the seller for the compaq, but the replacement HD is sata, and this psu dosen't have sata.
                    • stevo1210
                      • Oct 2006
                      • 4156
                      I second that statement. Some low end Cooler master PSUs use crappy caps and are kinda flimsily built. Um. Deltas are good though, some Deltas have UCC, whereas others have Ltec and Capxon.... I use these and I haven't seen a failure ever.
                      Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        agree
                        sigpic
                        • everell
                          • Jan 2009
                          • 1514
                          I put the leads to the 5vsb and the negative next to it, and it read 4.11V. Thats not right, I checked the other rails, and they read 12.28 and 5.12 with just a hard drive attached. In spec, so why is the 5vsb so low, and yet the computer still starts? [/QUOTE]
                          What model Bestec?
                          Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
                          • 370forlife
                            Large Marge
                            • Aug 2008
                            • 3112
                            its a 250-12Z
                            • everell
                              • Jan 2009
                              • 1514
                              [QUOTE]I put the leads to the 5vsb and the negative next to it, and it read 4.11V.
                              I didn't quite understand "the negative next to it". Are you measuring on the power supply pc board, the atx connector that plugs into the mobo, or somewhere else? For the negative side, I usually use an unused power connector, one that can plug into hard drive or CDROM, just plug the meter probe into one of the center black wires. That is the ground for 5vsb. Then can pick up 5vsb measurement off the violet wire on the ATX connector plugged into the mobo. Try measuring it that way and see if it makes any difference.
                              • 370forlife
                                Large Marge
                                • Aug 2008
                                • 3112
                                The attached picture shows the two pins I was using to measure. As you can see there is a ground right next to it, that's what I meant by the negative next to it.
                                • Wizard
                                  • Mar 2008
                                  • 2296
                                  Power_on is shorted to ground to turn ATX PSU on.
                                  There is no such as negative ground. All voltage measurements is referenced to the ground. There are two wires that usually have -5V and -12V measured to ground. Your DMM will say - voltage when measuring negative voltage or your probes reversed by mistake while measuring positive voltage.
                                  Standby voltage is what you should also measure against ground. The power_on pin is a signal not a voltage, it has bit of voltage via a pull up resistor to 5V internally in the PSU and mainboard pulls it low near ground via a transistor on the mainboard itself.
                                  Remember, in other non-PC applications there is some PSU designs that has isolated winding that does not have a ground connection and is still a DC due to diode and a capacitor network, usually for audio or other special application where double isolation is needed for extra safety.
                                  Cheers, Wizard
                                  • 370forlife
                                    Large Marge
                                    • Aug 2008
                                    • 3112
                                    am I retarded or what
                                    Hmmm, this is no good, its reading 5.90V. How did this ati chipset not fry yet? Good thing I got it out of there now.
                                    Last edited by 370forlife; 06-14-2009, 12:16 PM. Reason: thats no good thats no good thats no good thats no good....
                                    • Wizard
                                      • Mar 2008
                                      • 2296
                                      Good that you got this caught. Go retail Seasonic!
                                      Keep us updated.
                                      Cheers, Wizard
                                      • everell
                                        • Jan 2009
                                        • 1514
                                        If 5vsb measures 5.90 volts, it is only going to get worse, not better. This sounds more like the Bestec ATX-250 12E rather than the 12Z, unless they are playing games with the labels. Definitely time to change power supply to something like has been recommended.
                                        If you decide to dumpster the Bestec, send it my way for further analysis. I will reimburse you for the shipping expense. This is the first 12Z I have heard having a 5vsb problem - the 12Z model uses a PWM chip for better voltage control.
                                        Tom
                                        • federalhouse
                                          **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                                          by federalhouse
                                          I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                                          **Background:**
                                          I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                                          **What I've Tried So Far:**
                                          1. I accessed
                                          08-01-2024, 07:03 PM
                                        • tmcw
                                          PC case - Hard drive rails
                                          by tmcw
                                          A friend gave me his old PC case (with MB, and PSU), but no hard drive rails, he said he only used the 2.5" SSD spot inside, and used an external hard drive for data. He said that he'd have a look for the supplied rails, but I doubt he'll find them.
                                          So I was wondering if case manufacturers used any type of standard 3.5" hard drive rail?
                                          I'm used to the various Dell hard drive caddies or rails (and HP and Lenovo to a lesser extent), or el cheapo cases where you screw through the frame to fix the drive.
                                          Now, the case is a CiT Gaming Case, and...
                                          05-22-2022, 12:04 PM
                                        • madura2010
                                          DAY11AM6E0 hard disk drive and optical disk drive not detected
                                          by madura2010
                                          Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                                          i checked the connectivity of ribbon=good communication with hard and motherboard
                                          changed hard disk and checked=3f0 error persist
                                          sata power=+5v available
                                          Then checked data capacitors=all good
                                          Then checked data lines path connectivity to pch=all good
                                          reflashed...
                                          03-12-2023, 09:09 AM
                                        • ash91
                                          Hp pavilion 15 not detect hard drive
                                          by ash91
                                          Hello gentelmen .... this is my first post and sorry for my bad english,
                                          so my proplem is my laptop keep losing hard drive even if i but the
                                          hard disk in the cady (the box that can replace the dvd rom with hard disk)
                                          when i turn the laptop on the massage that said no boot media found pop on
                                          the hard disk is fine and to be sure i try another hard
                                          i also update my bios to the last update
                                          the 5 volt is present on the hard connector on the motherboard
                                          the dvd rom work fine when i but a windows dvd in it
                                          also when i boot from flash...
                                          06-07-2023, 01:45 PM
                                        • karto95
                                          Repairing a Seagate hard drive with damaged logic board
                                          by karto95
                                          I'm currently facing an issue with my Seagate hard drive that has a damaged logic board. I've obtained a replacement logic board from a donor hard drive, but unfortunately, I'm unable to recover the BIOS of the original board due to damaged firmware. I'm wondering if it's possible to make the hard drive work with this donor logic board.
                                          I have a CH341A programmer, so I'm hoping that it can be useful in this situation. I've attached the BIOS file .bin of the donor board for reference.
                                          If anyone has any suggestions or experience with this...
                                          03-21-2023, 04:05 AM
