Hard Drive Brand Recommendation
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Hard Drive Brand Recommendation
    Oh, BTW, this was on a PC that was not OC'ed and fine.
    And the errors after formatting occurred even with a fresh partition and connected to a Prime95 stable PC, when connected to my Asus P5QL Pro for testing and that's when I noticed file system errors.
    Windows Vista didn't error out when the HDD was changed, the Windows Vista installation was fine after changing the HDD.
    ->Looks like the PCB or cache is bad. Because it seems to stealthly corrupt data!
    ->Where even MHDD can't detect it! ->NOT a classic Western Digital failure, where they're would be sectors flagged.
    ->When I scanned with MHDD, not even signs of sector access problems and even the seek test is fine!
    Could be solder joints LOL.
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • KeriJane
      Mac Enthusiast
      • Sep 2008
      • 681
      Hello.
      I just replaced a Seagate 7200.7 160GB SATA drive out of an HP Pavilion.
      The drive has 4 years of light use and grew some bad sectors causing Windows to crash but fortunately sparing the 10GB of personal data.
      This seems noteworthy to me because the drive was mounted vertically against a well ventilated air input with decent airflow. Even so, the drive was sitting here at 45℃ and SMART had recorded a max of 50℃.
      Oh well. 4 years isn't actually bad but this was a light user mostly surfing the web and saving pictures from his camera. He didn't even have Photoshop on the system. Plus it was well cooled. Additionally, the Bestec 300-12z PSU tested well under load with very little Ripple. (it seemed low at well under 50mv @ 200-220w)
      I can't imagine this drive lasting very long in a Video Editing machine with less than perfect cooling or maybe a little more Ripple.
      It's a bad idea to generalize but this is the latest of a series of very hot Seagate 7200.7 - 7200.10s that I've come across. All but 2 had some bad Sectors and those were click machines.
      Could the heat be killing these drives? Or the rumored platter coating flaking?
      Maybe Seagate isn't so great despite their popularity?
      The single 7200.11 I came across seemed cooler to the touch. (yes, I updated the firmware while it was here) Also it tested OK and wasn't a clicker.
      Have Fun,
      Keri
      The More You Learn The Less You Know!
      • i4004
        • Oct 2006
        • 2029
        #43
        i'm a heavy user of 2 7200.7 drives and they're still going strong.
        fragmentation is unbelievable(i never reall defrag) i do a lot of video, millions of small files too etc.
        no problems whatosoever.
        weord that you say that, as my main rig really is video editing machine, primarilly.
        i'll let you know if anything happens to these 7200.7 of mine.
        <wink>
        • EGuevarae
          • Nov 2008
          • 1336
          Originally posted by i4004
          fragmentation is unbelievable(i never really defrag) i do a lot of video, millions of small files too etc.
          no problems whatsoever.
          Fragmentation (or lack of it) is tied to the underlying file system (FAT, FAT32, NTFS,HPFS,you-name-it...), which in turn is responsibility of the host OS.
          Just my 0.02 ......
          And the 7200.7 drives I've seen in video editing are dead already. Four of them is not that much of a testing universe, but if you consider that the set consisted of five, it makes you wonder.
          There are 10 kind of people in this world: those that understand binary, and those who don't.
          • ASUS ROG Maximus IX Code
          • Intel Core i5-7600K 3.8GHz
          • 16gb GSKILL TridentZ RGB DDR4-3200
          • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
          • Windows 10 Pro x64
          • GeForce GT1050
            2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
          • bgavin
            • Jan 2007
            • 1355
            #45
            I'm just finishing up a Vaio laptop that developed bad sectors and destroyed the OS.
            The good news is, the hidden recovery partition was unaffected.
            I imaged the entire disk, then wiped the system partition, and made a second image of the empty sys plus the recovery partition.
            Newegg overnighted a WD Scorpio Black in 320gb both cheaper/faster than I could get to Fry's this morning. $21 shipping vs. at least 1 hour service call to go buy the part. Fry's rarely stocks the premium drives, so I was better off buying from Newegg anyway.
            I was able to restore the image to the new drive, do an F10 restore at bootup, and restore to factory default condition. The customer data survived, so that is restored also. A lot of work. Emergency basis, good money.
            The bad drive was (of course) yet another Hitachi notebook drive. I have quite a pile of dead ones now.
              master hoarder
              • May 2008
              • 12175
              #46
              I'm guessing that Hitachi is one fo those earlier Travelstars. If so, those are notorious for failure, just like their Deskstar (GXP 60/75) siblings of that era. But at least they don't fail without prior notice (that is if you occasionally check the SMART data) or fail "at once".
              • KeriJane
                Mac Enthusiast
                • Sep 2008
                • 681
                Hi bgavin
                Odd... I've never seen a bad Hitachi/IBM notebook drive. I've seen quite a few and replaced several with larger or faster drives.
                I would expect to see at least some failures because of the rough treatment laptops often receive but haven't yet seen a dead or even dying Hitachi.
                Anybody want some 5, 10, 20 or 30GB Hitachis?
                Actually, I threw out most of them (after a secure wipe of course)
                Keri
                • EGuevarae
                  • Nov 2008
                  • 1336
                  Originally posted by KeriJane
                  Hi bgavin
                  Keri
                  I can take one or two either 10 or 20 for a little experiment I have in mind (two same capacity over 8gb would do it as long as they are 2.5", the larger the better).
                  • GeForce GT1050
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    DK23BA series had an issue where the firmware would go 'poof'.
                    5K80 and 5K100 series had clicking issues in combination with certain BIOS's.
                    Interestingly Thinkpad BIOS's were like the worst one for that problem.
                    Thinkpad <-> IBM <-> Hitachi
                    You need to put those here.
                    https://www.badcaps.net/forum/forumdisplay.php?f=12
                    And yes, I'll look.
                    Mann-Made Global Warming.
                    - Dr Seuss
                    • i4004
                      • Oct 2006
                      • 2029
                      #50
                      Just my 0.02 ......
                      what matters is how they die: if they start developing bad sectors i don't have issue with that...if they die suddenly, i have...
                      ie if they work fine for 4-5 years and then develop bad sectors, that's fine by me.
                      as for fragmentation and os/file system: so are you saying that there is a filesystem that deals-away with fragmentation?
                      well, offcourse you're not, and just knowing operating principles of hdd means you must have fragmentation, regardless of filesystem...
                      • EGuevarae
                        • Nov 2008
                        • 1336
                        I too agree on the bad sectors. The units I told about died suddenly. I didn't check the PSU on those, now that I remember.
                        And as for fragmentation, it can't be completely avoided, especially on heavy use, constant file deletion systems. But the underlying OS (the FS, mostly) has to do with fragmentation on logical partitions.
                        Deal away with fragmentation? Not yet. Try to reduce it? Well, they try.
                        Depending on the use, FAT32 tends to frag more than HPFS or NTFS. I speak from personal experience. Actual mileage may vary ....
                        Out of curiosity, I opened an external hard drive that I had for quite along time : a 7200.7 is in there, still going.
                        • GeForce GT1050
                        • federalhouse
                          **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                          by federalhouse
                          I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                          **Background:**
                          I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                          **What I've Tried So Far:**
                          1. I accessed
                          08-01-2024, 07:03 PM
                          HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
                          This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                          09-12-2024, 02:00 PM
                        • karto95
                          Repairing a Seagate hard drive with damaged logic board
                          by karto95
                          I'm currently facing an issue with my Seagate hard drive that has a damaged logic board. I've obtained a replacement logic board from a donor hard drive, but unfortunately, I'm unable to recover the BIOS of the original board due to damaged firmware. I'm wondering if it's possible to make the hard drive work with this donor logic board.
                          I have a CH341A programmer, so I'm hoping that it can be useful in this situation. I've attached the BIOS file .bin of the donor board for reference.
                          If anyone has any suggestions or experience with this...
                          03-21-2023, 04:05 AM
                        • tmcw
                          PC case - Hard drive rails
                          by tmcw
                          A friend gave me his old PC case (with MB, and PSU), but no hard drive rails, he said he only used the 2.5" SSD spot inside, and used an external hard drive for data. He said that he'd have a look for the supplied rails, but I doubt he'll find them.
                          So I was wondering if case manufacturers used any type of standard 3.5" hard drive rail?
                          I'm used to the various Dell hard drive caddies or rails (and HP and Lenovo to a lesser extent), or el cheapo cases where you screw through the frame to fix the drive.
                          Now, the case is a CiT Gaming Case, and...
                          05-22-2022, 12:04 PM
                        • madura2010
                          DAY11AM6E0 hard disk drive and optical disk drive not detected
                          by madura2010
                          Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                          i checked the connectivity of ribbon=good communication with hard and motherboard
                          changed hard disk and checked=3f0 error persist
                          sata power=+5v available
                          Then checked data capacitors=all good
                          Then checked data lines path connectivity to pch=all good
                          reflashed...
                          03-12-2023, 09:09 AM
