Vga Fan Speed
  • xsi_xsi
    • Mar 2009
    • 8
    Vga Fan Speed
    Hi there,
    Is this possible for me to reduce the fan speed of my VGA card (XFX 9600 GSO) using a resistor in series? Or is there any other easy way for that. The fact is that I'm sure I can not adjust the fan speed, because the fan on the heatsink only uses a two pin connection. See the attached image please. The sound is killing me.
    Any help would be greatly appreciated.
    Thanking you.
    http://img144.*************/img144/3526/img0799wr.jpg
  • kikkoman
    • Jul 2007
    • 691
    Re: Vga Fan Speed
    err... you could surely do that with a 7805 or - even better - a lm317 (variable) but i'm not sure if temps would still be tolerable. don't know how hot a 9600 runs.
    that fan is probably crap anyway.
    Zalman coolers are great but pricey, maybe you can find a AC VGA silencer or accelero for less money. others here recommended rocket coolers (just addon fans i suppose, but why not?)
    "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
    • 370forlife
      Large Marge
      • Aug 2008
      • 3112
      Re: Vga Fan Speed
      Since thats the stock cooler, I wouldn't reduce the fan speed, it would probably overheat.
      That being said, check the temperature of the card, speedfan usually works well, if the temp is high, the card may have preset voltages to run the fan at certain temperature intervals. May just be some case cooling is in order.
      If the temperature is fine, you may just need to go with a aftermarket cooler that is quieter.
      http://www.newegg.com/Product/Produc...82E16835118037
      I bought that one a while ago for my old 8600gt, it comes with a zalman fan mate or a regular 3 pin connector for your motherboard. Either way, it was really quiet, but is heavy, big, and expensive.
      http://www.newegg.com/Product/Produc...82E16835118116
      Thats also a nice one, a lot cheaper, too.
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        Re: Vga Fan Speed
        i used to use rivatuner to mess with fan speed of geforce
        but yeah inadvisable to use resistor and better go with aftermarket solution
        that fan looks tiny and will fail early
        first time i saw a decent looking stock fan was on this card
        http://www.twintech3d.com/products_f...asp?num=218#b2
        time they made all those tiny fans go the way of the floppy disk
        • ss627
          Super Member
          • Mar 2008
          • 52
          Re: Vga Fan Speed
          I had this problem on a xfx 8800gs which is essentially the same card as your 9600gso. I used a diode chain to lower the fan speed but it's a bad idea.
          Even during the winter, the card idled at 50ºc and went into the 70's playing simple games. Now, imagine the summer. You should consider investing in a good aftermarket cooler so you can reuse it when you change videocards in the future. The stock heatsink on the xfx is total garbage.
          • bgavin
            • Jan 2007
            • 1355
            Re: Vga Fan Speed
            I buy passive cooled cards, then put a Rocket V cooler in the slot below it.
            The two 70mm fans in the Rocket do an excellent job of cooling the card and the northbridge nearby.
            I run about 46C on average for the card temps.
            • xsi_xsi
              • Mar 2009
              • 8
              Re: Vga Fan Speed
              Thanking you so much for all of the comments. The fact is that the VGA cooling systems and brands you are talking about is not available in my country. The only VGA cooler I have found is Zerotherm Hurricane HC92 Cu model in local stores. The following link:
              http://www.zerotherm.net/eng/product/HC92CU-88.asp
              Is this a suitable model for current graphic card (XFX 9600 GSO) ? How about if I want to upgrade my graphic card in future - Is this VGA cooler still workable? I really need a silent and high performance cooler and don't know whether this Zerotherm could meet my expectations.
              Thanking you.
              • ss627
                Super Member
                • Mar 2008
                • 52
                Re: Vga Fan Speed
                That zerotherm or duo-orb or any of these older design heatsinks like zalman with a proprietary fan are junky for their performance. My vf700 and 900 were unacceptable for cards newer than a 8800gt. I really doubt you'll be able to effectively cool down newer generation cards with them. What country are you from?
                • xsi_xsi
                  • Mar 2009
                  • 8
                  Re: Vga Fan Speed
                  Thanks for the info. Would you please recommend me some suitable heat sink and fan for such purposes? Please provide me some options (in order of performance) preferably with product's link from newegg.com. I'm living in Qatar and many of those quality products from famous manufacture and brands in not available in our market.
                  • KeriJane
                    Mac Enthusiast
                    • Sep 2008
                    • 681
                    Re: Vga Fan Speed
                    Hi XSI
                    Yes, it is possible to slow down the GPU fan using a resistor in series with the fan wire.
                    I have done this many times on lower-end video cards with noisy fans. Your 9600GSO consumes a lot more power and produces more heat but you should be able to reduce the speed and noise somewhat without raising the temperature too much.
                    I generally use a 5w wirewound power resistor in a square, white casing. This allows easy attachment to the videocard cooler with a dab of hot glue.
                    The value for a small noisy fan like yours and the ones that I have experience with should be something along these lines:
                    22Ω- minimal effect, very slight reduction in noise, minimal risk to card.
                    47Ω- noticeable reduction in noise
                    82Ω- very noticeable reduction in noise, may cause overheating
                    100Ω- very noticeable reduction in noise, more likely to overheat a hot card.
                    It is important to monitor the GPU temperature carefully after modding the fan speed by running a GPU stress program like the one in ATITool. If the GPU starts to run hot, shut down the program and use a lower resistance value.
                    Overclocking the card after slowing down the fan is a really bad idea.
                    Lapping the contact area of the heatsink so that it is very flat and smooth and then using Arctic Silver 5 heat transfer compound is also a great idea. This will help compensate for the lower fan speed by allowing heat to flow more easily from the core to the heatsink.
                    Strangely, some cards actually run COOLER with the fan slowed down! This is probably due to the lapped heatsink and Arctic Silver. Maybe it's because the fan only makes more noise over a certain speed without increasing airflow as much, possibly due to increased turbulence?
                    The lower fan speed seems to reduce the rate of dust clogging as well.
                    I suggest getting the following to experiement with:
                    small heatshrink tubing
                    soldering iron and solder
                    a hot glue gun or some epoxy
                    one each of the following 5w or 10w wirewound resistors
                    10Ω, 22Ω, 47Ω, 56Ω, 68Ω, 82Ω, 100Ω
                    5w or 10w is overkill for such small fans but they stay pretty cool.
                    Have Fun!
                    Be Careful!
                    Keri
                    The More You Learn The Less You Know!
                      master hoarder
                      • May 2008
                      • 12175
                      Re: Vga Fan Speed
                      Maybe it would also be a good idea to add a switch between the resistor legs to bypass resistor in case full fan speed is needed again.
                      • ss627
                        Super Member
                        • Mar 2008
                        • 52
                        Re: Vga Fan Speed
                        A resistor mod is pointless on this particular xfx cards heatsink. I can guarentee that it'll be a waste of time and money unless your ambient temps are very low.
                        Also, the OP stated that he/she is from Qatar. A definite no no. I think the only option would be international mail order which is costly if there are no suitable hardware stores in Qatar.
                        • xsi_xsi
                          • Mar 2009
                          • 8
                          Re: Vga Fan Speed
                          So, if I want to go for a heatsink and fan, which models should I order?
                          • ss627
                            Super Member
                            • Mar 2008
                            • 52
                            Re: Vga Fan Speed
                            Depends on how much room you have in your case. I use a AC twin turbo model that was on sale. Its not worth it at its regular price. The arctic cooling S1 revision 2 would be your best bet but it is huge. Many people find that it inteferes with sata ports on the motherboard. Thermalright HR-03 GT is pricey but cools well and seems to be more compatible with pc configurations. You should look up reviews on late model videocard coolers.
                            • Babbar
                              1980s Holz Her 2420 belt sander - Only works when speed control at maximum
                              by Babbar
                              My fathers belt sander from the 80s which i very much would like to continue using has an issue with the speed control. The machine works fine on maximum speed but will not turn or give any sign of life when on any other setting. The speed control is a dial going from 1-6 although implemented as a potentiometer without distinct steps. I took the machine apart and measured each component individually, all components and measurements have been captioned in the attached pictures. The Triac did not get identified correctly using my cheapo component tester, i don't know if this is user error, if the...
                              11-13-2024, 01:54 AM
                            • eccerr0r
                              old X58 triple channel board... memtest86 memory speed?
                              by eccerr0r
                              Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                              Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                              Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                              06-28-2025, 09:06 AM
                            • japlytic
                              Maximum speed should be marked on network ports
                              by japlytic
                              I noted that a number of consumer entertainment devices have the maximum speed marked on the wired network port and considering that there are broadband plans faster than 100 Mbit, the wired network port can be a bottleneck since some routers do not have Gigabit (only 100 Mbit) support for the WAN port let alone the wired network ports.
                              One other thing: Certain low cost network cables only have two pairs which limits speed to 100 Mbit.​
                              12-19-2024, 05:04 PM
                            • kleung
                              Dell ultra 7070 ,Foxconn PWM laptop case fan. Spins at 100% speed in failure mode.
                              by kleung
                              I wanted to add to the knowledge base about a PWM case fan that it can fail at 100% speed.
                              On my Dell ultra 7070 (this is a 0.6 L pc so uses laptop parts); I had the case fan suddenly go 100% and I couldn't control it. I disconnected/reset bios and it was only solved when I swapped in a replacement fan.
                              I have tested and there is continuity between the 4 wires pins and the circuit board.
                              That is the extent of my troubleshooting. I took pictures of the circuit board but don't know what component would die (PWM controller?) that could cause this to happen....
                              12-07-2024, 01:45 AM
                            • armands0212@gmail.com
                              Alienware 13 r1 base speed of cpu higher than should be
                              by armands0212@gmail.com
                              Hi guys.i have alienware 13 r1 with weird thing what i cant understan
                              Basically laptop is freezing every time if nvidia gpu is enabled and laptop is on battery power,however it working just fine pn ac power
                              So i wanted to sort this out as thats quite annoying as i need to disable nvidia to use it on battery or use it only with power cord-i already tried change battery,update drivers,change power setting,update bios,install windows 10 and windows 11, but nothing helps it still will freeze on battery
                              What i noticed that cpu speed in bios is 1.70ghz but...
                              06-18-2023, 01:07 PM
