How Hot should MCP55 Host Bridge get?
  • bigbeark
    • Jan 2010
    • 661
    I have an MSI 7260 Ver 1.0 motherboard., socket AM2. On Intel-based motherboard the heatsink on the combined North/South Bridge gets plenty hot, but it's large and tall.
    The AMD heatsink occupies a similar footprint but is pretty low in height and gets really hot. You could burn yourself on it.
    Worth adding a fan?
    Also what about MSI BIos update procedure? Anyone used the newer CD-based one? Seems pretty complicated?
    What's the best option for Bios Update on this mobo?
  • Sparkey55
    • Jan 2010
    • 1523
    Re: How Hot should MCP55 Host Bridge get?
    What about the issue with your ECS 754 motherboard, got it fixed yet?
      • 31200
      anything too hot to touch needs a fan.
      IMO.
      • Stefan Payne
        • 1267
        IMO.
        that's why ~95% of all CK08 and MCP55 Boards do have a fan...
        • bigbeark
          • Jan 2010
          • 661
          I found a SOYO chipset fan in my parts box. Attached it to the passive-cooled heatsink on the MSI 7260 MCP55 bridge with two #4 screws. Seems to have lowered the CPU temps as well if XSENSOR readings are correct.
            master hoarder
            • May 2008
            • 12175
            IMO.
            +1000
            nVidia chipsets made after the nForce 2 (or even nForce 3) should always be kept cool to avoid issues. In general, the nForce 4 chipsets are also a bit tougher than the MCP55 and MCP61 (GeForce 6100/6150), but I recommend having all of these kept cool if you want to avoid issues with chipset failures. This matters even more for nVidia 6xx and 7xx series of chipsets. Same goes for AMD chipsets made after RS482 / Xpress 200, especially the 780 and newer ones (pretty much all AMD chipsets made for socket AM2 and newer).
            The only chipsets that can take a crap-ton of temperature abuse are the oldschool Intel ones, like i845/865, i965, and G31/33/45, P/Q45 and etc. (i.e. mostly socket 478 and 775 Intel chipsets).
            • Ross Kohler
              Diagnosing South Bridge (FH82H370) on Asus H370-Pro Gaming Motherboard
              by Ross Kohler
              I'm learning about motherboard repair and I believe I've traced the issue down for the South Bridge on the particular motherboard I'm working on. My path of concluding that:
              - There's no sign of any attempt to power on when pushing the power button.
              - No PSON signal is reaching the 24-pin ATX connector.
              - The Super IO chip is receiving the PS_SWITCH signal from the power button and is relaying this signal back to the South Bridge.
              - The Super IO is not receiving the S_SLPS#_R signal back from the South Bridge
              - If I pull the Super IO S_SLPS#_R pin...
              04-16-2024, 09:36 AM
            • harp
              Metod for removing glued heatsink from fragile component
              by harp
              I have peltir element glued to heatsink with something thick and sticky like putty... it cant be separate with force or heat without risk of breaking ceramic or damaged semiconductor layers due to force (eg if try twisted, pulled, lifted)... method that I am using is a single thread for needle (thin and firm thread of pure polyester that cant break with bare hands without glowes), and using it like a saw between heatsink and peltir. I holding a heatsink with knee against table. It slowly cut throug putty and release glued parts. It is slow proces, but preserve undamaged component and heatsink....
              06-23-2025, 02:01 PM
            • Ven
              Seeking Advice on Enhancing Heatsink for Main Processor on SAMSUNG TV Motherboard
              by Ven
              I'm looking to upgrade the heatsink on the main processor of my TV's motherboard for better cooling performance.
              The current heatsink is a square-shaped one (2.8cm x 2.8cn) with a basic design, and I believe a more efficient heatsink could help with thermal management and potentially extend the life of the TV.
              I'd appreciate any advice on the best type of heatsink to use, specific product recommendations, and tips for installation.
              If you've done a similar upgrade, I'd love to hear about your experience and any challenges you...
              07-08-2024, 09:32 AM
            • Roman555
              Asus H77 LGA1155 mainboard stopped working with Ivy Bridge CPUs
              by Roman555
              Bad symptoms when Ivy Bridge CPU (3rd-gen 22nm) is installed:
              • Won't boot OS (just blank screen or stucks at asus logo, monitor is turned on) with hangs at debug (post) code A3;
              • USB stick with MS-DOS can be loaded via F8 boot menu;
              • Other OSes won't load - hangs or goes reboot;
              • Postponed for several seconds reaction to Alt-Ctrl-Del, Reset and Power buttons;
              • An operating system starts loading but won't finish if it's left only 1 CPU core in BIOS settings;
              What I've already done and it hasn't helped:
              • Cleared CMOS many times;
              • Flashed different versions of BIOS in a CH341 programmer;
              • Updated
              01-18-2024, 06:26 AM
            • Byte_76
              Gainward GTX 295 SLI Bridge
              by Byte_76
              I have a Gainward GTX 295 with two PCB's which has a broken SLI bridge ribbon cable. As a result, the card is entirely useless and I'd really like to fix it if possible.
              I've searched eBay and AlieExpress but haven't been able to find the part.
              I believe this same SLI bridge cable is used on the Nvidia 9800 GX2 and the GTX 295 which both have two PCB's.
              Can anyone help me on where to get a replacement SLI bridge cable please?
              05-10-2024, 03:07 AM
