Diagnosing South Bridge (FH82H370) on Asus H370-Pro Gaming Motherboard
  • Ross Kohler
    • 14
    • South Africa
    I'm learning about motherboard repair and I believe I've traced the issue down for the South Bridge on the particular motherboard I'm working on. My path of concluding that:
    - There's no sign of any attempt to power on when pushing the power button.
    - No PSON signal is reaching the 24-pin ATX connector.
    - The Super IO chip is receiving the PS_SWITCH signal from the power button and is relaying this signal back to the South Bridge.
    - The Super IO is not receiving the S_SLPS#_R signal back from the South Bridge
    - If I pull the Super IO S_SLPS#_R pin high, the power supply turns on suggesting that the Super IO chip is working fine.
    - The capacitors around the South Bridge all seem to be fine and all have voltages that look reasonable (1,8V, 3.3V and 1V).
    At this point, I've run out of ideas on what to test. I would like to dive deeper into figuring out how the South Bridge works and what I should be expecting in it's proper operation but I can't find a data sheet for it. I'm leaning towards concluding that the South Bridge died but that seems like a lazy conclusion unless I can find hard evidence of it. Can someone help me in figuring out what else I could look at?
    This post here goes into some more detail about what I've been looking at and someone was nice enough to share a board view to help me.
    Any help would be greatly appreciated!
  • прямо
    • Sep 2022
    • 261
    • Indonesia
    Not surprised at all if the PCH is dead. Asus boards seem to always have a problem with overheating PCH. Got a couple Asus boards here that have heatsinks on the PCH, but when they are running, I can't even touch them with my finger.
    • piernov
      • Jan 2016
      • 4439
      • France
      300-series chipset datasheet is available but it doesn't help that much, the relevant info is left out.
      First need to check power rails, depends on the board but should have a 3V RTC rail, a 3V standby rail and a 1V standby/main rail going to the PCH at least.
      Then some signals, in particular the RTCRST#, SRTCRST# and RSMRST# signals (input to the PCH) and SLP_SUS# (output from the PCH).
      The 32 kHz RTC clock should also be present.
      Finally need to confirm if SLP_S4# is completely missing or at least pulsing.
      • Ross Kohler
        • 14
        • South Africa
        I'm nearing this conclusion. The one thing that gives me hope is that the PCH doesn't get hot while it's plugged in to the ATX. Even if I force the ATX on, it doesn't get hot. Does this happen? The PCH dies without a short circuit through it?
        If I touch the PCH I do think I can feel some warmth, but it's difficult to tell for sure.
        • Ross Kohler
          • 14
          • South Africa
          piernov voltage rails look good. I've measured 1.8, 3.3 and 1.05V all around the PCH on the capacitors on top of the chip. I'll check these other signals. Thanks for the tips.
          • DynaxSC
            • Apr 2021
            • 477
            • Poland
            Hi, PCH's have generally two types of failures: 1. short on any or all of the power supply lines - this is easy to diagnose, 2. functinality failures due to errors in the silicon structure - they lead to fatal failures (no boot, no start) or strange behavior of the chipset/board during boot and operation if any possible. I would estimate first failures type is 70%, type 2 is 30% approximately. The type 2 is much more difficult to diagnose, and can be finally confirmed only by replacing the chipset. Some things can be tested however, eg. If pch is reading the bios on Power Button push (scope eg. on pin 2 of the bios), clocks present on the cristal (scope with probe x10 to have low parasitic capacity), eg. voltages present on the cristal pins (0,2 - 0,4V). The supply voltage for the chipsets are usually higher than nominal, if the voltage exceeds too much the nominal, if often leads to overheating of the chipsets, and reducing of their life span. This can happen due to aging of the vrms and eg. changes in the reference voltages generated by the vrm chips, or due to bad resistances of the resistors used in divider network defining the output voltage of the vrms. I have often seen much too high supply voltages for chipsets on board, eg. 3.45V instead of 3,30V. This is enough to stress the pch and reduce the chip life span significantly, leading to failures. It seems to me that mobo vendors to not care about this issue deliberately. Another issue is that the chip quality of intel chipsets seems to be much worse than that of processors, as chipsets fail much more often than processors, which usually do not fail, if not something special happens to them.
            Chipsets have also some internal vrm generating 1,2V most probably during operation only, the voltage is connected to an external cap for stabilisation, this vrm may also fail, leading to non functioning chipset, dont remember the pin/signal name now.
            Also the DMI bus to the CPU can be checked in the CPU socket (use reverse diode mode, voltages should be 0,2-0,4V). This is tricky, socket pins can be bent easily).
            Normal operating temperature of chipset silicon without a heatsink should be 50-55 degree Celsius. If it is higher this is also an indication for internal chipset failure.
            Resistance on the 1,05V power line should be some 25-70 ohms (chip must have room temperature, resistance lowers significantly with rising silicon temperature), if lower the chipset is also suspect to internal failure. The other lines should be in single kohm range.
            • DynaxSC
              • Apr 2021
              • 477
              • Poland
              Btw, check also if the bios image is correct, seen many board with corrupted bios image, not booting, or even not starting the board. Backup first the image, and then write a stock image to the bios - you need a hw programmer, eg. CH-341 (must be modded before used to not destroy 3,3V bios chips, as it has a design flaw already leaving factory - instructions to be googled). The backup is important, as each bios has some personalisation data for each particular board, eg. UUID, serial no or MAC LAN address. This data is not present in the stock image, and if bios is corrupted must be transferred to the stock bios manually (DMI data section, and network data section in Bios). Usually bios can be programmed in-circuit with a special clip (board must be disconnected from ATX power). On some boards however its not possible to program the bios in-circuit, so then it must be desoldered for programming.
              And a tip, do not force power to the mobo by Atx pin shorting. This has no value for diagnosis (no board will start correctly that way) and can destroy some mobos - speaking from my own experience.
              • DynaxSC
                • Apr 2021
                • 477
                • Poland
                Checked again, and the 1.2V generated by the PCH is called VCCDPHY_1P24 (Gigabyte boardview naming) - so its 1.24V exactly, I believe this has something to do with the clock generation on the PCH, but I'm not fully sure.
                Regarding the sections in the BIOS I wrote about, they are called exatly "GbE region" (LAN MAC Adres is usually stored here) and what I called DMI section, is correctly "NVRAM" section located in the BIOS region.
                And another hint, the most important signal from the PCH starting the whole power sequence is SLP_S3# (or N-SLP_S3 on Gigabyte boardviews). PCH should activate this signal on pressing the Power Button, where the Power Button signal is relayed usually by the SIO to the PCH only when SIO is in correct state, eg. the monitored stand-by voltages are present (VIN inputs).
                • MakNCheese
                  ASUS Zephyrus GA401I Severe Lag, Suspect Motherboard/Power Issue - Need Help Diagnosing
                  by MakNCheese
                  I'm having a serious issue with my ASUS Zephyrus GA401I (4 years old, worked perfectly until recently). The system is lagging heavily, even in the BIOS, and is charging extremely slowly (a few percent in hours), making it nearly unusable. I suspect a motherboard or power delivery issue.
                  Symptoms:
                  • Severe lag across the system, including BIOS navigation.
                  • Slow boot times and unresponsive performance in Windows.
                  • Battery charges very slowly (e.g., ~5% in 2–3 hours).
                  • No error messages or BSODs, just extreme sluggishness.
                  What I've Tried:
                  • Replaced
                  06-04-2025, 12:48 AM
                • glovecaps
                  Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                  by glovecaps
                  I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                  My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                  The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                  11-25-2024, 04:23 PM
                • dhenion
                  Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
                  by dhenion
                  I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
                  The original board was:
                  ASUS X510UNR REV 3.0 A
                  The replacement board is:
                  ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
                  It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
                  01-30-2024, 01:45 PM
                • Allgone
                  Help diagnosing laptop ASUS X556UJ_MB REV 2.0 motherboard
                  by Allgone
                  Hello everyone, I have this Asus model X556UA that when plugged in I get the white light but nothing happens when pressing the power button. I've been looking into it following the power sequence and found out that the power button is sending the signal to the EC (PWR_SW#) but the EC is not sending the PM_PWRBTN# to the PCH (it always stays at 3.3V). I'm stuck here and don't know what else can I do, maybe I can get some help. I've seen that this could mean that the PCH is dead but I don't know how I can confirm this. Also this may not be important but when plugged in, the PCH/CPU (they go together...
                  05-14-2024, 02:10 PM
                • pkslowk
                  Debug Card Error Code and Solution
                  by pkslowk
                  Sr. Motherboard Debug Error Code Solution
                  1 Intel 845 E9 Bios Related Problem
                  2 Intel 845 D4 CPU Socket Related problem
                  3 Intel 845 37 Bios Related Problem
                  4 Intel 845 7C Bios Related Problem
                  5 Intel 945GCPE 34 Bios Related Problem
                  6 Gigabyte 845 2 Ram Related Problem
                  7 IBM Server A6 A7 Ram Mismatch Problem
                  8 Asus 845 29 CPU Related Problem
                  9 Lenovo I946 97 C-Mos Jumper related
                  10 Gigabyte 845 A0 CPU Related Problem
                  11 Asrock G31M-VS D7 Bios Related Problem
                  12 Compaq 845 BD-70G B0 CPU Socket Related problem...
                  01-28-2021, 12:51 PM
