IBM NetVista Hard Drive Rails
  • shadow
    • Feb 2007
    • 732
    I recently got an IBM NetVista for a very good price, however it did not include the hard drive. I thought that I would just pop in any IDE hard drive and I would be away.
    Unfortunately the hard drive can not be screwed in directly to the chassis of the case because it is designed to use a proprietary hard drive rail. The required rails are shown in the picture below.
    These rails are not easy to come by in Australia (it seems). I have seen them on EBay in the UK and the US. However these rails would probably cost me just as much as the whole system!
    I was wondering whether anyone has any ideas on making a custom homemade hard drive rails?
    I was thinking about making a pair of timber rails that i could then screw to the systems chassis. Would there be any disadvantages with this idea?
    I will have to hunt around in the garage and see what aluminium sections I can find. Maybe I could use am aluminium section as a rail with minimal modification.
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: IBM NetVista Hard Drive Rails
    A strip of plastic with recessed holes for the plastic to drive screw heads.
    [Use pointed screws from chassis into plastic.]
    A strip of wood used the same way.
    Small piece of aluminum angle iron.
    Mann-Made Global Warming.
    - Dr Seuss
    • linuxguru
      • Apr 2005
      • 1564
      These rails aren't very different from the older black plastic rails used on the IBM PC, PC/AT and some PS/2 systems. Look around, there should be lots of it in PC scrapyards which you can get for pennies and then modify slightly if necessary with a Dremel or in the old-fashioned way with a file, hacksaw and drill.
      • stevo1210
        • Oct 2006
        • 4156
        I have similar rails in my IBM Netvista 8309-16A. It looks like you could make wooden rails, then just push it in and sticky tape it at the end so it doesn't fall out.
        Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
        • KeriJane
          Mac Enthusiast
          • Sep 2008
          • 681
          Hi Shadow
          Antec has used similar drive rails in a lot of their cases. I still have some around, so if you could say what the dimensions are, I could check against mine.
          Antec usually sell spare ones on their site for a modest fee, but they don't state the dimensions.
          Good Luck,
          Keri
          The More You Learn The Less You Know!
          • NxB
            • Feb 2009
            • 1595
            Similar drive rails in my case. Also similar drive rails in dell cases I have seen, also others. Look on ebay for hard drive rails in general and see which ones look the same.
            • pentium
              • Mar 2006
              • 2778
              Duct tape works here. I did it before with one of these cases.
              Find Nedry!
              Check the Vending machines!!
              <----Computer says I need more beer.
              • shadow
                • Feb 2007
                • 732
                Just an update.
                I ended up making a set of compatible rails out of an off cut piece of hardwood.
                Pictures should come up tomorrow!
                • shadow
                  • Feb 2007
                  • 732
                  Sorry I didn't post the pics like I said I would.
                  I forgot about it and the rails already live in their homes.
                  • federalhouse
                    **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                    by federalhouse
                    I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                    **Background:**
                    I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                    **What I've Tried So Far:**
                    1. I accessed
                    08-01-2024, 07:03 PM
                  • tmcw
                    PC case - Hard drive rails
                    by tmcw
                    A friend gave me his old PC case (with MB, and PSU), but no hard drive rails, he said he only used the 2.5" SSD spot inside, and used an external hard drive for data. He said that he'd have a look for the supplied rails, but I doubt he'll find them.
                    So I was wondering if case manufacturers used any type of standard 3.5" hard drive rail?
                    I'm used to the various Dell hard drive caddies or rails (and HP and Lenovo to a lesser extent), or el cheapo cases where you screw through the frame to fix the drive.
                    Now, the case is a CiT Gaming Case, and...
                    05-22-2022, 12:04 PM
                  • madura2010
                    DAY11AM6E0 hard disk drive and optical disk drive not detected
                    by madura2010
                    Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                    i checked the connectivity of ribbon=good communication with hard and motherboard
                    changed hard disk and checked=3f0 error persist
                    sata power=+5v available
                    Then checked data capacitors=all good
                    Then checked data lines path connectivity to pch=all good
                    reflashed...
                    03-12-2023, 09:09 AM
                  • ash91
                    Hp pavilion 15 not detect hard drive
                    by ash91
                    Hello gentelmen .... this is my first post and sorry for my bad english,
                    so my proplem is my laptop keep losing hard drive even if i but the
                    hard disk in the cady (the box that can replace the dvd rom with hard disk)
                    when i turn the laptop on the massage that said no boot media found pop on
                    the hard disk is fine and to be sure i try another hard
                    i also update my bios to the last update
                    the 5 volt is present on the hard connector on the motherboard
                    the dvd rom work fine when i but a windows dvd in it
                    also when i boot from flash...
                    06-07-2023, 01:45 PM
                  • karto95
                    Repairing a Seagate hard drive with damaged logic board
                    by karto95
                    I'm currently facing an issue with my Seagate hard drive that has a damaged logic board. I've obtained a replacement logic board from a donor hard drive, but unfortunately, I'm unable to recover the BIOS of the original board due to damaged firmware. I'm wondering if it's possible to make the hard drive work with this donor logic board.
                    I have a CH341A programmer, so I'm hoping that it can be useful in this situation. I've attached the BIOS file .bin of the donor board for reference.
                    If anyone has any suggestions or experience with this...
                    03-21-2023, 04:05 AM
