IBM NetVista Hard Drive Rails
  • shadow
    • Feb 2007
    • 732
    I recently got an IBM NetVista for a very good price, however it did not include the hard drive. I thought that I would just pop in any IDE hard drive and I would be away.
    Unfortunately the hard drive can not be screwed in directly to the chassis of the case because it is designed to use a proprietary hard drive rail. The required rails are shown in the picture below.
    These rails are not easy to come by in Australia (it seems). I have seen them on EBay in the UK and the US. However these rails would probably cost me just as much as the whole system!
    I was wondering whether anyone has any ideas on making a custom homemade hard drive rails?
    I was thinking about making a pair of timber rails that i could then screw to the systems chassis. Would there be any disadvantages with this idea?
    I will have to hunt around in the garage and see what aluminium sections I can find. Maybe I could use am aluminium section as a rail with minimal modification.
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: IBM NetVista Hard Drive Rails
    A strip of plastic with recessed holes for the plastic to drive screw heads.
    [Use pointed screws from chassis into plastic.]
    A strip of wood used the same way.
    Small piece of aluminum angle iron.
    Mann-Made Global Warming.
    - Dr Seuss
    • linuxguru
      • Apr 2005
      • 1564
      These rails aren't very different from the older black plastic rails used on the IBM PC, PC/AT and some PS/2 systems. Look around, there should be lots of it in PC scrapyards which you can get for pennies and then modify slightly if necessary with a Dremel or in the old-fashioned way with a file, hacksaw and drill.
      • stevo1210
        • Oct 2006
        • 4156
        I have similar rails in my IBM Netvista 8309-16A. It looks like you could make wooden rails, then just push it in and sticky tape it at the end so it doesn't fall out.
        • KeriJane
          Mac Enthusiast
          • Sep 2008
          • 681
          Hi Shadow
          Antec has used similar drive rails in a lot of their cases. I still have some around, so if you could say what the dimensions are, I could check against mine.
          Antec usually sell spare ones on their site for a modest fee, but they don't state the dimensions.
          Good Luck,
          Keri
          The More You Learn The Less You Know!
          • NxB
            • Feb 2009
            • 1595
            Similar drive rails in my case. Also similar drive rails in dell cases I have seen, also others. Look on ebay for hard drive rails in general and see which ones look the same.
            • pentium
              • Mar 2006
              • 2778
              Duct tape works here. I did it before with one of these cases.
              Find Nedry!
              Check the Vending machines!!
              • shadow
                • Feb 2007
                • 732
                Just an update.
                I ended up making a set of compatible rails out of an off cut piece of hardwood.
                Pictures should come up tomorrow!
                • shadow
                  • Feb 2007
                  • 732
                  Sorry I didn't post the pics like I said I would.
                  I forgot about it and the rails already live in their homes.
