Samsung hard drives...
  • acstech
    GrumpyModerator
    • Jul 2007
    • 1432
    Re: Samsung hard drives...
    An update to my original post:
    I used a jumper to limit the offending drives to SATA 150. The errors on those drives went away, and they are functioning normally again. I would still prefer that they functioned at full speed, but it's not noticeable anyway.
    Just a few days ago someone else had an OEM Samsung drive (not the Spinpoint) with the same error. Apply jumper to limit to SATA 150, and problem goes away. Didn't even need to take the computer back with me.
    Apparently some of their controllers have problems with operating at SATA 300.
    A man convinced against his will is of the same opinion still.
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      • PC's, The Experts Exchange (same name there), Gardening, Hot Rods.
      Originally posted by i4004
      >hmm.. i only know about some problems on the WD RAID Edition 2 (RE2)
      they had a lot of DOAs or had 80% bad sectors directly after unboxing..
      exactly the opposite of pcbonez' experience mentioned here
      https://www.badcaps.net/forum/showth...=re2#post60899
      Yes but quantitatively I have only have 3 RE2 and somewhere between 20 and 30 RE. So far I only use the RE2 for non-critical temp stuff like recoding TV shows because I don't trust PMR yet. Using the RE2 is more or less a test.
      If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
      Subscribe to support us. It only takes 1 minute:
      https://www.badcaps.net/settings/subscriptions
      • acstech
        GrumpyModerator
        • Jul 2007
        • 1432
        Samsung hard drives are like playing with snakes; sooner or later, you're going to get bit!
        One of the ones with the transfer rate set down failed. Same controller error bulls***. I've got a 250GB WD RE1 on the way for replacement.
        Anyone have experience with the new Hitachi Deathstars, er, Deskstars?
        • Fatal0E
          • Jan 2004
          • 252
          That sucks you are having such bad luck with them. I look to Samsung for all my personal work. My boss buys what ever is cheap, usually WD or Seagate. We have been having much better luck with the WD drives over the Seagates. The last Samsung drive I had fail was I think a 60gb many moons ago.
          • NxB
            • Feb 2009
            • 1595
            I buy mostly WDs. Only one has ever catastrophically failed on me. I RMA'd it. I've seen a high failure rate on samsung drives too, the 160s and 250s. Its usually with people who have a dust colony living in their computer. A lot more logic board failures than platter failures though.
            • Junk Parts
              Court Jester
              • Jun 2006
              • 8953
              • Cars, Computers
              #26
              The only SamSung drives that I ever had were old, I mean old! These drives were in the mega bit sizes, not gigs. They got put in the bin without any failures simply because they were too small, and too slow for any modern PC.
              I bought a 586 class PC with a few Fujitzu 10 drives in it, and I was in a whole nother world of "speed!" All the Fujits died at about three years old.
              Now being that those drives at the time were expensive I started using older but larger used WD drives. Many of these were very noisy but they worked ok. They were not near as fast as the Fujits but faithful if you know what I mean. This is up until one night when I lost 3 months of Union co-pay records that belonged to my union local hall. Yes I backup, and save all the time. Fact is that the files ended up being saved in some unreadable area of a "good" quiet drive with S.M.A.R.T. turned on. Luck for me that all these file were mirrowed at the Hall. I switched to Maxtor! I think I bought maybe five of these before I figured out that they were bad drugs! I switched back to WD maybe four years ago and have not had a single dive failure in our home PC's since. No they are not the fastest, but they work, and seem to keep working.
              • NxB
                • Feb 2009
                • 1595
                #27
                The wd caviar 3-6gbs can be thrown against a wall and still work, lol.
                • KeriJane
                  Mac Enthusiast
                  • Sep 2008
                  • 681
                  • Trabant Comrade
                  #28
                  Hello.
                  I've had lots of good luck here with most hard drives. I attribute my good fortune to using decent-quality PSUs.
                  I haven't seen any Samsung failures, even when a Fuhjyyu'd TruePower took out a motherboard and a Hitachi hard drive.... the Samsung drive managed to survive.
                  I mostly use modern Deathstars with only the one Antec-inspired failure. They have a great AAC that can be set to make them virtually silent.
                  I also use a lot of WD even though I had to replace a newer one in a VAIO desktop that seized and would not spin up. Right now I have 2 GreenPower 1TBs in a RAID enclosure and a Black Caviar as my MacOS drive. All work flawlessly.
                  The few Maxtors and Seagates I've come across don't impress me. Too hot and too noisy. No actual failures though.
                  Have Fun!
                  Keri
                  The More You Learn The Less You Know!
                  • acstech
                    GrumpyModerator
                    • Jul 2007
                    • 1432
                    The failures don't show up right away. Sometimes they take over a year to show up, but usually it's right around a year.
                    If you have a computer with a reasonably new SATA Samsung hard drive handy, do me a favor. Go look in the event viewer. In XP, it's under the control panel, administrative tools, event viewer. Then look under system. Tell me if you see any events with the id 9,11, or 51. If you do, then you have a problem, even though things might seem to be working fine.
                    • bgavin
                      • Jan 2007
                      • 1355
                      • Subwoofer engineering/building, wedding photography, electric bass, Hammond keys, 5-string banjo
                      #30
                      Every Samsung drive I have removed from a client system is a dead Samsung drive.
                      I wouldn't buy a Samsung on a bet.
                      No Maxtors.
                      No Fujitsus.
                      No Seagates until they get their quality problems back under control.
                      • Scenic
                        o.O
                        • Sep 2007
                        • 2642
                        Originally posted by Scenic
                        nope.. bought those from 3 different shops (2x one HDD, 1x 2 HDDs).
                        all of them were new bulk HDDs (sealed in that WD labeled antistatic bag with those small silica gel bags inside).
                        i had problems with 4 drives out of 6 (all WD RE2 HDDs)
                        2 worked fine from day 1 (and they seem to still do.. no complaints from customers yet), the other ones were DOA (no spinup) or had tons of bad sectors. replacement HDDs for those drives (RMA) worked fine without problems..
                        i'll take that as bad luck.. maybe shipping (DHL is known _not_ to be careful with some packets sometimes..) or maybe i got some monday-HDDs or something..!? i don't know..
                        all other HDDs i bought from those shops worked fine since day 1 ..so i don't think those shops are to blame for that..
                        anyways.. both shops don't have RE2's in stock anymore... only RE3's..
                        edit: okay.. one of those shops still has a RE2 in stock, but only a 160GB one.. all others are RE3's ..
                        i was searching for something else on my HDD today and i've found the screenshots i made back then (just before i RMA'd it)
                        and this link here (online analysis of SMART values read out by speedfan)
                        http://www.hddstatus.com/hdrepshowre...ation=F47E08A1
                        left HDTune running overnight... every block after those pictured above was red (=bad)... and it still wasn't done checking the whole HDD after 12hours lol
                        and BTW: this "(Keine Rückmeldung)" in the title bar means that windows thought HDTune wasnt reacting anymore (crashed).. 100% CPU load all the time..
                        edit:
                        quote from that online analysis..
                        NOTE : your hard disk has 1365 reallocated sectors
                        OMG
                        The overall fitness for this drive is 0%. The overall performance for this drive is 96%.
                        OMG OMG
                        • kc8adu
                          • Nov 2003
                          • 8832
                          • U.S.A!
                          #32
                          you own a paperweight.rma if possible
                          edit:
                          OMG
                          OMG OMG
                          • c_hegge
                            • Sep 2009
                            • 5221
                            Most of the samsung HDDs I come accross in computers develop bad sectors after a few years. That is why I prefer Seagate and WD. I'm not a big fan of Hitachi or Maxtor either.
                            • RJARRRPCGP
                              • Jul 2004
                              • 6304
                              No such problem with a Samsung HD320KJ I have, from 2007.
                              Thus, it looks like a problem with your IDE (also SATA) cable or controller.
                              ASRock B550 PG Velocita
                              Ryzen 9 "Vermeer" 5900X
                              Arc A770 16 GB
                              eVGA Supernova G3 750W
                              Alienware AW3423DWF OLED
                              • acstech
                                GrumpyModerator
                                • Jul 2007
                                • 1432
                                Really! I've seen the problem across Nvidia and Intel chipsets, with differing cables. Sorry, the drive is at fault.
                                You're just lucky. I sell these things (in computers), I would suggest that my sample size may be a bit larger than the average person.
                                I do still have a couple out there that are working properly. Like I said, luck.
                                • Boardview and Schematic Bot
                                  09-07-2024, 05:50 AM
                                  09-06-2024, 11:40 PM
                                  09-06-2024, 08:40 PM
                                  Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                                  This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                  09-06-2024, 06:20 PM
