Ratdude's Main Rig V6
  • diif
    • Feb 2014
    • 6978
    • England
    #61
    Re: Ratdude's Main Rig V6
    I did read of people BIOS modding the liscenses in... but that screams trouble. I've already fought the BIOS gods and lost on this board, and I don't quite have the cojones to go there, especially since it's not a well documented mod and I'm not an x86 assembly expert.
    If it ain't fucked, don't fix it and post #15 suggests ; the unlucky fairies come to play quite often/the devil makes work for idle hands.
    I've only known one person with an SLI installation. I don't remember the cards but there was lots of faff getting it set right and the gains weren't great.
    • RJARRRPCGP
      • Jul 2004
      • 6304
      Originally posted by Topcat
      I wouldn't say that....more along the lines of what diif said... They aren't targeting the gamer crowd, and hence, not a lot of demand for SLI support amongst their target audience. I was only doing it to tinker around....I had no intention of actually using that system for anything gaming and/or productive.
      It was the directory the X58 drivers are in on their web site, LOL
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        For a variety of reasons, I moved this system to windows 10 tonight.
        Good news:
        -Activation worked out.
        -Most things work out of the box.
        -Once I installed classic shell and reconfigured some things, it seems to be OK to use.
        Bad news:
        -Intel network teaming is not supported. Not that I was really gaining anything from using such. Bummer though.
        If this works I may do the same with my other systems new enough to be compatible... I remembered what happened when XP lost support... at least for me stuff seemed to get infected a bunch all of the sudden (don't know why, I don't go to BS sites or the like). Hence why I migrated to W7 at that point.
        sigpic
        (Insert witty quote here)
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          While working on another build, I've discovered an issue:
          https://www.badcaps.net/forum/showthread.php?p=955091
          The issue is my GPU is lagging/bottlnecking like a SOB. I've played musical GPUs, and the issue is the system, not the GPUs.
          In novabench, I should be getting around 60FPS... I'm getting around 13-15. consistently.
          Also, I'm having intermittent keyboard lag, but I suspect that might be a logitech unifying issue. I might swap the keyboard and mouse for wired units as a test to see if anything changes.
          sigpic
          • diif
            • Feb 2014
            • 6978
            • England
            #65
            Possibly a chipset driver issue.
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              ...and Intel has none listed for windows 10, nor does SM. It uses dual Intel 5520 chipsets. Windows is using default drivers dated to 2006.
              However, I did some digging and apparently the windows 7 drivers are also marked for windows 8 and 8.1... and successfully installed.
              Rebooting, will try again.
              sigpic
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                Nope, no change in FPS.
                Might need to scour the BIOS settings... this is lame.
                sigpic
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  Windows, since Vista, usually shows 2006, even Windows 10, for Vista's sake! LOL!
                  Arc A770 16 GB
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    #69
                    No, it is not for Vistas sake: it is so that if you have a third party driver it will be newer than the Windows in-box driver.
                    And so Windows should not try to overwrite it with the in-box driver.
                    P.S: This worked fine up until the train-wreck known as Windows 10.
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      I think the issue is Novabench, not the system.
                      Ran catzilla, and got a very good score:
                      I've been getting scores in the 11000-13000 range on my other GTX970 based systems... this one is the fastest, and the benchmark shows it.
                      Go figure.
                      sigpic
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        I've done bricked her again... in a vain attempt to try get some less obnoxious fan curves, I decided to update the BIOS (which was already updated! )... and also the CPU microcode. BAD idea to do on the same boot... corrupted the BIOS checksum per hooking up over a null serial cable.
                        Sadly, all it's doing is giving that message with no way to tell it to shut up and take a new file.
                        Somewhere I probably have the new chip I bought several years ago... maybe. It's been a long time...
                        Alternatively, I'm keeping my eyes open for an X9DAX series board. They're EEATX like the X8DAH I have now, and will do LGA2011 V2 CPUs (Ivy bridge). In theory my RAM would move over (would need to get two more modules to make the channels line up), and possibly my dynatron coolers as well (supposedly LGA2011 uses the same setup, only with an integrated backplate). Now If I can catch a board for less than $170 (the current common price for the cheapest variant on eBay).
                        sigpic
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          Actually, if anything, I'd want to go for an X9DAE. Sure, it wouldn't fill my case, but the CPU layout matches my air duct a lot better, and according to SM it supports SLI!... the latter is what sets it apart from the X9DAI and X9DA7 workstation boards
                          Oh the trouble I could get myself into... Although if anything, that would be an upgrade for my wife's dual opteron (2000 series) which is already SLI'd. Right now the boards are unobtainium (other than the $600+ scab sellers).
                          Back to fixing what I got...
                          sigpic
                          • Topcat
                            The Boss Stooge
                            • Oct 2003
                            • 16959
                            is SLI really even a 'thing' anymore? I rarely see people doing it now.
                            <--- Badcaps.net Founder
                            Badcaps.net Services:
                            Motherboard Repair Services
                            http://folding.stanford.edu/
                            Team : 49813
                            Join in!!
                            Team Stats
                            • Uranium-235
                              Comrade Glimmer
                              • Aug 2007
                              • 5045
                              • US
                              #74
                              It's not worth the $$ for only a ~1.2-1.5 increase in performance. I've heard some games have issues with it, or just run worse
                              • ratdude747
                                Black Sheep
                                • Nov 2008
                                • 17136
                                Ran fine on WoW when my wife runs it on her SLI setup (dual GTX 970's).
                                Also, y'all know me... some of these things are more in the category of "because I can" and less "because I should".
                                She's fixed. Serial trick again. Forgot that I have to connect as soon as it powers up and answer the prompts very, very quickly.
                                Why am I such a freaking IDIOT?
                                sigpic
                                • Topcat
                                  The Boss Stooge
                                  • Oct 2003
                                  • 16959
                                  Glad she's going again!
                                  ...and I do understand the "I know it's not practical, but I'm doing it just for the hell of it" mentality. I'm a charter member of that club!
                                  Team : 49813
                                  Join in!!
                                  Team Stats
                                    master hoarder
                                    • May 2008
                                    • 12175
                                    #77
                                    That's if you're lucky.
                                    Most games these days don't even optimize for SLI anymore or any multi-GPU setup.
                                    In other words, SLI is... dead, Jim!
                                    Indeed. Have to check carefully each game you want to play and see how it does - that means not only average framerates, but also frametimes. There are games out there that will pump out really high average FPS, but the low FPS dips and frametimes can be full of spikes, which can make the performance choppy. And SLI can actually make that worse in some of them.
                                    WoW, from what I know, is a fairly-well optimized game... and not to mention quite old, so of course it's going to run on that 970. Question is, are there any benefits from the SLI or not. I would try it with one card and then SLI and compare FPS and frametimes, as mentioned above (MSI Afterburner is a good tool for that... though Fraps will still do in a pinch.)
                                    If not getting any benefits, you're just burning extra power and heating up components more in the system, potentially decreasing their useful life... not to mention paying extra for electricity.
                                    But I get ya... you just like building systems in a certain way, and that's the way it is. On that note, the most impractical system I ever built was a few years back when I used to work at MC - had a guy buy a bunch of hardware and ask to assemble it for him. System had a top-shelf (back then) 2011 gaming board, most expensive CPU that could fit said board, maxed out RAM, and 2x GTX 1080 TI is SLI (and these had just come out a few months prior, so they were expensive as heck and hard to get too!) But then he brought his older PC and asked if I could just transfer the HDD from that into the new system with the working Windows 10 and all. I was like and told him it probably wouldn't work, but he still wanted me to try. So I did and... it actually worked - at least Windows 10 booted to desktop OK... which is all he wanted me to do (he said he would install the drivers himself and whatnot.) I asked him why not at least clone the old HDD (an older mechanical spinner) to a new SSD and get some speed increase while at it. He said this was his desktop PC he uses for surfing and office work. Me:
                                    Clearly, that build was a case of I want the PC built this way, because I want to burn some money rather than doing something that made sense for his application. He was a very vocal guy too, so I didn't ask that many questions afterwards. Customer is always right, after all, right?
                                    That's always good to hear.
                                    Well... until next time, at least.
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      I know it's not a game, but I did several Catzilla benchmarks... from that system's thread (which I never posted the finished build, apparently???):
                                      Was finally able to run catzilla…
                                      Single GPU system (the mismatched evga gtx 970 SSC) for comparison (dual low voltage xeon hapertowns):
                                      SLI is indeed working... almost double in the gpu parameters. Yay?
                                      That wasn't on the final setup either. Running off a single clay pigeon HDD... among other things optimized later. But the GPU scores were doubled, which indicates that SLI was making a substantial difference, at least in that case.
                                      As far as I'm concerned, as long as Nvidia and OEMs supports it, it can't be dead... practicality aside.
                                      sigpic
                                      • ChaosLegionnaire
                                        HC Overclocker
                                        • Jul 2012
                                        • 3266
                                        • Singapore
                                        #79
                                        probably he is thinking that the most powerful computer will last a long time before needing an upgrade, so it could be that he likes holding on to a system for as long as possible before upgrading because its too slow.
                                        however, the problem with that logic nowadays is that modern junk doesnt last, so the mobo, video card or psu will fail in a few years, so that puts a spanner in the works of what he's trying to do...
                                        thats why i get all my stuff used and second hand now. aint paying top dollar for junk that doesnt ever last long. besides being kinder on my wallet, getting used stuff also helps to reduce e-waste and is good for the environment.
                                        next, regarding multi-gpu systems, i also have to agree with ratdude that they arent dead because multi-gpu gaming systems can now be re-purposed to mine cryptocurrency. with the price of bitcoin hitting 50 grand, its getting more lucrative to mine cryptocurrency again.
                                        Last edited by ChaosLegionnaire; 03-28-2021, 09:42 PM. Reason: added multi-gpu comments.
                                        • ratdude747
                                          Black Sheep
                                          • Nov 2008
                                          • 17136
                                          For the record, I just catzilla'd it in it's final form:
                                          A bit better... not as good as this thread's actual system (per a prior post) but the GPU scores are what made it worth building. For games that are more GPU intensive this isn't a bad setup... which WOW certainly isn't. Dunno. It ran well and I happened to have half the hardware sitting (and I needed another win10 capable workstation anyway)... but that's for that system's thread; I need to figure out where my pics went (or why I never posted them)...
                                          sigpic
                                          • cheeky2
                                            by cheeky2
                                            05-25-2024, 03:27 AM
                                          • Dani_2024
                                            by Dani_2024
                                            10-28-2024, 05:06 PM
                                          • ygorsan
                                            by ygorsan
                                            🧩 Problem Summary:
                                            • I
                                            07-28-2025, 08:34 AM
                                          • Asraf Atb
                                            Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                                            by Asraf Atb
                                            Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                                            Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                                            I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                                            01-27-2025, 05:02 PM
                                          • Genghis_Khan
                                            ThinkPad T470p – CMOS Checksum Error Persists After Main Battery Removal (even with new CMOS)
                                            by Genghis_Khan
                                            I’m currently troubleshooting an issue on my Lenovo ThinkPad T470p (Type 20J6) and would really appreciate any insights or solutions.
                                            Issue summary:
                                            Whenever I remove the main laptop battery and AC adaptor, then place them back, the system gives a “CMOS checksum error” at next boot, and the BIOS clock resets to its default time/date.
                                            However, the RTC works fine as long as the main battery remains attached — even if the laptop is unplugged for hours. Same as I remove the battery while the AC is attached, RTC remains. Obviously,...
                                            11-11-2025, 11:51 AM
