hard locks grapics corruption CPU,RAM,Other
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    So far switched GPU same issue.
    Switched Ram Same issue.
    Hard locks are random.
    System configuration is.
    MB. Gigabyte 990FXA-UD7 V3.0
    CPU. AMD FX-9590
    RAM. two of KINGSTON KHX1600C9D3/8GX
    PSU. corsair AX1200I
    Setting cpu at lowest possible speed helps a lot but still Causes render corruption.
    In this example dragging notepad over firefox.
    Does not affect all programs from what i have noticed but is a symptom I Think.
    here is a example of corruption.
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
    • 31291
    Re: hard locks grapics corruption CPU,RAM,Other
    buggy drivers, or a psu issue are the next suspects.
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      Sometimes if you switch GPU's the system way have several drivers installed and in older versions of Windows this could cause allot of problems.
      I used to use a software called "Driver Cleaner .NET" (paid for software).
      It was good for this but of course nowdays if you Google for it it's been replaced by something which will probably do more harm than good... (so don't download it).
      But the question still stands: what OS do you have this problem on and have you tried a clean install?
      • Seagorman
        • Apr 2017
        • 70
        • Ireland
        Joshnz, i had a similar problem with a pc some months back, customer reported that any time he tried a Render in SolidWorks or tried a screen refresh the pc would crash on a corrupted screen, initially suspected SolidWorks but eliminated that as it still happened on Screen refresh, i carried out a full service on the PC including Driver updates all to no avail, tried changing Ram & Graphics Adapter with no luck, the unlikely culprit turned out to be the PSU, changing this resolved the problem completely, inspection of the original PSU showed a large amount of bulging Caps, bin job as it was old and only rated at 350W, also 'ACE' brand which is the cheapest of the cheap, replacement was an 'Enlight' rated at 750W. its a slightly different issue to what you're having but i wouldn't discount the PSU, worth checking out.
        • joshnz
          • Feb 2011
          • 969
          • New Zealand
          Only one gpu the systems whole life until I swapped gpu with mine to see if problem of windows frame buffer issue changed.
          But I was 99% sure GPU was not the cause of that corruption as it is in screen shots meaning the bad data is in ram but had to try.
          I am running the beast gpu in my system for now to see if I get a hard lock.
          Ii am thinking firefox issue for the corruption issue will have to ask my friend if these fragments of other apps get stuck on the wallpaper.
          system is running Windows 7 x64.
          it is a multiboot i'll get him to try firefox in one of those systems and dragg notepad over it. that is how I got the example.
          My pc
          • joshnz
            • Feb 2011
            • 969
            • New Zealand
            His case is pita to work on.
            I'll try convince him to use the other 1200 watt psu that did not fit the case.
            but will have to run with side off he will not like that idea
            My pc
            • joshnz
              • Feb 2011
              • 969
              • New Zealand
              He just informed me system hard locked earlier so he can have his gpu back.
              guess PSU swap next.
              My pc
                • 31291
                why does the other psu not fit?
                • Seagorman
                  • Apr 2017
                  • 70
                  • Ireland
                  Hi stj, some PSU's appear to be non standard size, i have an Acer PC here, 750W PSU is about half an inch too wide so does not fit into the available room in the case, i dont know if this is just bad design (i doubt it) or if there are cases that take this slightly larger size , possibly some Server cases ?????
                  • joshnz
                    • Feb 2011
                    • 969
                    • New Zealand
                    If i remember correctly it is because the cables are to bulky.
                    The psu is mounted east west and cant get the cables to turn sharp enough to confortably thet the side on.
                    My pc
                    • junktv
                      • Nov 2010
                      • 3065
                      Try another monitor. Had a similar issue and usually my monitor would go black but would scramble sometime. New monitor fixed it.
                      • joshnz
                        • Feb 2011
                        • 969
                        • New Zealand
                        Three monitors happens on all three and is captuered by print screen so it is what windows is sending.
                        My pc
                        • junktv
                          • Nov 2010
                          • 3065
                          If they are hooked up or active in CCC at the same time then one will kick them all. Try disabling or unhooking all but one at a time and test them. Was a hanns-g that was doing it for me. Now use it on another box running linux and it still goes black but hasn't crashed it.
                          Only other thing I can think of is hardware acceleration but doubt it.
                          Similar pc's also. I'm on 8350, asus m5a99fx r2, 8mb gskill 2400 and a 270x devil.
                          • federalhouse
                            **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                            by federalhouse
                            I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                            **Background:**
                            I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                            **What I've Tried So Far:**
                            1. I accessed
                            08-01-2024, 07:03 PM
                          • ash91
                            Hp pavilion 15 not detect hard drive
                            by ash91
                            Hello gentelmen .... this is my first post and sorry for my bad english,
                            so my proplem is my laptop keep losing hard drive even if i but the
                            hard disk in the cady (the box that can replace the dvd rom with hard disk)
                            when i turn the laptop on the massage that said no boot media found pop on
                            the hard disk is fine and to be sure i try another hard
                            i also update my bios to the last update
                            the 5 volt is present on the hard connector on the motherboard
                            the dvd rom work fine when i but a windows dvd in it
                            also when i boot from flash...
                            06-07-2023, 01:45 PM
                          • madura2010
                            DAY11AM6E0 hard disk drive and optical disk drive not detected
                            by madura2010
                            Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                            i checked the connectivity of ribbon=good communication with hard and motherboard
                            changed hard disk and checked=3f0 error persist
                            sata power=+5v available
                            Then checked data capacitors=all good
                            Then checked data lines path connectivity to pch=all good
                            reflashed...
                            03-12-2023, 09:09 AM
                          • odie34
                            Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
                            by odie34
                            I am a hobbyist (not a professional) so please be gentle...
                            I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
                            I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
                            02-18-2024, 09:11 AM
                          • mkdj
                            Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
                            by mkdj
                            Dear all,
                            I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
                            Here the steps I have taken to fix the laptop:
                            - downloaded latest BIOS from Lenovo Website...
                            10-18-2025, 03:43 AM
