win 10 slow boot
  • Chicd
    • Jun 2015
    • 40
    win 10 slow boot
    My pc...dell running win 10 takes about 15 min on boot for me to access any program thru task bar....tried everythimg...any hints?
    • 31278
    Re: win 10 slow boot
    change to win7 or Linux (or dual-boot both)
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      whats are the specs of your pc
      • retiredcaps
        • Apr 2010
        • 9271
        1) Try running a standalone CD virus scanner. Boot PC from CD-ROM or DVD-ROM and let program run.
        Lots to choose from ...
        https://www.lifewire.com/free-bootab...-tools-2625785
        2) Try a live linux CD/USB and see how long it takes to boot. It shouldn't take more than a couple of minutes.
        --- begin sig file ---
        --- end sig file ---
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          Scan the HDD for errors with the manufacturers diagnostic tool, possibly it has bad sectors or is otherwise failing.
          • televizora
            ghettomodmaster
            • Nov 2016
            • 957
            What says the Event Viewer?
            Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
            1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              Originally posted by Chicd
              win 10 .... 15 min on boot
              ok.... Whats wrong here?
              On a more serious note: Sounds like the HDD is failing or a driver is hanging. Can Win10 boot into safe mode anymore? If so i would do that and see what driver it hangs on.
              Follow the white rabbit.
              • Seagorman
                • Apr 2017
                • 70
                • Ireland
                Hi Chich, could possibly be a problem with the Hard Drive but i've seen loads of Windows 10 installs suffer severe slowdown after Windows Updates have been downloaded and installed. How is the Computer behaving when it finally loads up the Desktop, is it working normally or still slow?, download Macrorits Disk Scanner from the following ink and run it to check your Hard Drive
                http://macrorit.com/disk-surface-tes...face-test.html
                Let us know the outcome, also did your Computer come with Windows 10 pre installed or did you avail of the free Upgrade ?. on most of the Computer i've seen with the free upgrade the Hard Drive activity seems to continuously run at 100%, on most occasions nothing seems to fix it ie. disabling unnecessary services or startup entries etc, wouldnt be the cause of your slow boot up but if Windows is running very slow itself check it out by pressing 'Ctrl,Alt, Del', select 'Task Manager' and have a look, again let us know your findings
                • ChaosLegionnaire
                  HC Overclocker
                  • Jul 2012
                  • 3266
                  • Singapore
                  or maybe the hard drive just needs a defrag is all. also since its an oem pc from dell, most likely it comes with tons of bloatware bogging it down. run pc decrapifier to debloat?
                  on a lighter note, most likely win10 is just gathering all of your personal data on the hard drive and sending it to m$. hahaha! hope u dont have anything naughty on there, man!
                  • mamado mosa
                    Slow boot dell latitude 5410 laptop issues
                    by mamado mosa
                    So i had this laptop dell latitude 5410 10th gen, good condition and new ssd and 16 gb ram .
                    The problem is it takes more than a minute to boot ..
                    The boot sequence starting with a 30 sec black screen and the the dell logo for 20 and when the windows start loading it takes like 7 sec .
                    Can someone suggest something to fix
                    06-19-2025, 06:55 AM
                  • privato89
                    Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                    by privato89
                    I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                    Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                    Let's begin:
                    Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                    03-26-2024, 06:37 AM
                  • Stephen
                    A1990 MacBook Pro 15" Turning on, loads then boot loops, fan spin slow and then fast
                    by Stephen
                    Got a MacBook Pro 15" A1990 with a board issue, The board turns on, I did a DFU revive to see if it needed a firmware patch, that was successful, however the board just keeps boot looping and turning off and on very quickly. Obviously the DATA Is there, but it wont even launch into recovery, it will just die and turn back on with Apple logo, once it gets really hot it dies, if the laptop sits for the day and is cool, it will turn on then get hot within 1 min then die and turn itself on and repeat. Once it does that it turns itself on and off repeatedly in seconds. I put a thermal camera...
                    10-04-2024, 02:50 PM
                  • Luke Anders
                    Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
                    by Luke Anders
                    A few details about the laptop itself:
                    Name: Lenovo Legion 5
                    Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
                    BIOS Version: GKCN60WW
                    EC Version: GKEC65WW
                    Serial Number: PF39AQ7Z
                    Board Model: NM-D562 Rev 3.0
                    RAM: 16GB Installed, DDR4 (brand new)
                    NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
                    I bought this laptop recently from eBay as a faulty device....
                    10-12-2024, 05:13 AM
                  • hinisa
                    Xiaomi router freezes at boot after re-capping
                    by hinisa
                    I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                    When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                    After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                    Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                    07-08-2023, 05:58 AM
