Whats my NIC upto?
  • Fizzycapola
    • Oct 2006
    • 423
    Whats my NIC upto?
    It's just been sitting looking at badcaps forum idle. It did this the other day too with google search sitting idle. Software firewall is allowing only System, Genenric Host Process and FireFox3.0.3 on Port 80.
    This is the native NIC (Atheros) on the P5Q. Through my laptop and other computers it looks normal, only a few thousand packets.
    Rubycon Rubycon Rubycon
  • bgavin
    • Jan 2007
    • 1355
    Re: Whats my NIC upto?
    This is a huge annoyance for me, also.
    A virgin installation of WinXP is constantly accessing the internet. I assume it is calling home for something or other. The activity never stops. Considering the vast number of Windows computers, this alone must constitute a horrendous amount of bandwidth consumption just on the Microsoft subnets.
    Why?
    • zandrax
      Hit and miss
      • Dec 2007
      • 1157
      • Italy
      @ Fizzy: those aren't packets but bytes so it's normal to see millions if not billions of bytes (compared to thousands to millions of packets: an ethernet packet ranges from a few bytes to 9000 [Jumbo frame] with 1500 bytes being the most common dimension). If your pc is connected to a lan while idling, you should consider all periodic and occasional exchanges among computers: Windows sharing (in a workgroup all computers broadcast their IPs and available resources about every 11 minutes, then await for replies), ICMP packets from the router or server (my Netgear router pings all computers on the lan about once a minute), DHCP renewal (usually once a day) and others. There is Windows related traffic too: calls to Windows Update, to Certificate Renewal list site and a few others.
      To discover them install a packet sniffer such as Wireshark (previously known as Ethereal) on your machine and log all connections.
      Zandrax
      Have an happy life.
      • Fizzycapola
        • Oct 2006
        • 423
        Zandrax, you're missing the point, you've started by jumping on my meaningless error - packet/byte it makes no difference with regard to the concern.
        Thats way too much activity for an idle computer with firewall only allowing the said activities. For example my laptop reads after 55 minutes: sent: 3,147 received 3,710. And my other computers read similar with Intel NIC's.
        I say it's a conspiracy lol.
        • Harvey
          • Apr 2007
          • 264
          Maybe you have a virus.
          • Fizzycapola
            • Oct 2006
            • 423
            Thanks for your suggestion Harvey. I'll have to check that one.
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              I think your PC is just lonely and it's checking out all the cute little SFF's on the PC personals sites.
              Mann-Made Global Warming.
              - Dr Seuss
              • JEWilson
                • Sep 2007
                • 369
                • Scotland, United Kingdom
                If no virus or malware
                Most likely be a default XP service such as SMB peer arbitration.
                You will be set up in workgroup most likely.
                On Win2k is the computer browser service
                If you have no browse master set up or, if you have a PC set up
                as a backup browser, there may exist a conflict.
                In this instance, the computer will try to arbitrate as to who
                will be browse master.
                This is more readily explained below;
                see further (Win2K)
                http://www.tech-archive.net/Archive/...4-10/1384.html
                as well as
                http://support.microsoft.com/kb/188001
                Alternatively, you may care to look into DHCP leasing and renewals
                Yet again, it may be a routing issue, a broadcast is occuring to locate
                you on the subnet.
                HTH
                • zandrax
                  Hit and miss
                  • Dec 2007
                  • 1157
                  • Italy
                  @ Fizzy: I support Harvey and JE: check for malware and for Windows services and/or drivers.
                  Generic Host Process is svchost.exe, Windows' service loader: allowing it means allowing all services which rely on it such as NetBIOS Helper, Workstation, Server, RPC service and others. My point is still valid: install a packet sniffer and check the traffic.
                  Zandrax
                  Have an happy life.
                  • hinisa
                    Xiaomi router freezes at boot after re-capping
                    by hinisa
                    I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                    When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                    After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                    Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                    07-08-2023, 05:58 AM
                  • m1ch43lzm
                    by m1ch43lzm
                    Hi everyone
                    09-06-2025, 05:47 PM
                    Texas Instruments bq24745 bq24745RHDR bq24745RHDT Battery Charger IC for Laptop Computers Datasheet
                    The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
                    The bq24745 features dynamic power management...
                    10-23-2024, 02:50 AM
                  • BOSCHNJAK
                    by BOSCHNJAK
                    ABOUT ME INTRODUCTION FILE
                    2
                    024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
                    2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
                    2022 BEV, PROJECT ?
                    2021 BEV, PROJECT ?
                    2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
                    2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
                    12-28-2023, 02:09 PM
                    MPS NB670 NB670GQ Switch Mode Converter for Laptop Computers Datasheet
                    The NB670 NB670GQ is a fully integrated high frequency synchronous rectified step-down switch mode converter with 3.3V fixed output voltage. It offers very compact solution to achieve 6A continuous output current and 9A peak output current over a wide input supply range with excellent load and line regulation. The NB670 operates at high efficiency over a wide output current load range. Constant-On-Time (COT) control mode provides fast transient response and eases loop stabilization.
                    Under voltage lockout is internally set as 4.65V. An open drain power good signal indicates the output...
                    10-23-2024, 03:23 AM
