Re: Whats my NIC upto?
@ Fizzy: I support Harvey and JE: check for malware and for Windows services and/or drivers.
Generic Host Process is svchost.exe, Windows' service loader: allowing it means allowing all services which rely on it such as NetBIOS Helper, Workstation, Server, RPC service and others. My point is still valid: install a packet sniffer and check the traffic.
Zandrax
Try our new boardview, bios, & schematic search. Over 1.3 million files for download!
Whats my NIC upto?
If no virus or malware
Most likely be a default XP service such as SMB peer arbitration.
You will be set up in workgroup most likely.
On Win2k is the computer browser service
If you have no browse master set up or, if you have a PC set up
as a backup browser, there may exist a conflict.
In this instance, the computer will try to arbitrate as to who
will be browse master.
This is more readily explained below;
see further (Win2K)
http://www.tech-archive.net/Archive/...4-10/1384.html
as well as
http://support.microsoft.com/kb/188001
Alternatively, you may care to look into DHCP leasing and renewals
Yet again, it may be a routing issue, a broadcast is occuring to locate
you on the subnet.
HTHLeave a comment:
I think your PC is just lonely and it's checking out all the cute little SFF's on the PC personals sites.Leave a comment:
Thanks for your suggestion Harvey. I'll have to check that one.
Zandrax, you're missing the point, you've started by jumping on my meaningless error - packet/byte it makes no difference with regard to the concern.
Thats way too much activity for an idle computer with firewall only allowing the said activities. For example my laptop reads after 55 minutes: sent: 3,147 received 3,710. And my other computers read similar with Intel NIC's.
I say it's a conspiracy lol.Leave a comment:
@ Fizzy: those aren't packets but bytes so it's normal to see millions if not billions of bytes (compared to thousands to millions of packets: an ethernet packet ranges from a few bytes to 9000 [Jumbo frame] with 1500 bytes being the most common dimension). If your pc is connected to a lan while idling, you should consider all periodic and occasional exchanges among computers: Windows sharing (in a workgroup all computers broadcast their IPs and available resources about every 11 minutes, then await for replies), ICMP packets from the router or server (my Netgear router pings all computers on the lan about once a minute), DHCP renewal (usually once a day) and others. There is Windows related traffic too: calls to Windows Update, to Certificate Renewal list site and a few others.
To discover them install a packet sniffer such as Wireshark (previously known as Ethereal) on your machine and log all connections.
ZandraxLeave a comment:
This is a huge annoyance for me, also.
A virgin installation of WinXP is constantly accessing the internet. I assume it is calling home for something or other. The activity never stops. Considering the vast number of Windows computers, this alone must constitute a horrendous amount of bandwidth consumption just on the Microsoft subnets.
Why?Leave a comment:
Whats my NIC upto?
It's just been sitting looking at badcaps forum idle. It did this the other day too with google search sitting idle. Software firewall is allowing only System, Genenric Host Process and FireFox3.0.3 on Port 80.
This is the native NIC (Atheros) on the P5Q. Through my laptop and other computers it looks normal, only a few thousand packets.
Tags: None
by hinisaI'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...-
Channel: Troubleshooting & Designing Networks
by m1ch43lzmHi everyone
I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
Programmer models: XGecu TL866II Plus / T48 / T56 / T76
Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
There's also an extra OTP Secu.R...-
Channel: BIOS Requests ONLY!
The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
The bq24745 features dynamic power management...-
Channel: Common Parts Library - Datasheets
10-23-2024, 02:50 AM -
by BOSCHNJAKABOUT ME INTRODUCTION FILE
2024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
2022 BEV, PROJECT ?
2021 BEV, PROJECT ?
2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...-
Channel: Visitor Messages
12-28-2023, 02:09 PM -
The NB670 NB670GQ is a fully integrated high frequency synchronous rectified step-down switch mode converter with 3.3V fixed output voltage. It offers very compact solution to achieve 6A continuous output current and 9A peak output current over a wide input supply range with excellent load and line regulation. The NB670 operates at high efficiency over a wide output current load range. Constant-On-Time (COT) control mode provides fast transient response and eases loop stabilization.
Under voltage lockout is internally set as 4.65V. An open drain power good signal indicates the output...-
10-23-2024, 03:23 AM -
- Loading...
