Texas Instruments bq24745 bq24745RHDR bq24745RHDT Battery Charger IC for Laptop Computers Datasheet
  • Boardview and Schematic Bot
    • 115958
    The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
    The bq24745 features dynamic power management (DPM) and input power limiting. These features reduce battery-charge current when the input power limit is reached to avoid overloading the ac adaptor when supplying the load and the battery charger simultaneously. A highly accurate current-sense amplifier enables precise measurement of input current from the ac adapter, allowing monitoring the overall system power. If the adapter current is above the programmed low-power threshold, a signal is sent to host so that the system optimizes its performance to the power available from the adapter. An integrated comparator monitors the input current through the current-sense amplifier, and indicates when the input current exceeds a programmable threshold limit.
    Features
    • NMOS-NMOS Synchronous Buck Converter with 300-kHz Frequency and >95% Efficiency
    • 30-ns Minimum Driver Dead-Time and 99.5% Maximum Effective Duty Cycle
    • High-Accuracy Voltage and Current Regulation – ±0.5% Charge Voltage Accuracy – ±3% Charge Current Accuracy – ±3% Adapter Current Accuracy – ±2% Input Current Sense Amp Accuracy
    • Integration – Input Current Comparator, With Adjustable Threshold and Hysteresis – Internal Soft-Start
    • Safety – Dynamic Power Management (DPM)
    • Up to 19.2-V Battery Voltage
    • 7-V–24-V AC/DC-Adapter Operating Range
    • Simplified SMBus Control Interface – Charge Voltage DAC (1.024 V–19.2 V) – Charge Current DAC (128 mA–8.064 A) – Adapter Current Limit DPM DAC (256 mA–11.008 A)
    • Status and Monitoring Outputs – AC/DC Adapter Present With Adjustable Voltage Threshold – Input Current Comparator With Adjustable Threshold and Hysteresis – Current Sense Amplifier for Current Drawn From Input Source
    • Charge Any Battery Chemistry: Li+, NiCd, NiMH, Lead Acid, Etc.
    • Charge Enable Pin
    • < 10-uA Battery Current With Adapter Removed
    • < 1-mA Input DCIN Current With Adapter Present and Charge Disabled
    • 28-Pin, 5-mm × 5-mm QFN Package
    Applications
    • Laptop and Ultra-Mobile Computers
    • Portable Data-Capture Terminals
    • Portable Printers
    • Medical Diagnostics Equipment
    • Battery Bay Chargers
    • Battery Backup Systems
    Our boardview and schematic bot.
    Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
    I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
    I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
    I tested the battery cells there are installed right now and they are testing good with no issues that I...
    02-04-2025, 08:08 PM
  • quickname
    Cyberpower 1500AVR UPS repair
    by quickname
    I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
    I decided to verify that the batteries were...
    11-12-2023, 09:57 AM
    Diodes AP21X2SG-13 AP21X2MPG-13 Current Limited Power Switch for Laptop Computer Datasheet
    The AP2182 and AP2192 (AP21X2SG-13 AP21X2MPG-13) are integrated high-side power switches optimized for Universal Serial Bus (USB) and other hot-swap applications. The family of devices complies with USB 2.0 and available with both polarities of Enable input. They offer current and thermal limiting and short circuit protection as well as controlled rise time and under-voltage lockout functionality. A 7ms deglitch capability on the open-drain Flag output prevents false over-current reporting and does not require any external components.
    All AP21X2SG-13 AP21X2MPG-13 devices are available...
    10-23-2024, 03:33 AM
  • DynaxSC
    Extreme High Current & Low Voltage Short Killer ??
    by DynaxSC
    Hi Folks
    I'm looking for a extreme high current short killer solution for a reasonable cost.
    I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
    After taking off the socket, the shorts dissappear again.
    The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
    10-15-2024, 10:13 AM
    Adjustable Boost Power Supply DC-DC Constant Voltage Current Charging Module
    I want to know if I could hook up a solar panels to this boost converter would I have any issues doing and I would have issues what would they be
    https://www.ebay.com/itm/116497313155?var=416785404161
    Here are some of the description from the eBay seller
    The main parameters:
    1. Product name: High-power non-isolated DC boost module power supply.
    2. Product model: 100A2000W.
    3. Input voltage: DC12V-60V.
    4. Input current: 100A (maximum)....
    05-18-2025, 09:45 AM
