Do you find this mod report credible?
  • jpdoe
    • May 2007
    • 237
    This guy claims he obtained a more stable 12v PSU output by attaching a couple of old cpu heatsinks to the stock PSU heatsinks. The kicker is, by looking at the pictures, it seems he only used a couple of screws and thermal paste to join them.
    Do you think that simple a mod can have such an important impact on 12v stability?
    http://alfredoblogspage.blogspot.com...0w-inside.html
  • Kaine
    • Mar 2007
    • 55
    Re: Do you find this mod report credible?
    Considering how shitty the original heatsinks were, it wouldn't surprise me. He's just about doubled the heat dissipation capacity there. I'd still want to see it on a CRO for proof though.
    • kikkoman
      • Jul 2007
      • 691
      don't know.
      there's space in there for a PFC transformer... either he removed it or PFC isn't mandatory where he lives. in case of the latter, why those crappy heatsinks in the first place?
      i have the extreme power 430W version which definitely has better heatsinks. mine's a rebranded Hipro unit. can anyone tell from the pictures who is the manufacturer of this unit?
      "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
      • jpdoe
        • May 2007
        • 237
        @kikoman: In his profile he says he is from my country, Argentina. Down here is very common to recognize on a PSU with missing components the PCB of a model seen on the web with all the components in place. My theory is that the argentinian importers dictate the price point they want to the PSU providers, and they in change decide which components they can skimp on, or totally remove, to achieve this price point. This got much worse when local brands got into the game. Kit (case, PSU, keyboard, mouse, loadspeakers) importers started to have his products branded with their local brand. PSU quality went downhill. There was a time when it was safer to buy international brands, no matter how shitty they were. In comparison to the local brands, it was a safer bet. Nowadays it seems even these players figured out they can't sell the same product worldwide, and they make even shittier products for Latin America.
        • i4004
          • Oct 2006
          • 2029
          that's not limited to latin america: cheap pcs have cheap psus, and that's it.
          usually another thing is also true: mid-range pcs also have crappy psus.
          overall only way to get a good psu is to build a machine yourself, as you never know what the assholes are putting in.
          but worst crap are the supplies for external hdd boxes.
          (if i have some time i'll do a writeup about that...)
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            better be careful! the heatsink with the choppers on it is live.
            short it to the rectifier heatsink and kill whatever is hooked to the unit.
            shock hazzard too.
            • zandrax
              Hit and miss
              • Dec 2007
              • 1157
              • Italy
              Too true to not to quote this
              Zandrax
              Have an happy life.
              • Gianni
                • Jul 2008
                • 681
                • Italy
                It is strange IMHO that he can have so good results just with a small contact area between original HS and the added ones.
                I would like to see with my eyes... and measure with my equipment.
                For sure, like kc8adu wrote, it is not safe to put the primary HS so close to the secondary HS.
                Gianni
                "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
                H. J. Brown
                • jpdoe
                  • May 2007
                  • 237
                  Thanks for all your answers. I guess if I try something like this I'll be changing the whole heatsinks. Don't like the idea of frying something otherwise, or the unhealthy live voltage kick.
                  • Krankshaft
                    • Jan 2007
                    • 2328
                    Yeah it's very funny that this guy didn't display a waveform from a scope to prove his theory.
                    My guess is he doesn't even own one.
                    • Fizzycapola
                      • Oct 2006
                      • 423
                      What more can you do than thermal paste and screws. Atleast it's better than glueing little pieces together several times and calling it the Thermaltake Ultra XXX edition.
                      Rubycon Rubycon Rubycon
                      • 999999999
                        • Sep 2006
                        • 774
                        That is just crazy. First of all, putting those heatsinks on doesn't significantly extend the life of the other components, the same amount of heat is being produced in the PSU either way so it his fan is slower, everything else gets hotter.
                        You can see the thermal sensor strapped onto one of the fins, putting a heatsink on the end like that will at most cool the sensor a bit due to proximity, and moreso due to blocking the empty area in the back of the PSU so it will cause more of the airflow to flow past the other components on the way out. This can be seen as good for a different reason, that it causes more airflow on the other parts instead of just the thermal sensor's heatsink fin. Even so, odds are his PSU components temp rose besides maybe a very small decrease in the two heatsink temps, offset by lower airflow as he described it. The PSU is worse off for having been modded before even considering the possiblity of the heatsink shorting on something if it moved.
                        It won't substantially change the voltage either, he must've had a different load as the PSU regulates based on feedback voltage, it's not an unregulated PSU that would respond to thermal drift of the parts inside.
                        As far as what more you could do, you could take the original heatsinks out entirely and put different ones in. The 600W version has copper 'sinks instead of aluminum, that is what Coolermaster already did.
                        • Vesko356
                          by Vesko356
                          08-11-2023, 03:27 AM
                        • danielgerman681
                          ENCONTRAR DATOS DMI EN EL CHIP BIOS IDEAPAD5 15ITL05 / FIND DMI DATA ON IDEAPAD5 15ITL05 BIOS CHIP
                          by danielgerman681
                          Hi, Im trying to find the area on the chip that contains all of my laptops information, but I havent found it. The laptop won't turn on anymore. I was updating the BIOS, and it was supposed to reboot itself, but it wouldnt turn back on. I ve tried every possible solution, every alternative on Lenovo forums, everywhere; I ve taken it to technicians, and no one has been able to fix it. I've already read the chip that contains the BIOS (Winbond 25Q128JSVQ) and searched for my laptops data, but they're nowhere to be found. I only find scribbles and lines of text indicating errors. Has anyone had a...
                          Yesterday, 01:17 PM
                        • GLISIT
                          by GLISIT
                          01-16-2025, 02:29 PM
                        • corrize
                          Where to find a very small fpc connector 0.3mm between 2 pins ?
                          by corrize
                          Hello, I search this connector (oxydated).
                          It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                          I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                          I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                          Do you know how to find this connector please ? What is the exact name for find it ?
                          08-06-2024, 05:25 PM
                          Where can I find a DD3 128000 type memory but 32 MGB in one module because this laptop has only one slot
                          by sam_sam_sam
                          This Dell computer is a pain in the a** because of it only has one memory slot this computer only had 4 megabytes of memory and slower than shit I found a 8 megabyte memory module and it is better but still slow as shit the maximum is 32 megabytes of RAM but I was not able to find one I found some that are 16 megabytes but they are 1600/128000 type and I am not sure if this computer will work with this type of memory or not
                          Dose anyone knows where I can find a 32 megabytes memory module for this computer because the battery still works fairly well still I would like to use it on my...
                          07-07-2024, 02:34 PM
