IDE adapters
  • stevo1210
    • Oct 2006
    • 4156
    IDE adapters
    I have one of these 2.5" --> 3.5" IDE adaptors to make a notebook hard drive compatible with a desktop PC. Only problem is that I don't know which way it goes into the laptop drive. It fits both ways so I am wary about this and I don't want to burn my laptop hard drive either. I can see that on the adaptor there is an indication of "pin 1", but I don't exactly know where pin 1 is on a laptop hard drve. So to make things easy, looking from a bove the drive (from the top where the labels are on the drive), which side is pin 1? left or right?
    My IDE adaptor is similar to this one: http://cgi.ebay.com.au/IDE-2-5-in-to...QQcmdZViewItem
    Thanks.
  • 370forlife
    Large Marge
    • Aug 2008
    • 3113
    Re: IDE adapters
    My experience with hard drives is that if a cable is plugged in backwards, it will just not detect it or throw a error. Also, i believe pin 1 is always the top, left hand side, but don't take that as fact, i don't usually work with laptop hard drives.
    • linuxguru
      • Apr 2005
      • 1564
      Re: IDE adapters
      Heads up: If you plug in the 50-pin cable reversed into a 2.5" IDE drive, it will usually release its magic smoke. The reason is that the connector also carries power (+5v) since there is no separate power connector. The power pins, if reversed, map onto something that trigger the smoke release (I forgot exactly what - maybe GND, maybe signal pins). Whatever it is, don't try reversing the cable. Pin 1 is on the side which has the configuration jumpers/pins (4-8 pins that are separated from the remaining 50).
      • Wizard
        • Mar 2008
        • 2296
        Re: IDE adapters
        Not just that, there are ground pins in wrong places and swapping connector adapter on HD around or the cable too shorts out the chipset and goes the useful die in them. Poof.
        Take a clear pic of your adapter both sides and we can find it.
        Cheers, Wizard
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          Re: IDE adapters
          hmm there should be one pin missing no?
          i will check tomorrow at the office
          • Scenic
            o.O
            • Sep 2007
            • 2642
            Re: IDE adapters
            pin 1 is always the one next to those 4 master/slave jumper pins
            dont mind those slightly bent pins.. i used one of those 2.5" HDD adapters waay too often on this HDD
            • Gendo Ikari
              • Jun 2008
              • 62
              Re: IDE adapters
              I need to get one of those to work on my notebook drive.
              So, who makes a good adapter?
              • dood
                Deputy dood
                • Mar 2004
                • 2462
                Re: IDE adapters
                Any old cheap thing will do. I usually get mine from Cyberguys for a couple bucks. I get a few, because I have a tendency to lose them somehow. There's nothing to them, so I've never seen a crappy one!
                Ludicrous gibs!
                • federalhouse
                  **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                  by federalhouse
                  I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                  **Background:**
                  I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                  **What I've Tried So Far:**
                  1. I accessed
                  08-01-2024, 07:03 PM
                • tmcw
                  PC case - Hard drive rails
                  by tmcw
                  A friend gave me his old PC case (with MB, and PSU), but no hard drive rails, he said he only used the 2.5" SSD spot inside, and used an external hard drive for data. He said that he'd have a look for the supplied rails, but I doubt he'll find them.
                  So I was wondering if case manufacturers used any type of standard 3.5" hard drive rail?
                  I'm used to the various Dell hard drive caddies or rails (and HP and Lenovo to a lesser extent), or el cheapo cases where you screw through the frame to fix the drive.
                  Now, the case is a CiT Gaming Case, and...
                  05-22-2022, 12:04 PM
                • madura2010
                  DAY11AM6E0 hard disk drive and optical disk drive not detected
                  by madura2010
                  Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                  i checked the connectivity of ribbon=good communication with hard and motherboard
                  changed hard disk and checked=3f0 error persist
                  sata power=+5v available
                  Then checked data capacitors=all good
                  Then checked data lines path connectivity to pch=all good
                  reflashed...
                  03-12-2023, 09:09 AM
                • ash91
                  Hp pavilion 15 not detect hard drive
                  by ash91
                  Hello gentelmen .... this is my first post and sorry for my bad english,
                  so my proplem is my laptop keep losing hard drive even if i but the
                  hard disk in the cady (the box that can replace the dvd rom with hard disk)
                  when i turn the laptop on the massage that said no boot media found pop on
                  the hard disk is fine and to be sure i try another hard
                  i also update my bios to the last update
                  the 5 volt is present on the hard connector on the motherboard
                  the dvd rom work fine when i but a windows dvd in it
                  also when i boot from flash...
                  06-07-2023, 01:45 PM
                • karto95
                  Repairing a Seagate hard drive with damaged logic board
                  by karto95
                  I'm currently facing an issue with my Seagate hard drive that has a damaged logic board. I've obtained a replacement logic board from a donor hard drive, but unfortunately, I'm unable to recover the BIOS of the original board due to damaged firmware. I'm wondering if it's possible to make the hard drive work with this donor logic board.
                  I have a CH341A programmer, so I'm hoping that it can be useful in this situation. I've attached the BIOS file .bin of the donor board for reference.
                  If anyone has any suggestions or experience with this...
                  03-21-2023, 04:05 AM
