How do I know if RAID is really working
  • travistee
    • Sep 2008
    • 68
    I have a gateway that has a RAID controller.
    The bios say its in RAID mode.
    In computer management I see:
    C: system boot... etc
    D: primary partition (recovery)
    E: Primary partition ( size is equal to an blank disk )
    Haven't used raid for awhile but as I recall, it should see the RAID array, two disks as one disk. So it should have only one primay partition.
    Any thoughts?
  • bgavin
    • Jan 2007
    • 1355
    Re: How do I know if RAID is really working
    Microsoft RAID is a tinker toy. First, the striping is done in software... oh great.. I want to let Microsoft handle yet another super-critical disk function.
    No thanks.
    If you really want RAID, do it in hardware. Spend the $$$ for a good card. Software RAID is bupkis. You can find all sorts of performance data on the various RAID flavors. There are benefits and penalties to each configuration.
    GHOST images and regular backups will keep you out of trouble.
    • pfrcom
      Oldbie
      • Jun 2006
      • 1230
      Multiple partitions can be defined on one disk - does Device Manager show one disk, or more ?
      better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
      • travistee
        • Sep 2008
        • 68
        Device manager also shows two disks.
        I think that even though the bios show its in raid mode, its not really seeing the two disks as one, as I think it should in a raid.
        • welp
          PS5 Disk Tray issues.
          by welp
          I have a PlayStation 5 CH-1215A with a Disk drive not reading disks anymore. (accepting and ejecting very slowly.)
          Knowing the PS5 has a married daughter board for the disk drive I made sure to use that and replace the rest of the disk tray as it* was owned previously by an indoor smoker.
          Once the job was complete and put back everything together, I tried to insert a disk with no luck at all...
          So, I checked voltage going from the ps5 to the daughter board and am only getting the 5V rail.
          With that knowledge I preceded to check all the fuses for the 12v rail on the main...
          12-19-2024, 02:04 PM
        • DynaxSC
          ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
          by DynaxSC
          I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
          Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
          Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
          The behaviour is also really very strange, i.e.:
          • The disk shows always up in BIOS - so it is recognized, so far so good
          • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
          02-23-2025, 01:33 PM
        • chth96
          LG GCC-4521B cannot read any disk
          by chth96
          I bought 6 second hands odd $5 at a flea market and I found that 2 odd(GCC-4521B,TS-H192) won't read any disk.
          But I measured all ESR value of SMD capacitor which is located on the TS-H192's PCB and replaced two capacitor which has higher ESR value.
          And To My joy,this TS-H192 odd finally recognized burned CD as well as pressed CD.😂
          But there was no more good fortune for GCC-4521B..In order to dead GCC-4521B back to life, I replaced three capacitor which has higher ESR value and I rubbed silicon grease on the every glides.I even brushed lens with cotton swab which was soaked...
          02-13-2024, 07:31 AM
        • madura2010
          DAY11AM6E0 hard disk drive and optical disk drive not detected
          by madura2010
          Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
          i checked the connectivity of ribbon=good communication with hard and motherboard
          changed hard disk and checked=3f0 error persist
          sata power=+5v available
          Then checked data capacitors=all good
          Then checked data lines path connectivity to pch=all good
          reflashed...
          03-12-2023, 09:09 AM
        • canadaboy25
          Drive SMART status not showing up through RAID controller?
          by canadaboy25
          Hey guys,
          I have an Asus M5A99FX Pro R2.0 motherboard with AMD RAIDXpert. I set up a 1000GB RAID1 array on it. This was about 8 years ago. Every once in a while, a power outage or something would knock one drive offline and degrade the array. After a reboot the drive would be back online and it would rebuild just fine.
          Recently, a drive dropped offline and the array became degraded. I figured it was no big deal and rebooted then set it to rebuild overnight. The next morning I took a look and both drives had dropped offline at 70% rebuild. Uh oh.
          I rebooted...
          09-24-2021, 01:56 PM
