heads up if you have an asus motherboard
  • rhomanski
    nowhere man
    • 5157
    • U S of A
    Haven't seen this on here so thought I'd put it up.
    http://www.forbes.com/sites/gordonke...x#3215df3f395e .
    Can you put Apple OS on a windows machine?
    sigpicThe Sky Is Falling
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: heads up if you have an asus motherboard
    The boards that have a dual back up Bios which also then restores the original flash if it fails should be ok.
    • Mad_Professor
      A Mech Warrior
      • Feb 2011
      • 1587
      Won't do any good since it's operating system issue and not a bios issue.
      The optional now recommended update adds UEFI support to windows 7, if the motherboard has UEFI secure boot enabled, on the next boot after the update had been applied to windows, the board won't recognize the windows installation since it never sign any keys for the uefi to store and compare to, it will refuse to boot the installation thinking it's malicious hence delivering a scary message.
      fuck microsoft and fuck windows.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Ahh I read it wrong lol yeah I see now thats just crap tbh
          • 31063
          just turn off the secureboot crap in the bios.
          proves it works btw, m$ fucked with the bootloader, so the bios detected the change.
          that or windows changed the EFI config - something that should be impossible - in which case we need that crap scrapped!
          (windows AND UEFI)
          • junktv
            • Nov 2010
            • 3065
            I'm not seeing that update and haven't installed it. Using 7 pro 64bit.
            • rhomanski
              nowhere man
              • 5157
              • U S of A
              I turned update off months ago and haven't even looked at it. Still doesn't stop this thing from sitting for hours at 50% cpu usage and 60% ram used.
                • 31063
                metrics and telemetry?
                i would put a network sniffer on that machine!
                • rhomanski
                  nowhere man
                  • 5157
                  • U S of A
                  I haven't done that yet but I have checked it with all kinds of different programs and nothing is found. I assumed it's that update checking with microsoft as everyone says. I figured telling it to not bother me about updates doesn't stop it from looking. On top of that I also notice security essentials isn't being updated like it used to. It complains about being out of date and will try to update for hours. Usually the next day microsoft will finally post one and it'll be happy for a couple days. They are doing all they can to force everybody to get 10 it looks like. Everyday it seems like they do something new to make 7 unusual. Sorry "unuseable".
                    • 31063
                    i have background software consantly checking sites for updates - news & torrents mostly.
                    it does not use 50% cpu - it does not even register on the cpu monitor!
                    your system is doing A LOT. (of something!)
                    • rhomanski
                      nowhere man
                      • 5157
                      • U S of A
                      Recently someone posted an article about 7 update program using 50% cpu and a lot of memory. !00% cpu with a single core. It started on mine just about the time they mentioned it. I went ahead and scanned it 7 ways from Sunday with nothing found. If I kill the internet it stops, but when it's doing it, it doesn't go on the internet. It doesn't run the hard drive either. Not sure what's going on. Others say it's just microsoft. I don't know.
                      • dan8139
                        • Jul 2004
                        • 57
                        I had the problem with Windows 7 Update sitting there doing nothing while using one core flat out and finally found the solution - install KB3102810.
                        You might have to do it after a reboot (disconnect the internet), or it won't install due to the same problem.
                        That's fixed it on a dozen or so machines for me.
                        Off topic sorry :-)
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          Turning off updates is not a good thing. What hardware have you got ?
                          Did you scan in safe mode ? Quality malware can avoid detection fairly easily.
                          • goodpsusearch
                            • Oct 2009
                            • 2850
                            • Greece
                            • goodpsusearch
                              • Oct 2009
                              • 2850
                              • Greece
                              In order to avoid endless "checking for updates" and high CPU/RAM usage you should install the following KB BEFORE running Windows Update (manually or automatically):
                              There should be NO INTERNET CONNECTION during Windows boot.
                              Manually install Updates in the following order:
                              KB947821 (could skip downloading and installing this one)
                              KB3083710 (October update client for Windows 7, fixes problems)
                              KB3102810 (definitely INSTALL this before running Win Update)
                              KB3138612 (latest update client for Windows 7, fixes many problems)
                              KB3145739 (important security update that makes Windows Update stuck forever at checking for updates, installing it manually fixes the problem)
                              Reboot if required between steps
                              Reconnect Internet
                              Run Windows Update or enable automatic updates and let it run in the background and install updates.
                              off topic:
                              To avoid Windows 10 and the spyware stuff:
                              Untick the checkbox
                              "Give me recommended updates the same way I receive important updates"
                              in Windows Update Settings
                              DON'T INSTALL / UNINSTALL THE FOLLOWING UPDATES
                              KB2952664 Compatibility update for upgrading Windows 7
                              KB2990214 Update that enables you to upgrade from Windows 7 to a later version of Windows
                              KB3021917 Update to Windows 7 SP1 for performance improvements (Telemetry)
                              KB3035583 Update installs Get Windows 10 app in Windows 8.1 and Windows 7 SP1 (GWX.exe)
                              KB3068708 Update for customer experience and diagnostic telemetry (Replaces: KB3022345)
                              KB3075249 Update that adds telemetry points to consent.exe in Windows 8.1 and Windows 7
                              KB3080149 Update for customer experience and diagnostic telemetry
                              KB3090045 Update for reserved devices in Windows 8.1 or Windows 7 SP1
                              KB3123862 Updated capabilities to upgrade Windows 8.1 and Windows 7
                              KB3139929 -MARKED AS IMPORTANT-Security Update for Internet Explorer with Windows 10 ads embedded...
                                • 31063
                                maybe the computer is mining bitcoins or some other "shared computation"
                                • rhomanski
                                  nowhere man
                                  • 5157
                                  • U S of A
                                  It's a Sony Vaio from around 2006. 2 core processor with 1 gig of ram. It's slow but still works fine. I already had those updates installed. I shut it off in November when they pissed me off. I just installed 36 security updates that were waiting. Four failed and now they've disappeared. It's still running the drive and cpu and memory. It should settle down soon. I'll check for them old updates but the ones it installed were higher numbers, newer updates. I'm pretty sure I never installed them old ones or uninstalled them when I got mad in November. I use Firefox and never even open IE.
                                    • 31063
                                    find out what aplication is using all the ram.
                                    • rhomanski
                                      nowhere man
                                      • 5157
                                      • U S of A
                                      It says svchost is using a lot of cpu and memory which leads to windows operating system.
                                      I uninstalled AVG months ago but it looks like it's still reserving memory too. By the way it says 3 gig of memory not 1.
                                      • goodpsusearch
                                        • Oct 2009
                                        • 2850
                                        • Greece
                                        svchost is not service, right click on it and find the service that uses it.
                                        wtf about avg? once an Av program is gone it should be gone completely from the system. Only some spare files and some unused registry elements could be leftover but not consuming ram/cpu.
                                        You are probably doing something wrong
