OC'ing a motherboard from 1998(sarcastic)
  • TechGeek
    Computer Geek
    • Jan 2015
    • 2254
    Hi all. I'm OC'ing a motherboard from '98, and I want to show you how it's done. It's going to be awesome, and photos/instructions are coming later.
    Permanently Retired Systems:
    Kooky and Kool Systems
    sigpic
  • dmill89
    • Dec 2011
    • 2534
    Re: OC'ing a motherboard from 1998(sarcastic)
    1998 huh.... Let me guess DIP-switches to set the frequency?
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8711
      I remember swapping crystal oscillators once to overclock... this was circa 1994, however.
      • Heihachi_73
        • Jun 2012
        • 713
        Nothing for a month, is it time to bring out the violins for the brave old Pentium III who wanted to run at two jiggahertz?
        • electromaster84
          • Jul 2015
          • 35
          Why not a K6-III+ at just 1 jiggahertz?
          • TechGeek
            Computer Geek
            • Jan 2015
            • 2254
            Or a Pentium III at 1.2GHz?
            sigpic
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8711
              I overclocked my P3 so much it says %&2 MHz.
              True story.
              Actually it's not really overclocked much. Nor do I don't recall what characters it printed there, but the multiplier and FSB speed combo isn't in the table of supported frequencies so it went past bounds and printed garbage.
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16959
                A pentium3 won't be 1998 era, thats more 2001-ish.
                <--- Badcaps.net Founder
                Badcaps.net Services:
                Motherboard Repair Services
                http://folding.stanford.edu/
                Team : 49813
                Join in!!
                Team Stats
                • mariushm
                  • May 2011
                  • 3799
                  Oh the old times... I remember my first PC ever with AMD K6-2 333 Mhz ( ? x 66 mhz) and overclocking it to 350 Mhz by going with 100 mhz bus and 3.5x multiplier.
                  The board was also one of the best in my country at the time, a PC Chips Elipina m577 : http://www.amoretro.de/2011/11/pc-ch...on_pm9900.html
                  Good times...
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    Good times...
                    I had the same CPU in my first PC, I don't remember the motherboard, but i do remember paying £200 for a 2x CD burner for it.
                    • TechGeek
                      Computer Geek
                      • Jan 2015
                      • 2254
                      O.o
                      Today, you can get a Blu-Ray burner for about $100!
                      sigpic
                      • mariushm
                        • May 2011
                        • 3799
                        A year or so after my parents bought that system with k6-2 cpu (which had a 24x cd-rom) , i was given an older 486 for free which came with a Mitsumi 1x cd-rom on SCSI with the ISA based SCSI card from Adaptec.
                        That was cool stuff, you pushed on a button on the drive's case (similar to the ones on ball point pens) and a cartridge would come out, then you lift the top cover and put the cd in, close the cover and push the cartridge back in.
                        Yeah , it was pretty much this one: https://www.youtube.com/watch?v=CUBeHWVHh9U
                        The guy that owned the company my parents bought the computer from had a 2x external HP CD writer, which was transferring data to the drive using the parallel port.
                        Slow as hell (took something like 40-50 minutes to burn a CD), but quite something for that time.
                        • RJARRRPCGP
                          • Jul 2004
                          • 6304
                          And anyone that encounters a pre-2000s Pentium III is encountering a "Katmai". "Katmai" was the first generation Pentium III that's pretty much a Pentium II with SSE! They aren't socket 370 at all!
                          They are cartridges! (slot 1) "Katmai" came out in 1999, IIRC...
                          ASRock B550 PG Velocita
                          Ryzen 9 "Vermeer" 5900X
                          Arc A770 16 GB
                          eVGA Supernova G3 750W
                          Alienware AW3423DWF OLED
                          • Heihachi_73
                            • Jun 2012
                            • 713
                            I have a 1.2 GHz Celeron from 2001, it's the same HP Pavilion 500a with the dead Bestec PSU that I posted on here a long time ago - sat for nearly a decade, wouldn't work when I took it out of the wardrobe. Found a ton of bloated JPCE-TUR caps that weren't like that when I put it up there. I had a spare SFF PSU for it so it's working again, but it's back in storage since it's all but useless today, and the Intel 810 chipset (82810E) and PCI slots only means it doesn't have a hope of being used for even retro gaming (24-bit on the desktop/GDI and 16-bit in D3D/OGL - no drivers in the world will give this one 32-bit graphics).
                            The other P3s and P3-based Celerons are mostly all Slot 1 though (I have a few other Socket 370s, but nothing to write home about, and most of them also have bad PSUs, all being from that era when caps had the lifespan of a fly).
                            • jiroy
                              • Jun 2016
                              • 2416
                              • Lebanon
                              True story.
                              That what usually happened when a Board Bios was older than a newer design CPU . If the manufacturer is keen on customers welfare , an update would solve the problem , but most just didn't care .
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                The GeForce 4 MX and GeForce FX 5200 were also available in PCI. Just sayin'.
                                A working TV? How boring!
                                • jiroy
                                  • Jun 2016
                                  • 2416
                                  • Lebanon
                                  Add to that the Pci Nvidia GF 6200 LX..
                                  • Heihachi_73
                                    • Jun 2012
                                    • 713
                                    All of those are (or were) worth more than the PC and PCs two generations newer.
                                    PCI video cards were generally always more expensive than their AGP equivalents for some reason. The Intel 815 chipset added support for AGP video cards - on mine, the BIOS already supported AGP, but the 810 chipset didn't and the board didn't even have solder pads for an AGP slot, it had chips and other surface-mounted stuff in that area - I've seen other non-HP 810 boards that actually put the ATX connector there!
                                    • TechGeek
                                      Computer Geek
                                      • Jan 2015
                                      • 2254
                                      talk about proprietary designs
                                      sigpic
                                      • Th3_uN1Qu3
                                        Believe in
                                        • Jul 2010
                                        • 6031
                                        It was an incentive to upgrade mostly. They had to have a bridge chip, but that alone doesn't justify the cost.
                                        • glovecaps
                                          by glovecaps
                                          11-25-2024, 04:23 PM
                                        • Docus
                                          Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                                          by Docus
                                          Hi everyone 😀,
                                          I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                                          To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                                          Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                                          1. I already own the exact same model, but its plastic chassis is badly damaged.
                                          06-10-2025, 04:24 PM
                                        • Archimedes
                                          HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
                                          by Archimedes
                                          Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
                                          Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
                                          Fans are spinning. Blindly could install windows11 and got the device manager...
                                          07-30-2024, 05:14 PM
                                        • dragon3x
                                          by dragon3x
                                          power on.
                                          Here are some examples :
                                          switching supply area).
                                          than 6.3 V.)
                                          03-21-2025, 02:46 PM
                                          ASUS P5GC-MX motherboard recap
                                          by momaka
                                          Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                                          This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                                          So here is what the motherboard looked like with its original caps:
                                          CPU VRM area up close…...
                                          01-27-2021, 11:59 PM
