Changing voltages.
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    Re: Changing voltages.
    Will do. Gonna take the kitten out to play for a bit and then when we get back in, I'll open the PSU up and see what's going on.
    Another way we can test if it's the PSU I guess would be for me to use another PSU. If the BIOS hardware monitor still shows the value jumping around, we could probably assume the PSU is good, right? I'll let you know what the inside of the PSU looks like when I get back.
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
    • ngvuanh
      • Jul 2013
      • 36
      A computer running slow doesn't mean it has voltages problem. There are a lot more factors causing a computer slowing down.
      Electronically, all semi components have marginal working voltages, so if all supply voltages stay within range, it should be fine.
      Let get another hard drive, do a fresh Windows install and compare to current one to see if it make any difference.
      • Spork Schivago
        • Mar 2012
        • 4734
        I took the PSU apart. The caps physically look good. It's gonna be a pain to get to the board so I can remove them to test them. At first, I thought it had some Rubicon caps. But at closer examination, they're Micon. It's weird because the font on them is very similar to a Rubicon.
        The PSU is made by a company I've never heard of, Okia. It's 450 watt.
        • Spork Schivago
          • Mar 2012
          • 4734
          I understand that a computer running slow doesn't mean voltage problems. And why would I replace the hard drive if it isn't bad? There's plenty of programs out there to read the SMART data and everything. I had just noticed the voltage jumping around in the BIOS (along with the fan speed) and had questioned if that was normal, before I went through and replaced the thermal paste, backed up the data, formatted and did a clean install.
          Thanks.
            • 31047
            take some psu foto's
            • ChaosLegionnaire
              HC Overclocker
              • Jul 2012
              • 3264
              • Singapore
              #26
              uh oh, junk/unknown brand caps in a junk/unknown brand psu? will have to assume the psu is faulty by default due to that reason. replace with a known good working japcap psu or post photos of the psu like stj said to see if its worth recapping the psu. caps can go bad without bloating especially junk/unknown brand caps! so dont assume the caps are fine unless that can be proven with an esr meter.
              • Spork Schivago
                • Mar 2012
                • 4734
                #27
                I hooked up my 20-pin PSU. Definitely a difference. The 20-pin is an el-cheapo as well, but Vcore bounces around 1.208v, 1.216v, 1.224v. After a good 30 seconds or so, 3.30V changes. 3.392v, 3.408v. Very seldom, 12V changes. 12.144, 12.196V, 12.249V. Most of the voltages seem stable now. 3.30, 5 and 12 aren't going nuts like before. Fan speed is still jumping. With the 24-pin one though, they changed much, much faster.
                It's like this now, Vcore changes multiple times real quick like. After so many times, 3.30V changes. After 3.30V changes so many times, 5.00V changes and 12V changes. Before, I could watch them all change all at once. Now I have to wait a good while for something besides Vcore to change.
                Do you guys think I should assume bad PSU at this point in time and just have him replace it with a better one?
                • Spork Schivago
                  • Mar 2012
                  • 4734
                  #28
                  Yeah, I agree that they can go bad without bloating. I just don't think it's worth replacing them. The amount of money it'd probably cost, the time involved in replacing them vs just buying a reputable PSU. You were posting around the time I was so I think you answered my question.
                  Any brands you recommend? I bought one of those EVGA PSU's not too long ago for a customer because it was cheap. This customer doesn't have a lot of money...
                  • Spork Schivago
                    • Mar 2012
                    • 4734
                    #29
                    A lot of *con caps I guess! The big ones are Canicon! The little ones, Micon. Both seem to use a font similar to Rubicon. I guess people like having the word con in their capacitors name!
                    • Spork Schivago
                      • Mar 2012
                      • 4734
                      #30
                      One of the ceramics look a little toasty. It's between the heatsink / a 1/4 resistor (or some other big type resistor) and some of those little transformers. It's dark in colour.
                        • 31047
                        that's a POS, i doubt it could out more than 250w safely!
                        if vcore is jumping, you need to turn to the caps on the mobo around the cpu next.
                        • Spork Schivago
                          • Mar 2012
                          • 4734
                          #32
                          Okay. And for that, I need to wait until my new iron comes in the mail. My 40 watt just isn't high enough to heat up the solder. I can always get one side, but the other side, it's always a no go. The board gets real hot so I'm pretty sure the plane is acting like a heat sink and a higher wattage iron will help.
                          Do you have any good suggestions on a PSU Stj? Or anyone for that matter?
                            • 31047
                            something made by SeaSonic.
                            lets have some motherboard foto's
                            • Spork Schivago
                              • Mar 2012
                              • 4734
                              #34
                              So I'll probably suggest this one for him:
                              http://www.newegg.com/Product/Produc...-074-_-Product
                              It's a SeaSonic S12II 430B 430 watt ATX12V V2.3/EPS12V 80 PLUS BRONZE Certified Active PFC Power Supply.
                              I wish some of the modular systems were a bit cheaper. He doesn't need anything fancy. He uses onboard video, no gaming. Just e-mail, weather, maybe on-line banking. He's retired now but after that whole investors screwing a lot of American's recession thing, his 401K took a huge dive and went down to almost nothing.
                                • 31047
                                http://www.hardwaresecrets.com/seaso...supply-review/
                                review looks good.
                                • Spork Schivago
                                  • Mar 2012
                                  • 4734
                                  #36
                                  Good to go. The board uses the nicer ferrite chokes, not the iron ones. So that's a good sign. I haven't counted how many phases there are yet but I figure I'll concentrate (once I get my new iron) on the voltage regulator circuit. I'll check the caps first. They all look physically good, that was the first thing I did, a physical inspection. So I'll pull them, test the ESR, and if I can't find a leaky one, I'll post some pics and come back here...
                                  Unless you just wanted to see the pics for the heck of it Stj. I appreciate the help with diagnosing the PSU. I'm almost always used to having either a completely dead PSU or one where one of the voltages is completely dead. I'm not used to finding ones that don't supply steady voltage. I'll be sure to keep a lookout for this in future and I'll be sure to test the voltages with a DMM next time I work on a PC.
                                  Thanks!
                                    • 31047
                                    i want to see the type and placement of the caps on the board
                                    • Spork Schivago
                                      • Mar 2012
                                      • 4734
                                      #38
                                      Okay, I will post pictures later today.
                                      I want to make sure I understand all of this now. The hardware monitor shows the vCore voltage, the 3.3v, 5v and 12v. Because the power supply supplies the 3.3v, 5v and 12v, the hardware monitor is reporting what the power supply is supplying, right?
                                      The vCore voltage changes on what CPU is being used so motherboards use a voltage regulator circuit to change the voltage for the CPU, the RAM, etc. Right?
                                      The voltage regulator circuit gets it's power from the PSU though. Is there a chance that once I get a _good_ power supply in there, the vCore will straighten out? If the voltage regulator circuit isn't getting stable voltages, I would think that would affect the various voltages it produces (ie, vCore).
                                      • Spork Schivago
                                        • Mar 2012
                                        • 4734
                                        #39
                                        These aren't the best pictures because the board is still in the case. When I get my iron, I will pull the board and post better pictures for you, unless you want me to take the board out now and take better pictures. These pics will at least show you how the caps are laid out. They're mostly (if not all of them) Evercon and look like the last pic posted (that's not from my board, I googled them).
                                          • 31047
                                          vcore comes from a switching psu on the mobo, it originates from the 12v from the psu.
                                          it should be stable, an unstable vcore = an unstable cpu.
                                          it looks the the 3phase switcher only has 3 caps - cheap bastards!
                                          can you make out the markings?
                                          • Capacitorial
                                            Powersupply has all the voltages - Monitor still no power
                                            by Capacitorial
                                            Hello guys,
                                            I have a Philips 240B7QPJEB. The monitor seems completely dead.
                                            I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                                            On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                                            The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                                            The weird thing is, that the Power LED is powered over the TCON board.
                                            On The TCON...
                                            12-28-2024, 02:12 PM
                                          • gjgib
                                            Help reading schematic voltages input/output
                                            by gjgib
                                            Hello, this might be embarassing since I consider it a dumb question but keeps me kinda stuck sometimes in my journey.
                                            I want to know if there is any post in this forum which explains my questions. A) When, where and how do I know when X voltage line is input or output. Example:
                                            I'm battling with this IC to understand it's voltages. It's from non-turning-on Lenovo Ideapad 3 15iil05 - NM-D461.
                                            I see some lines like +5VL / +5VALW / V9B+ / +3VALW being okay and some others like 1.8VALW / +0.6VS / +2.5V_DDR. I just know that some of them are bad or missing,...
                                            05-06-2024, 08:11 PM
                                          • RossMoodley1967
                                            HISENSE LCD LED TV MODEL HX40N2176F LED DRIVER SN51DP IC PINOUT AND VOLTAGES
                                            by RossMoodley1967
                                            Hello
                                            Need to know the voltages that will be present on SN51DP ic when tv is in standby and when powered on.
                                            Just to elaborate on the problem with the tv 1.set came in with flash of HISENSE logo on screen then back into standby.2. Now tv when plugged in red standby light present to quickly changes to blue but no backlights.3.Then an hour ago i checked again , came on standby and stayed until i pressed the power button which changed to power on (blue)4.As far as the led driver circuit goes voltage at output in standby was 38v , power on led light up voltages rise 58v-68v...
                                            03-01-2024, 06:07 AM
                                          • karlp028
                                            MSI Z390-A PRO missing VCORE voltages
                                            by karlp028
                                            I've got an MSI Z390-A Pro motherboard that starts up fine, but it's missing the VCORE (and VGT) voltages. All of the other voltages are present (e.g. VCCSA, VCCIO) and I know the CPU (i7-9700k) is good. Now, the original PWM controller (UP9521P) had an internal short and I replaced it with a new one. All of the enable signals look good. The problem seems to be the PWM signals going to the MOSFET drivers. I checked them with an oscilloscope and they are all flat 1.5V with no pulses. I don't know why this would be and I'm not sure where to look next.
                                            06-23-2025, 01:25 AM
                                          • lol999
                                            Asus Prime x299 Deluxe - no VCCIO VCCSA voltages
                                            by lol999
                                            Motherboard after starting show Q code 00.
                                            No shorts on any rail ( at last I can't finde any)
                                            All voltage are correct on SIO - 3.3V, PCH power 1V , DDR 1.2V, SPI 8 leg 3.3V
                                            Nothing get hot, PSU starting, all lights came ON....
                                            One thing i can see incorrect is no VCCIO and VCCSA voltages and no main power on CPU.
                                            After deep looking I found dead Synchronous Buck converter CSD97374Q4M that is powering VCCIO for CPU but after replacing it nothing changed. Voltages on it are correct....
                                            This buck converter is PWM'ed by Asus DigiVRM ASP1405I-62T. Can't finde any datasheet...
                                            01-21-2024, 02:25 PM
