Not again....
  • stevo1210
    • Oct 2006
    • 4156
    Not again....
    I have a Toshiba P25-S5093 laptop as some of you may know. This is one of the most expensive things that I own. It was a gift from my really awesome cousin after she didn't want to fix it up and purchased a new lappy. I was in USA at the time so I knew it was either end up in a closet for many years after she got a new laptop so I decided to give it a new home down south in Australia.
    But still.... I don't want to break anything while fixing this issue.
    Lately I've been having a problem with the optical drive. It had this issue a while ago but the problem disappeared for some months.
    The optical drive will read DVDs but not CDs. A few months ago, it would read both CDs and DVDs and could even burn both types of media. Now it only reads CDs. I don't know what I should do, but is this repairable or do I have to buy a new optical drive?. A new optical drive is going to cost me $200 or more which is something I don't really favour.
    Do i need to clean the reading lens or something? I want to fix this drive without having to physically take everything apart and then struggle to put it back together again.
    Earlier this year, I had to take the screen bezel off and tighten/ smoothen the hinges so now that's one issue solved.
    Thanks.
  • zandrax
    Hit and miss
    • Dec 2007
    • 1157
    • Italy
    Re: Not again....
    I had the same issue with an old Pioneer drive into an Acer 1351 portable: at first it read every disc, then it wasn't able to burn dvds; in a few months it couldn't even burn reliabily cds or read (re)writable dvd. Eventually it managed to read only industrial cds (not writable nor rewritable media) and, since cleaning the lens didn't help, I figured out the laser got exausted or damaged.
    Buy a cd cleaning disc (they're cheap, about 7-8 euro [$10-12]) and let it spin; if cleaning doesn't solve the issue, then you have to stand with it (as the portable owner did, since it uses pen drives for data exchange) or buy a new drive.
    Zandrax
    Have an happy life.
    • i4004
      • Oct 2006
      • 2029
      Re: Not again....
      chances are it's irreparable.
      dirty lens probably wouldn't read anything.
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Re: Not again....
        The CD and DVD functions use different lasers and it's not at all unusual for one to go out and the other is still fine.
        Mann-Made Global Warming.
        - Dr Seuss
        • stevo1210
          • Oct 2006
          • 4156
          Re: Not again....
          Damn, if that's the case then I have to spend $200 on a new drive. Is there some way I can burn a CD into a DVD so that I can use it with this laptop?
          Thanks.
          • ant3202
            • Jun 2006
            • 275
            • Singapore
            Re: Not again....
            dun make your life so hard
            buy a new drive bro......
            anyway cd 700MB ,
            dvd 4.7GB, i take single layer one...
            so it is quite a waste, from cd to dvd
            • tiggerific
              • Apr 2008
              • 21
              Re: Not again....
              If it's an ISO file then you can extract the files using winRAR and burn them to a blank DVD. If it's a bootable CD then there are tools available online to make a bootable image using the extracted files, I know I've used them before but I can't recall where I got them...
              Also found this on eBay, much less than $200:
              http://cgi.ebay.com/Toshiba-Satellit...QQcmdZViewItem
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                Re: Not again....
                what is it anyway? some game with copy protection? could make the iso and mount it from the dvd using some utility
                • Leopard
                  • Mar 2008
                  • 109
                  • Finland
                  Re: Not again....
                  High chances that it's something wrong in the drive's hardware but if Toshiba offers firmware downloads you could always try downloading new firmware for the drive.
                  • rounin
                    MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                    by rounin
                    I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                    🛠 Original Issue
                    The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                    ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                    04-19-2025, 01:18 AM
                  • ugamazing
                    Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                    by ugamazing
                    I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                    We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                    12-17-2024, 07:05 PM
                  • shahnld
                    Lenovo legion 5 pro startup issue
                    by shahnld
                    Good day Experts
                    I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                    A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                    And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                    08-24-2025, 12:31 PM
                  • ahmarzo
                    Acer laptop battery draining issue
                    by ahmarzo
                    Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                    Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                    08-02-2025, 06:39 AM
                  • elmark
                    HP 15-cw1002ua strange keyboard issue
                    by elmark
                    HP Pavilion 15-CW1002UA
                    S/N 5CD0251CBC
                    P/N 7KE54EA
                    Hello guys!
                    I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                    It powers on OK and has no other issues except the following:
                    • CAPS LOCK does not work at all
                    • Fn button toggles Flight Mode
                    • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                    • (with SHIFT pressed: 't%' and 'y^' respectively)
                    I initially thought it was a keyboard malfunction (internal short, etc.),
                    but when I press and hold...
                    06-27-2025, 01:10 AM
