Using Zeners to Reduce Fan Speed
  • bgavin
    • Jan 2007
    • 1355
    • Subwoofer engineering/building, wedding photography, electric bass, Hammond keys, 5-string banjo
    I want to experiment with using Zener diodes as voltage drops to reduce noisy 12v computer fans.
    http://www.cpemma.co.uk/diodes.html
    Does anybody know where I can source these diodes in the USA in small quantities, and a resonable price?
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Using Zeners to Reduce Fan Speed
    radio shack?
    digikey for sure.
    just pad the order with caps,ect to dodge the $5 handling.
    • WNG
      • Sep 2006
      • 354
      • cars, bikes, motorcycles, computers.
      PSUs are pretty well regulated. Simple series resistance is all you really need.
      KISS principle is best here. IMO, 50 Ohm resistors are a good start for voltage drops. Put them in series or parallel to get to the desire fan dB.
      “We the willing, led by the unknowing, are doing the impossible for the ungrateful.
      We have done so much, with so little, for so long, we are now qualified to do anything, with nothing.”
      • Harvey
        • Apr 2007
        • 264
        Or you could just connect the fan between the +12 (positive) and +5 (negative) and run the fan on 7V.
        • bgavin
          • Jan 2007
          • 1355
          The 7v solution runs a good risk of smoking the PSU. This warning is well documented on many of the testing sites. For my last parts order, I bought a few of the $1.95 9v solutions using a series resistor. Even if I swap out the resistor later, the cables and three connectors are worth the price.
          The resistor method does work, but limits the startup voltage to the fan. I'm told the Zener allow full voltage at startup.
          The first cadidate for the slow-down is a group of 92mm Panaflo 12H I have in stock. These damn things are irritatingly loud. I bought several because they have the BX tach encoder required by Dell system boards. My daughter is using a Dimension 2350 that I got when I customer got a new machine. I recapped the board and PSU, and it runs just fine... and too loud with the Panaflo.
          I did a cursory look at Digi-Key but didn't find what I wanted. I've never ordered, so I should take a closer look. I need some PSU caps, etc. Wai Fong is flat out of MCZ in the values I need.
          • yanz
            • Nov 2004
            • 910
            Hmm could you share the links? Im interested in this.
            Perhaps using a good psu vs cheap psu makes any differences? Or maybe it's the same dangerous both psus could face if using 7v methode..
            • gonzo0815
              • Feb 2006
              • 1600
              I have such connectors at home, bought them for several years. Never had a single problem.
              ATM i don`t see, why this should pose any risk for anything. As long as there is no short, i don`t think it is dangerous.
              May be some of the smarter people may explain it, why this could pose a risk. Up to then, i think this is one of the modern urban myths, grown on half knowledge.
              • bgavin
                • Jan 2007
                • 1355
                http://www.silentpcreview.com/article6-page1.html
                • yanz
                  • Nov 2004
                  • 910
                  ok, thanks! i'll check it...
                  • Fatal0E
                    • Jan 2004
                    • 252
                    I have a bunch of these 7v adapters, typically work well with good power supplies but I have had many computers not turn on with them hooked up.
                    • bgavin
                      • Jan 2007
                      • 1355
                      Fry's Electronics stocks various Zeners that will do the job. I picked up the NTE5067A in 3.9v, and NTE5069A in 4.7v. They come in two packs for 99 cents per pack.
                      I have a Panaflo 92mm H12 (2850 rpm) that I want to tone down. This one is mounted in the rear of a Dell case, and is objectionably loud. Funny thing, I have the same fan running internally on a Thermalright XP-90 heat sink, and it is very usable.
                      • Babbar
                        1980s Holz Her 2420 belt sander - Only works when speed control at maximum
                        by Babbar
                        My fathers belt sander from the 80s which i very much would like to continue using has an issue with the speed control. The machine works fine on maximum speed but will not turn or give any sign of life when on any other setting. The speed control is a dial going from 1-6 although implemented as a potentiometer without distinct steps. I took the machine apart and measured each component individually, all components and measurements have been captioned in the attached pictures. The Triac did not get identified correctly using my cheapo component tester, i don't know if this is user error, if the...
                        11-13-2024, 01:54 AM
                      • eccerr0r
                        old X58 triple channel board... memtest86 memory speed?
                        by eccerr0r
                        Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                        Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                        Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                        06-28-2025, 09:06 AM
                      • japlytic
                        Maximum speed should be marked on network ports
                        by japlytic
                        I noted that a number of consumer entertainment devices have the maximum speed marked on the wired network port and considering that there are broadband plans faster than 100 Mbit, the wired network port can be a bottleneck since some routers do not have Gigabit (only 100 Mbit) support for the WAN port let alone the wired network ports.
                        One other thing: Certain low cost network cables only have two pairs which limits speed to 100 Mbit.​
                        12-19-2024, 05:04 PM
                      • kleung
                        Dell ultra 7070 ,Foxconn PWM laptop case fan. Spins at 100% speed in failure mode.
                        by kleung
                        I wanted to add to the knowledge base about a PWM case fan that it can fail at 100% speed.
                        On my Dell ultra 7070 (this is a 0.6 L pc so uses laptop parts); I had the case fan suddenly go 100% and I couldn't control it. I disconnected/reset bios and it was only solved when I swapped in a replacement fan.
                        I have tested and there is continuity between the 4 wires pins and the circuit board.
                        That is the extent of my troubleshooting. I took pictures of the circuit board but don't know what component would die (PWM controller?) that could cause this to happen....
                        12-07-2024, 01:45 AM
                      • armands0212@gmail.com
                        Alienware 13 r1 base speed of cpu higher than should be
                        by armands0212@gmail.com
                        Hi guys.i have alienware 13 r1 with weird thing what i cant understan
                        Basically laptop is freezing every time if nvidia gpu is enabled and laptop is on battery power,however it working just fine pn ac power
                        So i wanted to sort this out as thats quite annoying as i need to disable nvidia to use it on battery or use it only with power cord-i already tried change battery,update drivers,change power setting,update bios,install windows 10 and windows 11, but nothing helps it still will freeze on battery
                        What i noticed that cpu speed in bios is 1.70ghz but...
                        06-18-2023, 01:07 PM
