GA-C7V7VX-RH Not Wanting To Work With Ide Drives
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Just finished building a small itx rig based off this gigabyte motherboard. However its not working properly, it wont let me boot off a Ide drive, also it wont let me install windows on to any drive either windows says the Bios wont let it.
    I have gone through the Bios and made sure no virus or write protection is on and its not, if I try to boot with a Ide drive it gives an error saying this "SW NOT SUPPORTED" however if I turn the Ide channel master to manual from auto it will boot however still wont let me install anything to the flipping drive.
    This board originally come with a small apacer idea ssd drive (only 64mb) which still boots fine but wont let me boot any hard drives.
    Any one have any ideas on this ?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: GA-C7V7VX-RH Not Wanting To Work With Ide Drives
    i think it used to be a thin client. Are you using separate IDE channels ? have you got the jumpers set correctly ?
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      It was for some school in Manchester, the jumpers on the Hdd are the for master only. This normally works what should it be set to ? Also there is a Comb port on the board however I cant seem to find out what the pins on it do.
      • diif
        • Feb 2014
        • 6978
        • England
        Are the IDE hard drive and CD ROM showing up in the BIOS ?
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Yes they show up, the Cd rom works however this thing just wont load the hard drives. The hard drives both show up properly. Thats why im so confused :L
          • diif
            • Feb 2014
            • 6978
            • England
            Have you tried with just one hard drive ?
            I'll have a quick look through the manual. Its been a while since I've had boot problems with IDE or even used IDE and my brain is a little slow after looking through a microscope all evening wrestling with a dead laptop.
            Something to do with the thin client booting I think.
            Beer time I think.
            Bear with my Reecey.
            • diif
              • Feb 2014
              • 6978
              • England
              What OS are you trying to load ?
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Nice one my friend
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Also the Hard drives are formatted, it wont even let me get to the boot up stage if they are connected. Im loading windows 7 32bit off a Usb drive. I say hard drives as I have 2 connected but it does the same even with one just says "SW NOT SUPPORTED".
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    The motherboard might not support USB boot. Does it show up in the boot order ?
                    • Uranium-235
                      Comrade Glimmer
                      • Aug 2007
                      • 5042
                      • US
                      USB emulation is sometimes required for older drives to boot the installer, make sure it's enabled in the cmos
                      are we talking about ribbon cable ide drives? some WD drives require a "only drive" jumper setting (not master or slave). Make sure the drive in on an 80 wire cable and on the end connector
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        I dont think you understand what im saying, its nothing to do with booting from a Usb. When ever I plug an Ide hard drive in (even with out the usb) the bios goes into halt mode when ever its set on auto scan for the drive but if I change that to manual meaning the Os loads data to the drive it boots, however even this I still cant load anything to the drive in windows or linux it says that something in the bios for the Hdd controller is wrong but it all seems fine ?
                          • 31201
                          does it have sata?
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            Maybe a photo or two would assist us Reecey.
                            Stj, I think is the thin client version of the motherboard without SATA.
                            Might be the reason for the error, possibly a custom BIOS.
                              • 31201
                              but if it does have SATA, maybe ide emulation is enabled re-directing all the ide calls to the wrong ports.
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                There are spots for sata ports however they are not soldered and the additional components for them are not installed. Will get you images in a while chaps
                                • artois7
                                  • Mar 2011
                                  • 159
                                  The exact errors on screen would help.
                                  • diif
                                    • Feb 2014
                                    • 6978
                                    • England
                                    http://www.parkytowers.me.uk/thin/vxl/itona/C7V7.shtml
                                    Windows 7 on a 1Ghz VIA running off an IDE HDD.
                                    Rather you than me buddy
                                      • 31201
                                      hmmm
                                      Bin Sun discovered that the latest BIOS for his TC2331 refused to boot anything from the hard disk he installed. It stopped with the message:
                                      SW not supported, system halted
                                      It turned out that the last TC2331 BIOS specifically will not boot from anything on the IDE interface that is larger than 64MB. (The BIOS release notes indicate that the previous version just applied this restriction to the master drive, not the slave). His solution was to flash the motherboard with the BIOS from the TC4331. (Both models use the same motherboard).
                                      • ReeceyBurger123
                                        Never Give Up !
                                        • May 2014
                                        • 7325
                                        • Britain
                                        Haha sorry for the slow update chaps been put aside Also I put win7 on a socket A Athlon ran quite fast tbf lol have a good Christmas will update all soon
                                        • Neddsme
                                          Bios partially corrupted somehow and now warm boot doesn't work which is critical
                                          by Neddsme
                                          Hie.
                                          I own a Lenovo ideapad v310-15IKB with an i5 7th generation with only Intel graphics configuration.
                                          Now the heart of the problem is that I don't know when or how it happened but I suddenly started getting distortion in the graphics output on the LCD. This basically meant a black screen full of flickering multicolored short horizontal lines. This would happen 30-60 minutes after booting and using it normally.
                                          I run Windows 10 20H build so I thought it was just a Windows update issue or graphics driver outdated issue.
                                          I managed to run Windows troubleshooting and...
                                          02-04-2022, 05:57 AM
                                        • Luke Anders
                                          Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
                                          by Luke Anders
                                          A few details about the laptop itself:
                                          Name: Lenovo Legion 5
                                          Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
                                          BIOS Version: GKCN60WW
                                          EC Version: GKEC65WW
                                          Serial Number: PF39AQ7Z
                                          Board Model: NM-D562 Rev 3.0
                                          RAM: 16GB Installed, DDR4 (brand new)
                                          NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
                                          I bought this laptop recently from eBay as a faulty device....
                                          10-12-2024, 05:13 AM
                                        • hinisa
                                          Xiaomi router freezes at boot after re-capping
                                          by hinisa
                                          I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                                          When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                                          After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                                          Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                                          07-08-2023, 05:58 AM
                                        • MullySculder
                                          A1989 EMC3214 can't boot to USB drives due to T2 but SSD can't be initialized and Macbook freezes then reboots in recovery
                                          by MullySculder
                                          Hey folks, I'm working a 2018 13" Macbook Pro that I can't get to install an OS on.
                                          This was given to me by a friend who told me I could have it, if I fixed it.
                                          I've noticed a couple of dents on the laptop case and the touch bar doesn't have any activity lights when first turning on. When I boot up the machine, it gives a folder with a question mark. When I do eventually get to internet recovery with High Sierra, I can go to Disk Utility but I'll get errors when I try to erase the 512GB SSD. First Aid comes back with no issues. But if you linger too long on anything,...
                                          07-10-2024, 02:17 AM
                                        • claws77
                                          FX553VE-DM318T(FX553v) not POSTING
                                          by claws77
                                          Cpu i7-7700hq Ram - 8gb samsung, 32 gb sk hynix
                                          Gpu - nvidia geforce 1050ti
                                          Ssd orion o700
                                          Hdd hgst721010A9e630
                                          See images
                                          What's not working right?
                                          The system does not even POST, display is black,
                                          LEDs on - power led, aiplane mode, capslock fpr few seconds in the start(when connected to ac power) only.
                                          When did the problem happen?
                                          My laptop had dual boot setup, ubuntu and windows 10.
                                          It already had a moklist error, that would occur when i tried to boot ubuntu.
                                          05-17-2025, 04:09 PM
