Best thermal interface material?
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    I've been using Arctic Silver 5 for more than a decade and I've been satisfied with its thermal conductivity and also its long term endurance.
    Nearly everyone in this forum has experienced the situation of CPU heatsink removal leading to CPU removal, because the cheap TIM had gone completely dry. After separating them carefully with a screwdriver, the cleaning of CPU / cooler would be difficult too.
    This has never happened to me with Arctic Silver 5.
    Now I feel it's time for a change. AS5 is quite old and many products with better results are available. I am running out of AS5 anytime soon.
    What is the best thermal interface material out there?
    Thermal conductivity is not the most important factor though, because it is pointless to gain 2 to 3°C at first, if the TIM is gradually deteriorating from thermal cycles, high temps and stress and after a couple of years becomes dried up and sticky leading to laptop / desktop overheating.
    So, I am interested in your long term experience with different pastes. There are products with excellent thermal conductivity that had proven to be corrosive to copper or making scratches to CPU surface. I can't risk using anything like that.
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: Best thermal interface material?
    Im staying with AS5 personally...
    Follow the white rabbit.
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16959
      AS5 gets my vote as well. Been using it for years without any complaints.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        AS5 here too. If there is something better, it's news to me.
        sigpic
        (Insert witty quote here)
          • 31285
          i was using as5, but for cost reasons, i just got some MX4.
          it's supposed to be pretty similar, but it's based on carbon rather than silver.
          because when your doing ps3's you use a hell of a lot of paste!
          so a 20g pack sure beats a 2.5g or whatever one!
          • Compgeke
            • Feb 2014
            • 524
            I've been using Ceramique 2. A fair bit cheaper than AS5 and unless you're doing some odd insane overclocking you won't notice a difference in temps.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              As 5 here too !
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                Been using AS5 since forever but since my tube dried out (it's a big tube that is several years old)
                I've now bought something called Gelid GC-Extreme
                It's cheaper and according to reviews performs a bit better.
                Of course no idea about if the long term stability is as good as AS5.
                Already managed to misplaced my first tube too so ordered a new one that arrived today.
                Fantastic eh?
                • ChaosLegionnaire
                  HC Overclocker
                  • Jul 2012
                  • 3266
                  • Singapore
                  i would recommend arctic mx-4 and gelid gc-extreme too. u can also try shin etsu x23-7783d if u can ever find it but no promises on its long term reliability! all three perform equal to or even better than as5 if u apply them right.
                  the gelid paste comes with a spatula for helping u to apply the paste so no excuses for poor thermal paste application skillz!
                  • Dan81
                    SNES-powered
                    • Oct 2013
                    • 1866
                    I know that it's not that common but I'd recommend Spire SP-456/1G.
                    It does wonders for me,regardless of the platform.
                    Even for 3GHz Prescott HT Pentium 4 systems.
                    Main rig:
                    Gigabyte B75M-D3H
                    Core i5-3470 3.60GHz
                    16GB DDR3-1600
                    Samsung SH-224AB DVD-RW
                    Delux MG760 case
                    • Uranium-235
                      Comrade Glimmer
                      • Aug 2007
                      • 5045
                      • US
                      I used AS5 on a skylake i7-6700K (naitive 4ghz clock) just monday
                      idle was about 39c, prime 95 burn maxed about 86c before the fan dropped it out average about 82c
                      • rievax_60
                        • May 2012
                        • 897
                        • australia
                        I use Arctic Cooling MX2. I notice that the original substance used in almost all laptops exactly resembles hardened MX2 or similar.
                        • xelectech
                          retired tech
                          • Nov 2014
                          • 238
                          Being perpetually short on funds, I've been using Radio Shack's silicone based heat sink compound for years now, seems to be sufficiently effective for everything I've used it on so far (PC's, amplifiers, PSU's); even used it to replace thermal glues and tapes,
                          ymmv
                          • RJARRRPCGP
                            • Jul 2004
                            • 6304
                            Looks like the heatsink may not be seated properly.
                            ASRock B550 PG Velocita
                            Ryzen 9 "Vermeer" 5900X
                            Arc A770 16 GB
                            eVGA Supernova G3 750W
                            Alienware AW3423DWF OLED
                            • goodpsusearch
                              • Oct 2009
                              • 2850
                              • Greece
                              ymmv
                              From my experience this no name stuff is of low quality that hardens and dries up as it deteriorates gradually making PC overheating.
                              If you are on a budget, there are some value for money thermal pastes available:
                              Arctic MX-4 20g
                              http://www.ebay.com/itm/Arctic-MX-4-...gAAOSwymxVNAts
                              I found it locally for 15€.
                              I also found Arctic MX-2 30g for 19€.
                              Another decent and cheap paste: Arctic Ceramique 2 25G:
                              http://www.ebay.com/itm/GI2703-Arcti...oAAOSwu4BVnUAR
                              Available in Greece for just 7 €!
                              I would never risk using an unknown paste. Durability is critical.
                                • 31285
                                look at the sellers postage details - very strange!
                                http://www.ebay.co.uk/itm/361421463688
                                http://www.ebay.co.uk/itm/181909219317
                                • xelectech
                                  retired tech
                                  • Nov 2014
                                  • 238
                                  >From my experience this no name stuff is of low quality that hardens and dries up as it >deteriorates gradually making PC overheating.
                                  Haven't experienced that yet with the RS stuff, which, price-wise compares to the
                                  AS Ceramique 2, approximately (the RS stuff comes in 6.5 gram tubes). I wonder if the actual ingredients are all that different between the two, I tried to take a pic but the
                                  printing is too small, so thought I'd list 'em in case it's of interest:
                                  polydimethylsiloxane, zinc oxide, polytetrafluoroethylene, fumed silica.
                                  Now I'm wondering what all was in that zinc-oxide heatsink compound that was used back in the 70's.
                                  Arctic MX-4 20g
                                  Thanks for listing some possibilities.
                                  I guess the only way to see how good it is is to use it till it fails 8-).
                                    • 31285
                                    zinc oxide is something you need to keep off your skin and out of your lungs.
                                    • trebo
                                      • 514
                                      • Wales, UK
                                      That sure don't make any sense
                                      • LDSisHere
                                        • May 2012
                                        • 727
                                        • U.S.A.
                                        I use the same as you get lots more bang for your buck and there is no real difference in performance.
                                          MSI Trident 3 Arctic 9SI-618EU Trident 3 Arctic i7-9700F Specification for Upgrade or Repair
                                          This specification for the MSI Trident 3 Arctic 9SI-618EU can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Trident 3 Arctic 9SI-618EU boardview and Trident 3 Arctic 9SI-618EU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-12-2024, 03:28 PM
                                        • Gcnewbie
                                          Dell Latitude 5570 Ambient thermal sensor reading -127 Degrees C
                                          by Gcnewbie
                                          Forgive me this is my first request for help on this forum, so if i've screwed up or not followed the rules i should have i apologise profusely.
                                          I have a Dell Latitude 5570 that was randomly shutting down, on further investigation i found that the machine had been shutting down due to thermal events as noted by windows event viewer.
                                          My investigations lead me to the dell diagnostics screen, where i found that there were two sensors out of range which had been causing the shutdowns, one of which was the GPU thermal sensor and the other the ambient sensor.
                                          I opened the...
                                          03-29-2024, 06:55 AM
                                        • Veyron7887
                                          Laptop overheating after replacement thermal paste
                                          by Veyron7887
                                          Hi. I have Asus X55C laptop from year 2013. It has i3-2328M CPU. I replaced stock thermal paste with high quality thermal paste. Before thermal paste replacement, I measured CPU temperature Around 65-70 degrees Celcius with stock thermal paste. If after the replace thermal paste, I measured CPU temperature around 80-84 degrees Celcius and fan don't stop when system is idle. I replaced the thermal paste several times but still did not change. Where is the problem?
                                          11-24-2024, 05:08 AM
                                          MSI Trident 8RB-094UK Trident 3 Arctic i5-8400 Specification for Upgrade or Repair
                                          This specification for the MSI Trident 8RB-094UK can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Trident 8RB-094UK boardview and Trident 8RB-094UK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          ALIENWARE Aurora R7 i7-8700K Specification for Upgrade or Repair
                                          This specification for the ALIENWARE Aurora R7 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aurora R7 boardview and Aurora R7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ALIENWARE Aurora...
                                          09-12-2024, 03:36 PM
