Best thermal interface material?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Best thermal interface material?
    Originally posted by trebo
    That sure don't make any sense
    European sales. They have it here http://www.ebay.co.uk/itm/Arctic-MX-...item58c33a4e51
      • 31281
      that's one clumsy add, look at the item specifics!
      • ChaosLegionnaire
        HC Overclocker
        • Jul 2012
        • 3266
        • Singapore
        for the best white silicone thermal compounds, try anabond and servisol. they come in big 50-100g tubes and cost only a few bucks.
        • Hondaman
          • Sep 2008
          • 1092
          I have been using Arctic Silver 5 for years, but I don't overclock - I just surf the Net, do very basic office stuff, and that's about all. I have a tube of Radio Shack CPU paste, I probably only used it once. I still have it.
          • hikaruichijo
            • Aug 2015
            • 123
            • Spain
            I've been using the Gelid GC-Extreme for two years and it is giving better results to me than AS5 but it is a bit hard to work with it, it is to hard at ambient temperature.
            • ChaosLegionnaire
              HC Overclocker
              • Jul 2012
              • 3266
              • Singapore
              #26
              might wanna turn up the heater in your room in that case if applying thermal paste. warmer ambient temps should soften it a little, making it easier to spread with that spatula they gave.
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                I never use a spatula; I use the heatsink itself to do the spreading. Less risk of air bubbles that way.
                sigpic
                (Insert witty quote here)
                • xelectech
                  retired tech
                  • Nov 2014
                  • 238
                  Hey, happy holidays to all.
                  Thought I'd add a data point regarding the RS thermal compound - I have an AMD Athlon-64 based machine that I used that heatsink compound on about 4.5 years ago. I had to replace a few bulged caps in it yesterday and decided to redo the heatsink - the old stuff was fairly-well dried out, so it was time. I'd gotten used to the processor always running in the low to mid 40's, now it's cruising along in the low to mid 30's.
                    master hoarder
                    • May 2008
                    • 12175
                    #29
                    Originally posted by goodpsusearch
                    So, I am interested in your long term experience with different pastes.
                    I am using cheap thermal compound that I bought from eBay about 5 years ago. Not sure what brand it is, but it has "HC-151" written on the label. It's a 30 gram tube and I think I paid something like $5 for it.
                    Basically, I decided to try it out as an experiment. It is probably the most oily and runny compound I have ever used... but it works! And when I say that, I mean it works quite well. Maybe not as good as Arctic Silver, but definitely a respectable performance .
                    The best part is that it doesn't matter how thick of a layer I apply. Because it is very runny, the heatsink pressure always thins it out to just see-through thickness. Thus, I get pretty good temperatures with it - both on small, exposed-die CPUs/GPUs as well as CPU and GPUs that use a heat-spreader.
                    Also, it doesn't seem to dry out over time, unlike some other generic thermal compounds I've used in the past (*cough* Spectra Cool *cough*). The oldest application was on an Athlon 64 3200+ CPU about 3 years ago. Last I checked it, the compound was still wet and oily under the heatsink. Didn't even bother re-applying new compound after that. Instead, I simply collected the excess on the side of the CPU and put it on the CPU heat spreader again. Guess what? Temperatures were still the same afterwards (45C at full load in a 28C room temperature, with a 500 MHz overclock at stock voltage). Compared to my other Athlon 64 systems that use the same CPU and heatsinks but with stock AMD thermal pads, I get slightly lower temperature with the cheap compound by 2-5 degrees C.
                    Also appears to work well even with tiny GPU/CPU dies. In fact, I just did a Radeon HD 2400 about a month ago. The temperature was about 5C lower with the new compound vs. the stock ATI pink bubble gum stuff (50-63C idle/load before, 45-55C after, both with closed case at 18C room temperature).
                    All of that said, though, I definitely won't say that every cheap thermal compound online is this decent. Back in 2007, I bought what appeared to be some of the first cheap thermal compound on eBay. I think it went by the name of Spectra Cool. Now that stuff was complete garbage. It was just borderline soft enough to use. I could swear at moments that it was just chalk and water. I did a few GPUs and CPUs with it too (namely another Radeon 9700 and a Duron 750 MHz s462 CPU). The compound dried on both of them within a year. The Duron 750 MHz CPU was powered ON maybe only about 3 times and did no more than 4 hours total.
                    On a different note, I also tried some "diamond" thermal compound before in the repair shop I used to work. My boss said to use it for the PS3, since he thought it would help with heat dissipation from those phat PS3 CPUs/GPUs. The compound claimed extremely good thermal conductivity on the box. However, I didn't like it at all. Not only was it very pricey, but it was also very thick and hard to spread. Almost about the consistency of tar. Because of that, I don't think the compound was too effective. No way to measure the temperature on a PS3, though, so I can't say for sure. But IIRC, a few did come back with overheating issues (again).
                    Originally posted by Compgeke
                    I've been using Ceramique 2. A fair bit cheaper than AS5 and unless you're doing some odd insane overclocking you won't notice a difference in temps.
                    Originally posted by LDSisHere
                    I use the same as you get lots more bang for your buck and there is no real difference in performance.
                    Yup, AS Ceramique 2 is definitely decent stuff. Used it on many Pentium 4 Prescott HTs computers a few years back for a small-medium size office (about 40 PCs or so). No heat issues whatsoever.
                    However, there was another guy in that place that also did some of those PCs, and many of them ran their CPU fans at near 100%. Reason why is because he applied too thick of a layer. Ceramique 2 is somewhat thick, so it needs to be spread well into a thin layer in order to perform well. The CPUs were overheating and throttling back with the thick compound layer on there.
                    i would recommend arctic mx-4
                    That's another good one. I have a few tubes with some leftover compound from a friend of mine. It's not too runny and not too thick either - actually just the right viscosity, IMO. That said, I still like my cheap eBay compound better .
                    Nearly everyone in this forum has experienced the situation of CPU heatsink removal leading to CPU removal, because the cheap TIM had gone completely dry.
                    I've had that happen with fresh thermal compound as well. Namely, it was with a thick layer of Ceramique 2. The same guy I mentioned above had worked on the system before me.
                    To prevent this from happening, you should never pull up on the heatsink. Only twist and lift one corner, while simultaneously pushing the corner diagonally-opposite down. If the heatsink doesn't want to move at all, it may help to heat it up with a hair dryer for a little bit.
                    I've never lifted a CPU since.
                    Now that's more like it!
                    The temperatures for my Athlon 64 systems are pretty much all like that - at least the ones I did with my cheap compound as well.
                      MSI Trident 3 Arctic 9SI-618EU Trident 3 Arctic i7-9700F Specification for Upgrade or Repair
                      This specification for the MSI Trident 3 Arctic 9SI-618EU can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Trident 3 Arctic 9SI-618EU boardview and Trident 3 Arctic 9SI-618EU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-12-2024, 03:28 PM
                    • Gcnewbie
                      Dell Latitude 5570 Ambient thermal sensor reading -127 Degrees C
                      by Gcnewbie
                      Forgive me this is my first request for help on this forum, so if i've screwed up or not followed the rules i should have i apologise profusely.
                      I have a Dell Latitude 5570 that was randomly shutting down, on further investigation i found that the machine had been shutting down due to thermal events as noted by windows event viewer.
                      My investigations lead me to the dell diagnostics screen, where i found that there were two sensors out of range which had been causing the shutdowns, one of which was the GPU thermal sensor and the other the ambient sensor.
                      I opened the...
                      03-29-2024, 06:55 AM
                    • Veyron7887
                      Laptop overheating after replacement thermal paste
                      by Veyron7887
                      Hi. I have Asus X55C laptop from year 2013. It has i3-2328M CPU. I replaced stock thermal paste with high quality thermal paste. Before thermal paste replacement, I measured CPU temperature Around 65-70 degrees Celcius with stock thermal paste. If after the replace thermal paste, I measured CPU temperature around 80-84 degrees Celcius and fan don't stop when system is idle. I replaced the thermal paste several times but still did not change. Where is the problem?
                      11-24-2024, 05:08 AM
                      MSI Trident 8RB-094UK Trident 3 Arctic i5-8400 Specification for Upgrade or Repair
                      This specification for the MSI Trident 8RB-094UK can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Trident 8RB-094UK boardview and Trident 8RB-094UK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                      ALIENWARE Aurora R7 i7-8700K Specification for Upgrade or Repair
                      This specification for the ALIENWARE Aurora R7 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aurora R7 boardview and Aurora R7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ALIENWARE Aurora...
                      09-12-2024, 03:36 PM
