Emachines T5088 - CMOS/checksum random errors
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3266
    • Singapore
    Re: Emachines T5088 - CMOS/checksum random errors
    Originally posted by momaka
    Bad caps likely won't cause this issue
    umm, i have to disagree and say that badcaps can cause the issue of cmos settings resetting as i experienced with my asus p4c800 that had a board full of osts. only when i fully recapped all of the osts off the board did the problem of the cmos resetting go away and i have ruled out that its not my power supply, bad battery, poor battery contacts or esd issues as i did not tinker with it to cause it to throw up cmos errors.
    therefore, my point is that bad caps on a motherboard and cause the board to throw up all sorts of weird issues. so anyway the ts must get rid of all the possible bad caps on the board including the 6.3v filter ones scattered around the board. its also possible that a crappy power supply can kill caps on the board and then cause the board to behave strangely due to the board's caps going out of spec.
    • caphair
      • Nov 2011
      • 1249
      Thanks for that response momaka. I've checked battery terminals and they seemed fine.
      I'm wondering if the CMOS issue is somehow related to the computer randomly restarting itself like the owner claimed? It seems to be running cooler as I stated to have cleaned dust and replaced thermal compound.
      • SteveNielsen
        Retired Tech
        • 2327
        Overheating CPU can cause a lot of different symptoms, restarts are a common one. Not sure about it affecting CMOS but it wouldn't surprise me.
        • caphair
          • Nov 2011
          • 1249
          But it's not overheating, that was my initial thought due to ramping of the CPU fan but even after cleaning and change of thermal compound it still randomly restarted after been left on for some time. That's where I'm stumped
            • 31303
            if you only get this issue with the psu removed or unplugged, i'v had it before.
            you need to trace the battery + though to the chip.
            it could be a bad diode, but in my case it was a coroded track.
            • caphair
              • Nov 2011
              • 1249
              #26
              I'll try that. What I'm questioning though is if the CMOS issue could be related to the random restarts or if that's a separate issue.
                • 31303
                seperate.
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  #28
                  Interesting.
                  So bad caps can cause anything then. I guess the O/P really needs to replace the caps on this board then - the KZGs, that is.
                  • Genghis_Khan
                    ThinkPad T470p – CMOS Checksum Error Persists After Main Battery Removal (even with new CMOS)
                    by Genghis_Khan
                    I’m currently troubleshooting an issue on my Lenovo ThinkPad T470p (Type 20J6) and would really appreciate any insights or solutions.
                    Issue summary:
                    Whenever I remove the main laptop battery and AC adaptor, then place them back, the system gives a “CMOS checksum error” at next boot, and the BIOS clock resets to its default time/date.
                    However, the RTC works fine as long as the main battery remains attached — even if the laptop is unplugged for hours. Same as I remove the battery while the AC is attached, RTC remains. Obviously,...
                    11-11-2025, 11:51 AM
                    ACER eMachines PT.NCAE2.071 eMachines EL1850 E5800 Specification for Upgrade or Repair
                    This specification for the ACER eMachines PT.NCAE2.071 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the eMachines PT.NCAE2.071 boardview and eMachines PT.NCAE2.071 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    09-12-2024, 03:36 PM
                  • dmill89
                    Emachines T3104 "Sleeper"/random parts build.
                    by dmill89
                    I decided to see what kind of "sleeper" build I could do on the Emachines T3104 from cheep/free thread with the "random junk" I had laying around (with the exception of a SATA to IDE adaptor I bought to make the original Emachines optical drive to work).
                    Before:
                    Specs:
                    Motherboard: FIC K8M-800M
                    CPU: AMD Sempron 3100+
                    RAM: 512MB DDR-400 (2x256MB)
                    GPU: Integrated VIA Unichrome Pro
                    PSU: HiPro HP-P3527F3 300W
                    HDD: None/removed (case sticker indicates it originally had a 100GB IDE HDD)
                    ODD: Lite-On DVD-ROM/CD-RW...
                    01-23-2023, 09:06 PM
                  • Caimano
                    hp Pavilion 14 CE-1XXX 5 fast 3 slow blinks or cmos checksum error if restarted immediately after shutdown or suspend
                    by Caimano
                    MB G7AD-2G DAG7ADMB8D0 REV D
                    Processor i5 8265U
                    AFAIK schematics or boardview are not available for this MB, but I used a similar board as a reference (G7AL-2G)
                    Laptop came in not booting with caps lock blinking 3 fast- 2 slow indicating RAM error. Charging works fine. Found bad soldering on the only ram socket present (2 outer left pins and 2 outer right pins).
                    Once soldered the laptop started fine and I was able to install Windows 11, upgrade BIOS to version F30 from Windows without a problem, BUT I found a strange and annoying...
                    02-06-2024, 10:14 AM
                  • questore
                    XPS 13 9370 CMOS battery voltage always low
                    by questore
                    Hi Everyone,
                    I have brought you a mistery item
                    This laptop have come with some strange faults.
                    1. CMOS battery was flat 0v
                    Symptoms:
                    - After using the laptop and shutting down and removing the AC adapter for at least 1 minute, the laptop never turned on until EC reset (either shorting RTC or removing battery and long pressing power button)
                    Amp drawing was stuck at 0.005 milliamps.
                    - Laptop cannot really be turned off because it autostarts about 5 sec-1 or 2 minute. (lid sw is not the problem)
                    After inverstigation RTCD1 diode had a low value...
                    09-30-2025, 05:47 AM
