Zotac mainboard needs PSU with 8-pin mobo connector
  • binsonk
    • Apr 2014
    • 182
    For my Zotac GeForce 9300 mainboard, I need a PSU with an 8-pin motherboard connector. This PSU is hard to find and expensive. An adapter is available to combine with a 4-pin mobo connector to make it an 8-pin. Does anyone have experience with these $5 adapters, or would it be better to buy a PSU with the 8-pin mobo connector?
  • Compgeke
    • Feb 2014
    • 524
    Re: Zotac mainboard needs PSU with 8-pin mobo connector
    For the most part you can just plug the 4-pin into the 8 and it'll work fine, just don't expect overclocking and such to be stable. I've never known a board that won't work using a 4 in the 8.
    • binsonk
      • Apr 2014
      • 182
      The 4-pin mobo connector only fits in slots 5 to 8. Is that normal? IIRC, the 4-pin PSU did not work, but an 8-pin PSU did work. Unfortunately, I only borrowed the 8-pin PSU, and lost the opportunity to buy it.
      I just powered it up with the 4-pin in slots 5 to 8. I got a display but the fan did not work. The CPU fan gets power from a connection on the mobo.
      • c_hegge
        • Sep 2009
        • 5219
        I had an Intel D975XBX2 which would refuse to POST if you used a 4-pin CPU connector. The majority of motherboards, though, will work fine with only 4 pins connected.
        The thing is, though, virtually all new PSUs have an 8 pin EPS12V CPU connector, so I don't know what you meant by hard to find and expensive.
        see http://www.newegg.com/Product/Produc...82E16817151148. Dirt cheap, reasonable quality and it has the connector.
        • binsonk
          • Apr 2014
          • 182
          Thanks for the link, c_hegge. It's sort of the point of this query to find out about the even cheaper adapter.
          • c_hegge
            • Sep 2009
            • 5219
            It would probably work too, but I prefer to avoid using adapters where possible in favour of a PSU which has all of the required connectors
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              Get a used unit with an 8 pin. They used it for a reason, and that is current draw. Otherwise, especially with heavy use, you'll overload the adapter's connector and the 4 wires trying to carry the current of 8.
              sigpic
              (Insert witty quote here)
                • 31248
                it's possible that the 12v pins on the gfx card are not all linked and some are directly driving different parts of the card.
                that would be a poor design, but it sounds like what's happening.
                • c_hegge
                  • Sep 2009
                  • 5219
                  Depends on the CPU. Something such as an E6600 does not need an 8-pin connector to power it, regardless of what motherboard it's installed in. With an OC'd 125W CPU, though (Core 2 Extreme for instance), then yes, you would want to use an 8-pin connector.
                  • binsonk
                    • Apr 2014
                    • 182
                    Oh my, I wasn't satisfied with the cooler and fan on it, so I swapped in a stock Intel cooler, and now the CPU fan works with the 4-pin mobo connector in slots 5 to 8 (?). I think I can make a box now.
                    • omendata
                      • Jun 2015
                      • 25
                      The 8 pin converter works fine just remember it is sucking more current from a single power line on the psu so dont overload your psu.
                      You are only too old when you say you are too old!!!
                      • Compgeke
                        • Feb 2014
                        • 524
                        Not sure which pins it is off the top of my head but it'll only fit in one position, won't fit aligned over the others.
                        • binsonk
                          • Apr 2014
                          • 182
                          I got a new toy. I don't have many units with specs this good.
                          Zotac mainboard
                          2.6 GHz Dual Core
                          nVidia display
                          1 GB DDR2 / 800 MHz FSB , 128 MB onboard video (VGA)
                          VGA & Digital Video, onboard connectors
                          HDMI onboard
                          4 SATA drive slots
                          I'm running a liveCD of Linux. Look Ma, no hard drive!
                            • 31248
                            you should double the ram - other than hat the specs look good.
                            • binsonk
                              • Apr 2014
                              • 182
                              If I spend any money on this unit, first priority will be the correct PSU with 8-pin mobo connector. I don't know many distros of Linux that would falter with 1 gig of DDR2.
                              • binsonk
                                • Apr 2014
                                • 182
                                What about these two designs?
                                1 http://www.ebay.com/itm/6-Server-Mot.../121731664839?
                                2 http://www.ebay.com/itm/4-Pin-Molex-.../321229806421?
                                • Stefan Payne
                                  • 1267
                                  At least, better put 4Gig in there...
                                    • 31248
                                    Linux isnt so greedy with ram
                                    • binsonk
                                      • Apr 2014
                                      • 182
                                      I dropped by the local computer repair shop to look for a 4-to-8 pin adapter. The man said of the 8-pin mobo connector that the other/extra 4 pins are to power a graphics card, implying that the motherboard is adequately powered by the 4-pin connector.
                                      • Stefan Payne
                                        • 1267
                                        oh dear...
                                        I'm out of words for that...
                                        And no, it is not. It is for the CPU, most likely not GPU...
