Gigabyte 1660 Super OC 12V Short 8pin connector
  • RandoomStyle
    • Aug 2022
    • 14
    • Ensenada
    Hello i got a card with 12V short, found an IC blown Q510, remove it short persist, found that the short is on 12V GPU, remove all the Mosfets and the short still there, i inject 1.5V to the line and i got 1A of consumption, nothing getting warm, this could be the GPU itself?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3598
    • slovakia
    if u remove all mosfets u canot have 12V bypass to mem and core. u need at last 10A with 1V to show something on thermocam. q510 switching 12V . looks badly shorted. heat can fuse layers under it
    • RandoomStyle
      • Aug 2022
      • 14
      • Ensenada
      I see, thanks for that info, also I didn't check that the resistance on Vcore is low, I was thinking it has a high Z, one of the MOSFET is shorted so now I'm checking that to replace them and also fix the q510 got a destroyed via
        Thermal pad thickness for various laptop GPU / Graphics Cards
        ASUS Dual RTX 2070 OC 8GB
        ASUS ROG STRIX RTX 3080 OC
        ASUS ROG STRIX RTX 3090
        ASUS TUF Gaming RTX 3080 OC Edition
        ASUS TUF GTX 1660 S-O6G GAMING
        EVGA RTX 3060 Ti XC GAMING 8GB
        EVGA RTX 3060 XC GAMING 12GB GDDR6
        EVGA RTX 3080 FTW3 ULTRA GAMING
        EVGA RTX 3080 TI FTW3 ULTRA GAMING
        EVGA RTX 3090 XC3 ULTRA GAMING 24GB
        Gainward RTX 2080 Phoenix GS Specs
        Gainward RTX 3070 Phoenix 8GB
        Gainward RTX 3080 Ti Phoenix
        GIGABYTE AORUS RTX 3080 MASTER 10G
        02-09-2024, 08:08 AM
      • kappamax
        Need Bios "Gigabyte 1660 super mini itx"
        by kappamax
        I Need bios of "Gigabyte 1660 super mini itx".
        i lost my serial.
        V19120-1
        2/AX/KJ7864 01073 V19119-2 - PCB SN
        Thank a lot...
        07-29-2025, 09:42 AM
      • Prott
        Gigabyte GTX1080 - identifying a dead short on vmem
        by Prott
        Hey!
        I have a problem with Gigabyte Aorus 1080. The card seems fine (expected resistance on vcore, pex, 5v, 1.8v, 12v and reset) except for a dead short on vmem (FBVDD). It's interesting failure mode, cause usually (in my experience) when memory fails it still retains a few ohms - this one is literally a dead short.
        I removed the inductors and tried inject voltage (0.8 V at 6 A) which only seemed to warm up the cables to the card while the card itself didn't show any hotspots.
        Is there any way to narrow down the search for a short? I would prefer not to remove...
        07-04-2023, 06:29 AM
      • DynaxSC
        Extreme High Current & Low Voltage Short Killer ??
        by DynaxSC
        Hi Folks
        I'm looking for a extreme high current short killer solution for a reasonable cost.
        I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
        After taking off the socket, the shorts dissappear again.
        The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
        10-15-2024, 10:13 AM
        NVIDIA GeForce GTX 1660 Schematic & Board View
        The GeForce GTX 1660 is a performance-segment graphics card by NVIDIA, launched on March 14th, 2019. Built on the 12 nm process, and based on the TU116 graphics processor, in its TU116-300-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 1660. The TU116 graphics processor is an average sized chip with a die area of 284 mm² and 6,600 million transistors. Unlike the fully unlocked GeForce GTX 1660 Ti, which uses the same GPU but has all 1536 shaders enabled, NVIDIA has disabled some...
        10-02-2024, 07:44 AM
