Goodbye Windows Hello Ubuntu
  • mockingbird
    • Dec 2008
    • 5488
    #41
    Re: Goodbye Windows Hello Ubuntu
    Originally posted by diif
    If they are kept away from the internet and are used for data entry there isn't much of a problem.
    They are, but hypothetically, an XP machine with POSReady updates should be as secure and protected from zero-day threats as any Vista/7/8/10 machine. Perhaps even moreso, since XP is more mature.
    Legality doesn't change depending if it is checked or not, it breaks their EULA and as they are charging a good deal extra to support them i'd have thought they were quite keen to clamp down. I know the UK Met and parts of the NHS have coughed up a few million £ to keep their patches coming.
    It breaks the EULA of the patch, and the original product for which the patch was intended for isn't owned by the proprietor, so the EULA doesn't apply. It is a grey area for sure, but it isn't illegal, and any systems administrator worth his salt would undoubtedly keep vigilant in updating his XP systems with these patches.
    I don't think POSready is a full version of XP so even fully patched, parts of XP that are not used by POSready will fail to be updated.
    It's XP allright, just with a few minor changes.
    • diif
      • Feb 2014
      • 6978
      • England
      #42
      Vista/7/8/10 have more security features such as ASLR and is more secure than XP by default.
      It breaks the EULA of the original XP and probably the EULA of the patch.
      http://www.zdnet.com/article/hacked-...ll-a-bad-idea/ suggests it doesn't work fully.
      Any Admin worth his salt would have moved on the moment his tight company asked him to patch XP this dodgy way.
      • mockingbird
        • Dec 2008
        • 5488
        #43
        That's debatable.
        No it doesn't break XP's EULA, and you can't break POSReady 2009's EULA, because you don't have that OS. Either way, without getting into specifics, if a BSA auditor went to inspect a company, he would be perfectly happy as long as each PC was properly licensed. Like I said, he's not going to go around and compare DLL file versions to see if someone's using POSReady patches.
        It works, and it works quite well. What doesn't work is simply doing the 'hack' he mentioned. At the RyanVM forum, there's an active list of appropriate updates that's maintained. You can't just change your Windows ID to POSReady and use Microsoft Update, that's for sure.
        Apparently you've never heard of something called a budget. Let's see, spend tens of thousands of dollars upgrading your equipment and whatnot for something you don't need, or stay with something that works just as well, and that your employees are already used to?
        Management doesn't care how it gets done, only that it gets done. If I'm a systems admin and management comes to me and asks me what to do, I'd offer up both options and list the costs of each, and then fully expect them to choose the former.
        I'd then be saving myself the hundreds of hours of unecessary headache, and then I'd ask for a large raise at the end of the year, and I'd get it, because I saved the company so much money. Everyone is happy this way, and this is the way a smart sysadmin should think.
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          Ok, so Spotify is supposed to work under Ubuntu, I followed their official directions, but it is compeltely broken (does not open).
          • SteveNielsen
            Retired Tech
            • Jun 2012
            • 2327
            Bummer. Especially considering there's no other way to get free music from the internet.
              • 31294
              any time something does that,
              open a terminal window and run it from the command line.
              then you can see the error message(s) and fix it.
              it probably wants a library you dont have installed.
              ** this trick also works with windows.
                • 31294
                there are thousands of free music sources,
                most radio stations (real ones) also stream.
                examples
                http://www.pointblank.fm/listen_live.php
                http://vibesfm.net/radio2.htm
                http://192.240.102.195:8220/listen.pls
                http://ontopfm.net/player/
                and you have specialised ones like these
                http://www.broadcastify.com/
                http://www.scenemusic.net/
                • SteveNielsen
                  Retired Tech
                  • Jun 2012
                  • 2327
                  examples
                  I thought sometimes the sarcasm is obvious enough to not need to point it out, but I guess I was wrong.
                    • 31294
                    well yes, you need to specify
                    /sarc
                    to avoid confusion.
                    • RJARRRPCGP
                      • Jul 2004
                      • 6304
                      I always found that means dependency hell!
                      ASRock B550 PG Velocita
                      Ryzen 9 "Vermeer" 5900X
                      Arc A770 16 GB
                      eVGA Supernova G3 750W
                      Alienware AW3423DWF OLED
                      • shovenose
                        Send Doge Memes
                        • Aug 2010
                        • 6575
                        Nah, I just went back to Windows. But had this problem: http://www.michaelstaake.com/windows...tem-partition/
                        • SteveNielsen
                          Retired Tech
                          • Jun 2012
                          • 2327
                          Windows doesn't like boot sectors and MBRs written by other OSes. Hell, it doesn't even recognize its own if you run fixboot or fixmbr from recovery console.
                            • 31294
                            lol - use a linux live disk to delete all the partitions.
                            i used to have similar problems btw with windows98 and scsi drives - it's not a new problem.
                            • SteveNielsen
                              Retired Tech
                              • Jun 2012
                              • 2327
                              Yep, not a new problem at all. I think erasing track zero will do the trick as well. A zero-fill DEFINITELY will
                              • shovenose
                                Send Doge Memes
                                • Aug 2010
                                • 6575
                                No I did dod wipe same issue also same issue on Dell vostro 2420 running 10 before.
                                  • 31294
                                  put opensuse or fedora on it - those are the real big ones (unlike ubuntu that just has the hype)
                                  • shovenose
                                    Send Doge Memes
                                    • Aug 2010
                                    • 6575
                                    I like Fedora a lot actually. It's closer to CentOS (which is what I use on my server) but I wanted to try Xubuntu as a daily driver because it's a little bit more mainstream. But Windows 7 runs faster and works with all of my applications
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      I find that on my stuff (my laptops at least) Arch runs pretty well, on par with Win 7. That said, arch is not for noobs and never will be, hence why it runs so well (less overhead by way of crap one doesn't need, such as SElinux). I tend to dual boot though, as there are a few programs I use that don't work in linux and in case arch has a burp, I have some sort of a backup (also good for people like my wife who don't know gnome 3.x).
                                      sigpic
                                      (Insert witty quote here)
                                      • tsavpyn
                                        Requests to Intel Flash Programming Tool for Linux Ubuntu x86_64
                                        by tsavpyn
                                        Dear all,
                                        I forgot my BIOS password of my Surface Pro 3, I searched for solutions for a long time and knew that by using FPT to dump my bios to bin file and using decryptor, I can get my BIOS password.
                                        Now I have a problem that I am unable to dump my BIOS into bin file.
                                        My Surface Pro 3 currently runs on Ubuntu 22.04, with Secure Boot enabled and Boot From SSD Only.
                                        I searched for FPT but there is no Linux version and none of them work.
                                        I hereby request a copy of Intel Flash Programming Tool for Linux x64.
                                        I would really appreciate it if anyone...
                                        05-28-2024, 11:18 PM
                                      • ivtec
                                        install Linux on Windows 10 | Install Ubuntu on Windows 10 using Virtualbox ?
                                        by ivtec
                                        Has anybody installed Linux on Windows 10 using Virtualbox? and since my old PC will have support after oct 25 and won't update to 11 , i just want to use win 10 for Music notation program and use Progdvb iptv player .
                                        01-17-2025, 12:54 PM
                                      • abajor
                                        Evaluating Mechanical Hard Drives SMART Data in Linux (Ubuntu) Using the Disks Utility.
                                        by abajor
                                        I've gotten into the habit of Looking at peoples Mechanical Hard drives with a Ubuntu thumb drive to boot their system.
                                        I understand the raw values are not really uniform between manufacturers, but I have noticed that high seek and read error raw values at the very least correlate to a drive that is going to have sub par access time, and extremely slow OS booting.
                                        The odd thing is I've often seen very high seek and read error rates on drives with fairly low on time.
                                        Does anybody have any other takes on evaluating smart data? I've used Crystal Disk Info, It seems to present...
                                        04-23-2024, 11:43 PM
                                      • benek123
                                        RedmiBook 15 pro 2023 Ryzen - after replace LCD screen work only in windows
                                        by benek123
                                        I replaced the screen and LCD ribbon in Redmi Book 15 Pro Ryzen 2023. After replacing, the image on the screen is only visible in Windows 11 - when the AMD drivers are loaded.
                                        The screen is backlit but there is no image in: bios, post, when loading windows, in linux (ubuntu boot from usb), windows 10 PE.
                                        When I disconnect the EDP connector from the board and connect the HDMI cable, the image is visible everywhere good, in the BIOS you can see 2/3 of the image, i.e. 1920 pixels out of 3000 pixels.
                                        I checked the EDID with the old screen - it is identical.
                                        What...
                                        09-24-2024, 03:28 PM
                                      • piernov
                                        Compaq SR1000 MSI MS-6577 ACPI fix
                                        by piernov
                                        Compaq Presario SR1000 / SR1116FR, MSI MS-6577 (Xenon) Gamila/Giovani/Neon series
                                        ACPI fix!
                                        Yes, you read that right, the bug that HP/Compaq never fixed is finally no more, 16 years later. You probably don't care but here it is anyway.
                                        Bug
                                        Basically the bug is as follow: you want to use Linux on this machine, but it doesn't power off when you shut it down, you cannot put it to sleep, nouveau driver for NVidia GPUs doesn't load, etc…
                                        At boot, you may be greeted by the following message:
                                        Code:
                                          [ 0.000000] ACPI Error: A valid RSDP was
                                        11-30-2021, 02:34 PM
