Pata/Sata converter anyone?
  • alessioblaupunkt
    • Aug 2010
    • 50
    I want to use the ST500LM012 SEAGATE [SATA II HD 2.5" 5400RPM] in a old PC with PATA cable.
    So I need this converter from PATA to SATA II.
    But there are no report in the entire web that say: Yes, I've done it, it works.
    Can you please tell me as much as you know about this kind of conversion.
    Some info of my pc.
    http://support.hp.com/ie-en/document/bph07843
    I don't have the SATA HD, not even the converter.
    Thank you.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Pata/Sata converter anyone?
    I've used similar in the past yes.
      • 31094
      they do work.
      one thing to remember,
      that board is designed for a 3.5" drive.
      when you plug it onto a 2.5" drive it will be hard to mount.
      you may be better with the type that plugs into the motherboard and connects to the drive using a sata cable.
      those adapters come in a lot of shapes and sizes for different aplications.
        • 31094
        looking at the motherboard specs, it's only ata100
        you may be better off using a SATA pci card.
        • alessioblaupunkt
          • Aug 2010
          • 50
          Thanks. I can buy the metal plates to adapt the 2.5" in the 3.5" slot.
          Can you suggest a SATA pci card?
          • c_hegge
            • Sep 2009
            • 5219
            I have one hdd adapted the other way (an IDE HDD on a SATA motherboard), in my server. It's in RAID 1 with a newer SATA HDD. It works with no problems
            • alessioblaupunkt
              • Aug 2010
              • 50
              Thank you c_hegge, can you post a pic of yours so I can buy the one that look closer?
              There will be OS and data in the SATA hd, and it will be the only hd in the system.
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                I've used the kind that plugs into the PATA header and provides 2 SATA ports (Startech.com makes them, others make them with only one SATA port). I've had good luck; SATA I and ATA-133 are the exact same speed anyway.
                sigpic
                (Insert witty quote here)
                • Compgeke
                  • Feb 2014
                  • 524
                  Yes and no. You'd need an offset adapter, however I've never actually seen one. One such would stick the drive to the left side of the adapter, probably screwing onto the bottom of the drive rather than sides.
                  As you can see here, when centered (like the adapters I've seen do) the SATA connectors don't line up, instead it has to be aligned all the way to the left.
                  • brethin
                    • Dec 2008
                    • 1907
                    Just use a SATA PC card they dirt cheap and would be faster than a IDE to SATA adapter.
                      • 31094
                      as long as it has a bootrom on it.
                      • brethin
                        • Dec 2008
                        • 1907
                        It doesn't need a bootrom (why you would think that is beyond me). Most PC's will see a PC card and allow interrupts for disk controllers to be passed through and be bootable, I have a half dozen on my bench to prove it.
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          ^Not the cheapass via cards at least. Not in 2007 or so anyway. Not bootable. Better cards, sure.
                          sigpic
                          • c_hegge
                            • Sep 2009
                            • 5219
                            Yup. I've also seen VIA SATA cards which were not bootable.
                            EDIT: And owned one.
                              • 31094
                              seen them? i'v owned them.
                              any motherboard that's old enough to only have ATA100 is unlikely to have any code in the bios to boot from SATA or even know what that is.
                              i hope this does not turn into another "anything older than c2d is junk for the skip" type threads!
                              • ChaosLegionnaire
                                HC Overclocker
                                • Jul 2012
                                • 3264
                                • Singapore
                                waaa, u guys are lucky to have gotten your hands on working pata/sata converters. there's lots of fake pata/sata converters in my area almost as bad as fake caps around ebay.
                                anyway, none of the pata/sata converters i got would work reliably. first one i bought was a converter u attach to the board, couldnt detect my sata2 hdd. inserted jumper to limit the drive to sata1 and drive was detectable but speed and transfer rate were unstable. ruled out that the sata cable is faulty. works fine when connected directly to another sata motherboard.
                                next, when i tried a pata drive connected to a sata motherboard, the sata board simply could not recognise the pata drive. it just stuck at detecting the drive for several seconds then gave up and said "no drive detected at port".
                                also, another pata/sata converter (the type that is attached to the drive) killed one of my 2tb hard drives because it couldnt supply enuff current to the drive. drive kept clicking. smart failure detected. seek error rate out of spec. drive head failure. bye bye data. it was good to have had you.
                                poor me!
                                • alessioblaupunkt
                                  • Aug 2010
                                  • 50
                                  Quite similar to ChaosLegionnaire.
                                  Bought and adapter quite similar to the one in post #1 and there are problems.
                                  Bought a different hd, different from the one in post #1.
                                  Here's the full description.
                                  Sorry for posting elsewhere but I need much more people to read about this problem.
                                  Using the old PATA now.
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8701
                                    I have a few SATA MB -> PATA drive converters, every single one work perfectly. They even worked for CDROM/DVD drives. On the other hand, I have one PATA MB -> SATA drive converter. This didn't work so well, but didn't play with it much.
                                    Yes and via SATA PCI boards are trouble... then again it seemed to work ok on a via motherboard... or perhaps I'm imagining things.
                                      • 31094
                                      i have seen some adapters running on 5v when they should have a 3.3v regulator on the board.
                                      they run real hot and die after a few monhs.
                                      now the bitch is, the boards had the pads for a regulator, but the input and output had simply been bridged to save money!
                                      • fzabkar
                                        • Mar 2009
                                        • 772
                                        The problem you have described at bleepingcomputer is due to stuck bits (0 and 3) in the IDE interface.
                                        Code:
                                        C:\>debug
                                        -e 100 "TFS@ABA DT00ACA0"
                                        -e 110 "TOSHIBA DT01ACA050"
                                        -d 100 11f
                                        1262:0100 54 46 53 40 41 42 41 20-44 54 30 30 41 43 41 30  TFS@ABA DT00ACA0
                                        1262:0110 54 4F 53 48 49 42 41 20-44 54 30 31 41 43 41 30  TOSHIBA DT01ACA0
                                        -q
                                        Bad model number due to stuck bit in IDE interface:
                                        http://www.hddoracle.com/viewtopic.php?f=59&t=147&p=262
                                        • DynaxSC
                                          GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                                          by DynaxSC
                                          I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                                          There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                                          The board is generally working now, all PCIe ports are working, Windows installs normally.
                                          However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                                          The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                                          03-10-2025, 12:27 PM
                                          HP Z2 G4 + 3TB SATA 6Gb/s 7200 HDD i7-8700K Specification for Upgrade or Repair
                                          This specification for the HP Z2 G4 + 3TB SATA 6Gb/s 7200 HDD can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z2 G4 + 3TB SATA 6Gb/s 7200 HDD boardview and Z2 G4 + 3TB SATA 6Gb/s 7200 HDD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-12-2024, 03:28 PM
                                        • clabr
                                          Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
                                          by clabr
                                          Need help to solve some problems with this laptop.
                                          After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
                                          After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
                                          Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
                                          Before this had happened I observed some other problems:
                                          When I tried replacing original mecanical HDD with a SSD HDD could not get them...
                                          12-02-2021, 08:09 AM
                                          Pegatron M2N78-LA (rev. 3.02) freezes on POST with SATA drives attached
                                          by momaka
                                          Like the title says, I have a Pegatron M2N78-LA (HP P/N: 513430-002) motherboard out of an HP Pavilion PC. The motherboard hard-locks during POST when it gets to the part of trying to detect the SATA devices *only* if there is a SATA device (be it HDD or optical drive) connected to any of the SATA ports. I cannot enter BIOS or do anything when this occurs. Pressing Ctrl+Alt+Del cannot restart the system either. In fact, the keyboard locks up too (Num Lock status LED cannot be toggled anymore.). However, if I disconnect everything from the motherboard's SATA ports, the motherboard can POST successfully...
                                          11-28-2020, 11:08 PM
                                        • playit
                                          psu sata power wires thinner - does it make a difference ?
                                          by playit
                                          hello , i have a psu 450 zebronics (yes its bad crap) which used to work before with its own sata power cable ,but today its not able to power up harddrive efficiently with its own power sata cable , but when there is a connector which have a thick wire than the psu sata power cable wires - its powering up and working smooth , no problem yet .
                                          i the voltages with multimeter shows 12 ,3.3 v , no problem , but hardrives powers well only with this thick wire sata power cable connector from psu power molex .
                                          any explanation on this ?? thank you ,soon i am planning to buy some branded...
                                          10-12-2023, 05:25 AM
