Worst Corrosion I've ever seen
  • c_hegge
    • Sep 2009
    • 5219
    This computer lived just 100 meters or so from the coast and, well... I'll let the pictures do the talking...
    PS: Sorry about using HWI to host the images. I can't upload attachments anymore. The forum is way too slow now. I might resize them a bit later when I'm back on my PC and try again.
    EDIT: Done. I had to resize them to 1366x768.
    https://www.badcaps.net/forum/attach...1&d=1429787450
    The back. I've seen plenty of PSUs with rust spots on the back, but not quite like that before.
    The bottom of the case. It looks like moisture has been dripping there from the PSU.
    The PSU intake grille
    The rest are the PSU's internals. Even Deltas aren't immune to corrosion, unfortunately.
    Last edited by c_hegge; 04-23-2015, 05:14 AM. Reason: Re-sized pictures and attached locally
  • japlytic
    • Oct 2005
    • 2086
    Re: Worst Corrosion I've ever seen
    I had a computer which had succumbed to salt air corrorsion (twice from the same client), and I've read in the Serviceman's Log in an issue of Silicon Chip where a TV repair involved corrosion from sea air.
      • 31086
      i'v seen much worse.
      you should see what can happen to arcade machines that operate on the seafront or pier with open-fronted buildings and lots of intake fans to keep them cool (and spread the death!)
      • goodpsusearch
        • Oct 2009
        • 2850
        • Greece
        Just replace the case and the screws and it will be ok
        • c_hegge
          • Sep 2009
          • 5219
          Maybe, but I'd never even be able to give it away with that much corrosion on it.
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16958
            I was given a Dell 3011 monitor that was literally looking out the window at the pacific ocean. PCB's were corroded beyond repair, but the panel was fine. Scavenged boards from one with a broken panel to repair it.
            <--- Badcaps.net Founder
            Badcaps.net Services:
            Motherboard Repair Services
            http://folding.stanford.edu/
            Team : 49813
            Join in!!
            Team Stats
            • mockingbird
              • Dec 2008
              • 5484
              Whoa! Was that in use in that state?
              Yes, the pictures are extremely slow on the forum. Topcat, what's up with that?
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16958
                I've explained the attachment slowness a bazillion times.
                Team : 49813
                Join in!!
                Team Stats
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  It's gotten so bad, that I often have to refresh multiple times just for a text page to complete loading!
                  ASRock B550 PG Velocita
                  Ryzen 9 "Vermeer" 5900X
                  Arc A770 16 GB
                  eVGA Supernova G3 750W
                  Alienware AW3423DWF OLED
                  • mockingbird
                    • Dec 2008
                    • 5484
                    It's never been slow for me up until a short while ago.
                    • Life Goes On
                      • May 2014
                      • 264
                      • Curacao
                      Is it worth to repair something like that, i think its doomed.
                      The Night Drop Down, I Will Keep Try Until..., You Never know.
                      Dushi Kòrsou, Nos Tei.
                      • c_hegge
                        • Sep 2009
                        • 5219
                        No. That PC is destined for the scrap heap.
                        • nish_pinto
                          The Adventurist
                          • Oct 2011
                          • 83
                          • India
                          God damn corrosion.
                          http://nishantpinto.blogspot.in/
                          • B2L_Repairs
                            Huawei D15 no power found corrosion damage
                            by B2L_Repairs
                            I got a huawei D15 that came in for no power repair. Device charges , charging led flashedms but doesn't turn on. I found corrosion on an IC (ic name is BDJCY1...I can't find out much info about it online). I removed this ic and two pads are corroded but they can be repaired. To my knowledge inductors never short to ground (i might be wrong and please those that are more knowledgeable than me can correct me). I found few inductors short to ground when my multimeter is in beep mode ,indicating a short in the line of those inductors...but I don't know how to go about to find the shorted component...
                            02-06-2025, 01:05 PM
                          • AJ847.63e
                            Dell XPS 9510 LA-K411P Liquid damaged
                            by AJ847.63e
                            Hi All,
                            Just wanted to get some advice on a XPS 9510 we have. Unit suddenly decided it no longer wants to turn on. Sometimes pressing the power button, it sits on keyboard lights no picture and boot loops a few times before shutting down. Other times it completely ignores the power button and does nothing. There is no light at the front of the laptop.
                            We are getting 20V on all 3 ports so the USB C PD communications working fine. We are getting 12V,3V3 and 5v so it seems like an issue quite late in the power sequence.
                            Removed the board and found dust corrosion...
                            02-26-2024, 06:05 PM
                          • Comp_Pro
                            A2159 Macbook Pro 820-01598 stuck on 5V
                            by Comp_Pro
                            This is a mid 2019 Macbook Pro touchbar model. Motherboard is 820-01598. Technical information is going to be attached below including power sequencing graph.
                            I am having the issue of no 20V on the USB C port. USB-C Stays at 5V permanently. Current draw is 130mA. If I connect and disconnect in a certain way I can sometimes obtain a 300mA draw.
                            This laptop came in for water damage and although there was some corrosion it was not very bad. The board was ultrasonic cleaned but is not powering on. Laptop was having 20V prior to cleaning but there was no signs of charge...
                            03-02-2021, 02:51 PM
                          • Traptor
                            Logitech Z506 with corrosion
                            by Traptor
                            Hi Guys,
                            I have a Logitech Z506 with some problem.
                            The main problem was the front right and subwoofer gave a hard noise.
                            After the disassemble I found many corrosion on the mainboard as you can see on the pictures.
                            I removed the corrosions and the noise disappeared but the sound too.
                            I think some parts is damaged because of the corrosion.
                            I searched a lot on the internet but I cant find correct schematic for this pcb, so I dont know what is the correct values of the damaged parts.
                            But I found same good pictures of this board.
                            02-11-2023, 05:25 AM
                            The worst poorly constructed tvs that are being churned out.
                            by nomoresonys
                            This topic might save some from buying the worst of the cheap tvs. Have seen plenty, this is the latest one I've had the dis-pleasure to see up close: Hisense 55-Inch Class A6 Series 4K UHD...
                            03-03-2024, 07:01 AM
