Re: Dumbest 'electronic' mistake you ever made
Im so sorry newtothis but i could not stop laughing, a funny kinda dance, sorry lol
" I remember doing a funny kinda dance "
lol im so sorry but i could not stop laughing, imagination is so bad
we lost a phase at my HS and we lost the elevator, 3 phase circulatiors, cooling tower fan motors, 3 phase server PSU.... all of them burned up. yep, expensive.
So yeah, I didn't cause this (LOL), but I thought this is the best place to post this, so here goes:
Yesterday we had some power issues at school. Bathroom (that sucks, LOL) and some stairway lights didn't work. No tripped circuit breakers! We checked the incoming 3 phase supply. A to N = 119V, C to N = 122V, B to N = 7V!!!! Ruh-roh!
We went into the boiler room, which is separate from the electrical room (though, there are sub-panels in the boiler room). As soon as we opened the door, a bad burning smell hit us. One of the circulator pumps runs on 3 phase, and it didn't like being run on 2 phases!!! It was smoking! We quickly shut it off and it took quite a while to stop smoking.
There are no other 3 phase motors in the building besides the fans for the A/C system and it's compressor(s). We made sure everyone knew not to turn them on, lol.
An AC powered clock shows that the B phase failure happened at around 2:40 AM (If I recall correctly, lol). We called PSE&G (Public Service Electric and Gas) and they came out. A pole down the street had the B phase cutout blown. They opened a manhole cover, where some splices were (for the 13.8kV feeder lines) and there was water in there. Splices looked fine, according to the workers. They did pump out the water just to be sure. Well, here is the fun part. They put in a new fuse, to see if there was still a fault. Yep, there was, and it blew. DAMN! Quite a bang, and a flash of light from the bottom of the cutout! They sure put a good amount of explosives in those things! :P
So, it turns out, that the fault was actually on the pole. It was in the shroud that covers the HV wires, which are going to the bottom of the pole, and into the underground conduit that feeds the building.
Oh, and there are 3 underground transformers in a vault, each is 100kVa. Just thought you might want to know.
I might see if I can get the circulator motor when they replace it, and take a look to see how cooked it is inside. Then I'll just recycle it, or give it to the local motor repair shop, if they want to rewind it and sell it to someone else. I also think we should get some sort of protection contactor for the new motor, to prevent this from happening in the future, if we do loose a phase at some point in time. Those motors aren't cheap!Leave a comment:
You might need to get to a dentist Ben.Leave a comment:
Yeah, popped caps can really stink. It's interesting though, all the brands seem to have a different stink xDLeave a comment:
putting 9 caps on the output VRM on a Dell GX280 all backwards. 9 pops i a row very quicklyLeave a comment:
Lets see, dumbest. . . I was 8 or 9, decided I needed to know what would happen if I put a hanger across the pins of a lamp plug before plugging it in. Hanger welded itself to the plug prongs. Luckily I didn't get electrocuted, and circuit breaker tripped before anything really bad happened.
One time I put my hand on a heat sink to feel if it was warm, got a nice 200+ volt DC shock.
Latest dumb thing, put a Panny FM 2200UF 16V cap in backwards. "pop-fissssss" scared the shit outta me when I hit the power switch. Cloud of magic smoke streamed into the air through the PSU air vents. Smelt like a skunk fucked a garlic clove.
Latest dumb thing, put a Panny FM 2200UF 16V cap in backwards. "pop-fissssss" scared the shit outta me when I hit the power switch. Cloud of magic smoke streamed into the air through the PSU air vents. Smelt like a skunk fucked a garlic clove.Leave a comment:
A while back, I was around a live electrical socket w/o a cover for the hole in the wall. I think I was poking around in there and I heard BZZZZZZZZZZZZZZZZZZZZT. How I didn't get zapped, I have not a clue.Leave a comment:
Well I have had my fair share of mishaps... I started young with electric... to the age of 3 when my mom said I went very quiet for 2 minutes.... After investigating what I was doing she noticed I had a screwdriver in my hand... and the front AND backbox of a plug socket off the wall... How I didn't get fried I have no idea lol.... My luck did not continue though!..
Multiple times I have picked up a power board after testing and shorted my fingers across the PFC caps! LOL Many little burns from those.
Tested a broken plug socket with my DMM to make sure there was no power after switched the fuse off for (Counter plugs).... DMM says no power.... Unscrew the cables and fit new backbox... go to wire the front on and BUZZZZZZZZZZZZZZZZ! DMM was faulty and Fukin thing was live.... HA
Making the mistake of asking for help from someone that doesn't listen properly..... Was working on a HPS light ballast and asked someone to switch the unit on WHEN I said so.... They heard "Switch it on" and flicked the switch..... I remember doing a funny kinda dance with my hands gripped tight to the unit before all my muscles locked up on me... friend turned off the power and I instantly let go of the 4KG ballast dropping it on my foot breaking 2 bones!Last edited by newtothis; 04-17-2015, 03:06 PM.Leave a comment:
It wasn't really anything, but something that wasn't smart. I was taking apart an Acer Aspire One D150, and I was removing the keyboard tray, and I forgot to unplug the power button, and tore the ribbon cable right off of the power button. While trying to fix it, I almost fried the netbook and made smoke come out of the button. I got lucky there.Leave a comment:
by GraphicManHello guys
Because the unit is old (but only occasionally used) the loudness button causes some noise due to bad contact,
sprays did not work, so i decided to solder the pins that it connects on the pcb at the on (loudness on) position
i did that and it worked fine, i know from the bottom of my heart that the switch connects 2 pins and also d/c other 2 pins
on every position it have (6 pin switch), so i was curious what would happen if i clicked the switch off while the pins are soldered at on (so basiclly on and off at the same time), when i did so the sound is gone, nothing...-
by sam_sam_samThis is a new item at Electronic GoldMine that has arrived within the last few weeks
Here is the link for them I know for sure that it works because ( I tried it on mine soldering station ) I bought two of them and I just bought two more of them so I have some extra replacement ones in my parts bin
Stahl Tools DDDS Replacement Iron for DSDS Stahl Solder Station
https://theelectronicgoldmine.com/products/g28392
One note it will not work for the ZD-917 or similar model number that does not have the sleep function that are the same iron but the plug only...11-24-2024, 01:25 AM -
by elmontadorHello i hope someone can help me i made a mess, i forgot that the board still hot and i knock some resistors out of place , i can't find any schematics or any info, i am uploading a picture with the components i need to put in place i don't need the full manual just the list for the resistors and their value(8 in total), if someone can help i'll be thankful...
by alex26Hello. I have a Lenovo ideapad gaming 3 laptop. I did a big mistake, more precisely I powered a laptop with 61V instead of 19V. I found a shorted coil and injected 1v. TPS65993 is heating up. I powered it through the rectangular plug, not through USBC. It is possible that this integrated circuit has burned out. I can't find a datasheet. TPS65994 can be found at Mouser but I don't think it is a good replacement. This TPS65993 is PD controller.Thanks. Motherboard code is HLG30 LA-L916P.
by handsworthJust wanted to share some information that I ran across when attempting to do the tape method on a tv with a shorted panel. I normally use magnifying glasses however while watching a you tube video, the person was using their phone. It seems that the Iphone has a magnifier app and wow, it works great. I have Iphone 11 and the app is built in. Pictures attached are screen shots. Made taping the pins a breeze. Also useful when reading the tiny print on the boards. Hope this helps somebody. ...
- Loading...
