LG RL4 (i made a mess)
  • elmontador
    • Nov 2017
    • 4
    • Portugal
    Hello i hope someone can help me i made a mess, i forgot that the board still hot and i knock some resistors out of place Click image for larger version
ID:	3716743 , i can't find any schematics or any info, i am uploading a picture with the components i need to put in place i don't need the full manual just the list for the resistors and their value(8 in total), if someone can help i'll be thankful
  • madan1
    • Nov 2016
    • 685
    • Bulgaria
    The same IC is used in other LG models, for which there are schematics. You can try extrapolating the value of the resistors based in on which pins they are connected to the IC.
    For instance R5F7 R5G1 R503 seem to be connected to the caps next to them. Most likely those correspond to R5N9 R529 R528 on LG LAP250H.
    • brightest_z
      Hot Air Blew Away Resistors Near Bios
      by brightest_z
      Hi All - I'm in the midst or reprogramming the bios on my gen1 Surface Laptop Studio and I accidentally blew away 2 resistors nearby the bios. I don't have another board to measure values of the missing resistors and schematics aren't available, bbut the bios is a 6x5mm Winbond WSON8, W25R256JWPQ model. The traces are conductive to Pins 3 and 7 (IO2 & IO3 respectively) so I have reason to believe they are 10k pull up resistors since IO2&3 pins are used for Quad SPI instructions.
      Does anyone with more knowledge, and experience than I, know if this is the case?
      12-11-2024, 08:34 PM
    • TinkerTron
      Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
      by TinkerTron
      Hey everyone,
      I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
      Instead, here's what's been bugging me so far:
      The schematic...
      03-06-2025, 02:03 PM
    • alindumitru46
      Gigabyte Windforce 980 G1 Gaming no image
      by alindumitru46
      I received the board as a "souvenir", but from the first analysis it was full of dust and lint, never maintained, for sure.
      The exact model is GV-N980G1 Gaming-4GD rev 1.0.
      The board starts with the fans running full, the blue Windforce LED is on, but it doesn't give any image at all, and the GPU is cold.
      I moved on to disassembly and cleaning, unfortunately for some time I haven't been able to keep a better photo device handy and the pictures are not great.
      I quickly identified an area with 2 oxidized resistors, R61/R64, and after carefully cleaning the 2 resistors...
      01-25-2025, 07:14 AM
    • jinu_j
      LED driver circuit. Burnt Resistors
      by jinu_j
      Hi Folks
      This has to do with a LED light driver rated for Output - DC36-65V 300mA. This is used to drive a 15W LED panel light.
      Now this does not work so opened up and found 2 resistors burnt to crisp. Sensing a learning moment, i looked around the circuit to figure out that it is built around the OB2538 chip. The circuit to a large extent follows the sample application circuit mentioned in the data sheet. I have traced the actual circuit and the same is also attached for reference.
      But i have some queries on this circuit
      1. The resistors that burnt to crisp...
      08-26-2020, 01:24 AM
    • repair-it
      Pioneer VSX-40 ,Trying to ID these resistors
      by repair-it
      I am trying to determine why these two resistors are the colors that they are. This is a Pioneer amp. The ones I am concerned about are the RED & GREEN colored resistors. I need to replace them and want to be sure to use the properly rated component....
      12-16-2024, 02:08 PM
