Hello. I have a Lenovo ideapad gaming 3 laptop. I did a big mistake, more precisely I powered a laptop with 61V instead of 19V. I found a shorted coil and injected 1v. TPS65993 is heating up. I powered it through the rectangular plug, not through USBC. It is possible that this integrated circuit has burned out. I can't find a datasheet. TPS65994 can be found at Mouser but I don't think it is a good replacement. This TPS65993 is PD controller.Thanks. Motherboard code is HLG30 LA-L916P.
What can i measure to see if the Tps is really burnt?Hello. I have a Lenovo ideapad gaming 3 laptop. I did a big mistake, more precisely I powered a laptop with 61V instead of 19V. I found a shorted coil and injected 1v. TPS65993 is heating up. I powered it through the rectangular plug, not through USBC. It is possible that this integrated circuit has burned out. I can't find a datasheet. TPS65994 can be found at Mouser but I don't think it is a good replacement. This TPS65993 is PD controller.Thanks. Motherboard code is HLG30 LA-L916P.
When powered from USB-C, the board can not work without a PD-Controller. It needs to be replaced. You are still very luckyComment
You are right, I was very lucky especially because it wasn't my laptop, but my power supply went crazy, it jumped from 19v to 61v. The charger doesn't work, I identified the BQ24800 integrated circuit. It wasn't powered because the resistor on Vin was open. I think the integrated circuit is short, but I don't have this exact model and I'll use the BQ24780Comment
I replace the bq chip and the laptop work, but i have another problem. With my external power supply the laptop charges but with the original charger it does not. The charger plug is that rectangular one and I don't know if the problem is with the central pin, although from my power supply I only have 2 pins and the laptop charges.Comment
The laptop works fine, the problem is that the battery does not charge. The battery is detected by the laptop and displayed in windows. The bq24800 battery charging integrated circuit was burned, the 10 ohm resistor on VCC and a mosfet on the charger. I replaced the Bq24800 with the Bq24780S and the measured voltages are those in the picture.
The resistance between ACP/ACN pins of charging IC is 0.
The resistance between pins 18 (SRN) & 19 (SRP) on the charger IC is 20 ohms.
I even have the charging light.
What can be the problem? Thanks.1 PhotoComment
by Evgenii999Hello everyone,
I need your advice in diagnosing a motherboard issue on a Lenovo IdeaPad 3 15ITL05, motherboard HS45A/HS55A Rev 1.0 NM-D461 (2020-11-02).
Symptoms:
The laptop does not power on and does not respond to the power button.
Background:
According to the owner, her child was playing on the laptop when it suddenly shut down.
What has been done so far:
Original charger is missing; the non-original one was tested and found faulty (0 V output).
Using a lab power supply (20 V, 0.5 A) — no activity on the board, no LEDs, no standby voltages.... -
This specification for the HP OMEN by HP OMEN Gaming Laptop 16-xd0000na Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the OMEN Gaming Laptop 16-xd0000na boardview and OMEN Gaming Laptop 16-xd0000na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...09-07-2024, 07:19 AM
This specification for the HP OMEN by HP OMEN Gaming Laptop 16-xf0002na Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the OMEN Gaming Laptop 16-xf0002na boardview and OMEN Gaming Laptop 16-xf0002na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...09-07-2024, 07:19 AM
by BoxcryptorHello,
I tried to update the BIOS version on my Lenovo Laptop L340-15IRH Gaming from BGCN29W to the latest version, BGCN36WW, as released on the pcsupport.lenovo website. However, I encountered the following error message after following all the steps carefully:
**InsydeH2O – Secure Flash**
**Error: Decompress failed!!!**
**Please press any key to reset the system.**...-
Channel: BIOS Requests ONLY!
This specification for the Acer Nitro Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i7-11800H, 16GB, 512GB SSD, NVIDIA RTX 3060, Full HD 144Hz, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i7-11800H, 16GB, 512GB SSD, NVIDIA RTX 3060, Full HD 144Hz, Windows 10, Black) boardview and Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i7-11800H, 16GB, 512GB SSD, NVIDIA RTX 3060,...09-07-2024, 03:10 AM
- Loading...
