Electronic Goldmine has replacement Irons for the ZD-978 or similar model number this the one that has the sleep function
    • Jul 2011
    • 6061
    This is a new item at Electronic GoldMine that has arrived within the last few weeks
    Here is the link for them I know for sure that it works because ( I tried it on mine soldering station ) I bought two of them and I just bought two more of them so I have some extra replacement ones in my parts bin
    Stahl Tools DDDS Replacement Iron for DSDS Stahl Solder Station
    https://theelectronicgoldmine.com/products/g28392
    One note it will not work for the ZD-917 or similar model number that does not have the sleep function that are the same iron but the plug only has 4 pins and the one that has the sleep function has 6 pins
    One other note do NOT be tempted to plug it in the ZD-917 desoldering gun port even though it has 6 pin connector the wiring is NOT configured for this iron you will burn out the sleep function on it ( I know because I tried it once )
    I probably should have put this post in the soldering station post section but the reason I did not I want to make sure that people who have this soldering station see this new item from Electronic Goldmine I get email from them all the time and because the cost is $17.95
    I have done modifications to my desoldering station on the post before about mine ZD-978
  • survivalbloke
    Lenovo Flex 5 14ITL05 - will only sleep if commanded to through start menu>power icon
    by survivalbloke
    This laptop refuses to sleep unless specifically commanded to sleep through Windows. If I close the lid, the screen does go dark just before the lid is closed, so it appears the hall sensor works. However, it will sit there, drawing 1.xx amps until the battery dies. If I command it to sleep, it drops down to normal sleeping current. If I have it sleeping with lid closed and I disconnect the power adapter, it will wake from sleep, even with the lid closed. I have updated the firmware, but still the fault persists. I've also verified power settings in Windows that the device is to sleep when the...
    03-20-2025, 02:29 PM
    Electronic Goldmine has a weekend sale Wireless Charging Awesome Earbuds with Microphone CTS-MB3
    https://theelectronicgoldmine.com/products/g26731
    There regular price is $49.99 they are worth that but I would not buy any unless they are at $10.00
    When they had them on sale the first time I just add to an order that I was getting I have had wired earbuds before and was not impressed with the way they fit in your ear but these fit in your ears very well and easily put into your ear
    I bought a pair of them when they had them on sale for $10.00...
    06-22-2024, 07:38 AM
  • cappernicus
    Satellite r945-p440 - Hard crash coming out of sleep
    by cappernicus
    Toshiba Satellite r945-p440
    Motherboard: FAM2SY2 A3256A
    I do not have a schematic or board file
    I usually let it go to sleep every time I use it because it is nearly always plugged in, with occasional shutdowns to reset things. Then it started to hard crash every time it tried to come out of sleep. The lights would come on for half a second but before anything shows on the screen they would all shut off and it would boot up as if I had shut it down completely (except that windows knows it didn't), and when it comes back on the fan ramps up to full and stays there perpetually...
    04-16-2025, 05:31 PM
  • rutgerv
    Acer Swift 3 SF314-42 not powering up
    by rutgerv
    Dear all,
    For a friend I'm trying to repair an Acer Swift 3 laptop (SF314-42). I'm not a professional, but have some experience (both as amateur and professional) in working with electronic design and repair of musical instruments.
    The issue with the Acer laptop is the following:
    It was bought new and used (not heavily) at home for about three years. After normal use, it was put to sleep, connected to charger and left over night (just like any other day). The next morning, the laptop would not wake up from sleep. Instead, when pressing the power button, the power...
    08-02-2024, 06:59 AM
  • Salvador Pérez
    Help identifying the function of these two coils - MSI Delta 15 (MS-15CK1)
    by Salvador Pérez
    Hello everyone, I'm troubleshooting an MSI Delta 15 (MS-15CK1) motherboard, and I need help identifying the function of the two coils marked in the attached image. The laptop powers on and responds to the keyboard, but the screen does not turn on-neither the LCD nor the backlight. I've checked the main power rails, and all other coils seem to have the expected voltages:
    • 0.91V for the GPU
    • 1.7V for VRAM
    • 3.3V and 5V rails 1.8V for the BIOS
    • 0.9V for the CPU and iGPU 1.2V for the RAM
    However, these two coils are not showing any voltage....
    03-10-2025, 11:50 AM
