Macintosh II Ressurection
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Things were a little slow around the shop today, so I figured I'd tinker around with this Macintosh II that was given to me a couple weeks ago. It quit working (would no longer power up) in 1996, at which time they switched over to the PC platform. This old Mac has sat in the dank cold basement of a 100yr old storefront building for a local realtor's office ever since...so you can imagine what it was like down there....
    I know nothing of Mac's other than the hundreds of G5 iMac and G4 eMac's I've recapped...... I plugged it in, pressed power, it wouldn't do anything....nothing. Common sense says to start in the power supply. Measured the PSU outputs, nothing, not even STBY. I removed it, took the cover off, blew out the almost 30yr old dust bunnies, and had a look... Starting in the primary, things were looking good. Fuses ok, rectifier diodes ok, no bloated/leaking caps, no red flags....so before I really start digging into it, I research the PSU model, which came up with a lot of obscure information on the entire Mac II system..... Apparently, these PSU's do not have standby voltage. When the power button is pressed, the initial powerup signal voltage is supplied by the CMOS battery, and once powered up, the +5v rail takes over and maintains the signal voltage....so I look at the motherboard and see 2x half AA size 3v batteries. One showed 3v, I was in shock that it was still good after all these years and stored in a cold place. The second one was dead as a mackerel... They were soldered to the board, so I cut them both off at the batt, leaving the leads in the board.
    I had nothing like that laying around....but being 3v, a couple CR2032's would do just fine, atleast temporarily... I robbed a couple bad SX270 boards of their batt holders and soldered them in place and stuck new batteries in them.
    ok, not the prettiest....but fine for testing purposes....
    Putting it back together.......the ultimate "bigfoot" HDD, eat your heart out Goontron!! A whopping 80mb SCSI.
    Low & behold, ignition!! The monitor really grumbled and groaned the first few seconds......between the degauss and all those old caps reforming, it made some really cool frankenstein lab noises. It booted right up.
    There is no stripe in the display like the pic shows.... yay for low refresh rates and cameras.
    Whopping 5mb of RAM....
    That concludes today's lesson on how to waste an hour's time on a completely useless machine!!
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • tvsteve2
    • Aug 2014
    • 25
    • usa
    Re: Macintosh II Ressurection
    But you had a nice trip back in time to what was an expensive computer then! I found a Compaq win 95 laptop that fired right up and even had office on it but never had been on the internet and ran amazingly fast! TIME WARP!
    • Compgeke
      • Feb 2014
      • 524
      Just a heads up the rest of the motherboard probably will need a recap. Apple's capacitors of that time were utter crap and have a tendency to leak.
      I have a Mac Classic II and a Mac IIcx that both need recaps, just haven't had a chance to buy the caps to do it.
        • 31278
        most of the old mac's i'v seen are all tantalum.
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16959
          There are a few axial lytics, all nichicon. Don't remember the series, but were 470uF 16v. None appeared to be leaking, but we know how that goes around Badcaps.net....thanks for the heads-up compgeek. The caps in the PSU were all UCC.
          Team : 49813
          Join in!!
          Team Stats
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16959
            While I was at it, I tried out the printer. The ribbon is dried out, print was very light. I doubt you can even get a replacement for it anymore....but it did print!!
            Some MS word doc that was on the system....
            Glare reducer cleaned up. This system must have been near a window when it was used, much of the plastic has the classic UV yellowing...the glare reducer was the worst.
            Team : 49813
            Join in!!
            Team Stats
              • 31278
              maybe sticky this attachement someplace.
              • RJARRRPCGP
                • Jul 2004
                • 6304
                Probably at least better than the G5 era. I would think that by the time they bulged and/or leaked, they would be at least about 20 years old!
                The Nichicon caps in G5s (and possibly G4s) have a tendency to bulge and leak within a few years. (Or at best, 6 years)
                ASRock B550 PG Velocita
                Ryzen 9 "Vermeer" 5900X
                Arc A770 16 GB
                eVGA Supernova G3 750W
                Alienware AW3423DWF OLED
                • lti
                  • May 2011
                  • 2557
                  The caps that leak are surface mount electrolytics. I don't see any on that board.
                  The G4 and G5 would have Nichicon HM and HN series caps.
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16959
                    ....or UCC KZJ....or Rubycon MCZ.... I've recapped hundreds of those boards.
                    Team : 49813
                    Join in!!
                    Team Stats
                    • Compgeke
                      • Feb 2014
                      • 524
                      Yeah, they did last a while. I know the IIfx, IIcx, IIci, Classic II and a few other random models suffer from bad motherboard caps. The LC and LC II suffer from bad power supply caps. Interestingly the SE I picked up tonight works fine sans the Miniscribe hard drive.
                      • BigTroll
                        • Sep 2010
                        • 1317
                        • LAMBDA SOND
                        Yeah I had to heat my psu up with a space heater or the lcii wouldn't boot I found leaking elnas out the bottom and replaced the elnas With nippon kys been fine ever since I also treated it to a tantalum recap
                        My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
                        • BigTroll
                          • Sep 2010
                          • 1317
                          • LAMBDA SOND
                          Oh BTW nice thread, seeing TC work on a vintage mac is heart warming and priceless. does anyone happen to have a good working SE/30 motherboard I have 2 SE/30s and I recaped both boards but SCSI does not work on either board don't know what happened.
                          • Meall
                            • Oct 2015
                            • 4
                            Sorry to resurrect this thread, but I have a Mac II showing similar symptoms. One of the two soldered batteries is showing 3V and the other nothing. When started up, I hear the "dead" sound. What would be the best solution to replace the batteries on the cheap?
                            I looked on eBay but not really sure if it worth what I found. Maybe there's better place to find replacements.
                              • 31278
                              they are ½AA 3v lithiums i think - wire ended.
                              you can get them, but you can also get then without wires and buy a pair of holders.
                              probably cheaper that way.
                              there is no bodge for this, you need those big cells.
                              what's written on the old ones?
                              • goontron
                                5000!
                                • Dec 2011
                                • 4108
                                • US
                                You could run netBSD on it....
                                Follow the white rabbit.
                                • Meall
                                  • Oct 2015
                                  • 4
                                  I wonder if it could be possible to use this socket and CR2032 here? they are dirt cheap, and we can get 2032 cheaply on eBay too.
                                    • 31278
                                    2032 wont last as long though.
                                    if you do want to use 2032's you can salvage the sockets from some old motherboards.
                                    • Meall
                                      • Oct 2015
                                      • 4
                                      Ah, I see. Makes sense.
                                      I have a bunch of 3.6V 1/2 AA batteries, sadly this bad guy it using 3.0V.
                                      Sockets for 1/2 AA are easy to find and cheap on eBay. The batteries is something else... They tend to be expensive...
                                        • 31278
                                        they are sold as camera batteries - so people take the piss with the price.
                                          by momaka
                                          03-12-2025, 03:42 PM
                                        • mitchw
                                          Older Macintosh Magnetek power supply ressurection
                                          by mitchw
                                          Hi, I have an old PowerMac 8100 power supply from a company MagneTek.
                                          I need some advice repairing it. I am not sure if I got the right SMPS controller IC.
                                          When I got it, the primary side was completely blown, both MOSFETs blown, control IC blown its cap off, etc.
                                          I slowly got it to work, first I disconnected all the visually blown and shorted components, until all there was left was a standby power supply. There was a major darkening in the standby area, but it was caused by an overheating resistor (which still tests good - 68 ohms). This was caused...
                                          02-10-2020, 05:20 PM
                                        • flibidy
                                          Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                                          by flibidy
                                          I have here a Magnum IA.100 which belongs to my parents.
                                          The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                                          Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                                          What Ive done........
                                          01-01-2025, 01:26 PM
                                        • TechGeek
                                          Power Macintosh 7200/120 PC Compatible Restoration
                                          by TechGeek
                                          So here we go. The system featured here is a Power Macintosh 7200/120 computer with a PowerPC 601 CPU and 24MB of RAM. It was built sometime in 1996 and appears to have been in use between 1997 and 2007, with most activity ceasing by 2005.
                                          The system was also ordered with the PC Compatible option, which, in this case, is a 12" long PCI card with an entire PC compatible system on it. It has a 100MHz Pentium (i586) CPU, 8MB or 16MB of onboard RAM, an ATi Mach/64 video card, and a Sound Blaster Vibra16 sound subsystem.
                                          It was checked into a computer repair shop (presumably...
                                          03-21-2023, 03:23 PM
                                        • nicktasios
                                          Macintosh Quadra 840AV PSU
                                          by nicktasios
                                          I had my Quadra 840AV (which I recapped and had working) plugged in for some time without using it and randomly decided to turn it on today. Unfortunately it did not turn on. After checking the PSU, I found out I was not getting anything from 12V, only from the 5V rail. After a few minutes, I removed the PSU and plugged it back in the electrical outlet and it suddenly started making a weird sound and soon after smoke started coming out. I quickly unplugged it. I opened it up but on first instance I didn't see anything out of the ordinary really. I later turned it back on and one of the MOVs blew...
                                          12-22-2024, 05:07 AM
