A coworker of mine showed me his brand new ASUS Sabretooth 990FX with a damaged AM3+ socket. He and his friend were building a new system and decided to pull off the stock CPU cooler without twisting it loose. The CPU popped right out of the socket due to the strong grip of the latest AMD thermal compound. They bent a bunch of pins on the FX-8350, and damaged the socket so the cam end is lifted and the lever no longer moves the top of the socket back and forth. That is almost $400 worth of new hardware trashed by a pair of morons in 2 seconds
(I extrapolate that to almost 3/4 million dollars per hour if they had the opportunity).
So I told him I would try to find out about repairing the socket. I'm not sure yet if any socket parts are actually broken or if they are only dislocated. I have a dead motherboard with a good socket that could perhaps be a parts source, but I know I don't have the equipment or experience to remove the bad socket from his board and solder the good socket in place without damaging something. Anybody know of any info on these sockets that might help? Thanks.
