Lighthing hit me!
  • coolcurrent
    • Oct 2010
    • 98
    Lighthing hit me!
    I was using a laptop on a raining day, and it got fired!
    Lightning struck, i got a shock, but temporarily without any fatel incidence.
    Compaq presario CQ61 aka insyde
    but my laptop was affected, it was plugged in when i was using it.
    when i tried to boot some days later, i got an error message
    Code:
    Serial Number: (empty- nothing is shown)
    UUID Number is 00000000-0000-0000-0000-000000000000
    Product Configuration ID: 00000000000000000
    Factory installed OS: non-vista
    presently, the laptop boots up,but stops at the win7 logo with the progressbar. I tried to format, still stops there, i thought of doing a bios update, but need your imputes
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    Re: Lighthing hit me!
    That's not much to go on.
    I'm surprised that it's still working.
    Try a linux distro see if you can boot into ubuntu or linux mint live cd, if you can then try to to install it, if it fails then something is screwy. Also run memtest86+ usually comes on linux live cds as well.
    Another thing you can do is try d-ban and wipe the drive good, then attempt to reinstall windows. Sometime bad MBR, boot sectors, broken partitions and magnetic errors causes the drive to get screwed up so bad that nothing can install or tries to install but fails because of it.
    • dj_ricoh
      • 2073
      i saw a sony vayo 6 years ago and the notebook was doing the same stuck on logo.
      hdd change rams optic, i could not take the bios out at that time to update but if you can it will be a progress to my old mistery sony vaio to see if you can get it unstuck fromt here
      • theokretes
        • Jul 2013
        • 49
        It's very difficult to repair laptop motherboards, especially if they use BGA chips that need replacing.
        BGA... is my least favourite. Partially due to the fact I don't own a BGA reworking station.
        • dj_ricoh
          • 2073
          if you really wanna take out a chip and replace or reball you can make you`re own setup.
          it depends on how much you wanna do that thing.
          home made rework station its now a new thing
          • theokretes
            • Jul 2013
            • 49
            I actually may be interested in that. I have a 3dfx voodoo 4500 which I want to replace the VSA chip with another one as I accidentally broke it while removing the heatsink.
            But that's off topic.
            • Junk Parts
              Court Jester
              • Jun 2006
              • 8953
              I feel your pain. "Thor" has taken at least three desktops at my house. This means he has two of my Dells and a nice home built unit. I wish you luck!
              "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
              Mark Twain
              "I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way."
              John Paul Jones
              There is a fifth dimension, beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call the Twilight Zone.
              Rod Serling
              • c_hegge
                • Sep 2009
                • 5219
                I have a Gigabyte G41 motherboard that was hit by lightning last year. When I got my hands on it, it wouldn't POST. I fixed it by removing the Ethernet controller IC (which was visibly blown out) with my hot air gun. Around here, lightning hits though the power are extremely rare. They almost always come through the phone line, and take out the ADSL modem and Ethernet controller IC
                • ddscentral
                  • Mar 2008
                  • 151
                  • Lithuania, EU
                  I remember trying to fix a Dell PC which was hit by lightning.
                  It would still turn on and display something like "keyboard error press any key".
                  Both USB and PS/2 ports were totally dead.
                  • goontron
                    5000!
                    • Dec 2011
                    • 4108
                    • US
                    with the underground cable and electrical system here that not very common. but the construction crew here are idiots and end up digging into the power lines and cable lines so outages are common.
                    Follow the white rabbit.
                    • RJARRRPCGP
                      • Jul 2004
                      • 6304
                      You need to wipe the HDD then put in the Windows 7 DVD.
                      Laptop HDDs seem to get bitrot often!
                      ASRock B550 PG Velocita
                      Ryzen 9 "Vermeer" 5900X
                      Arc A770 16 GB
                      eVGA Supernova G3 750W
                      Alienware AW3423DWF OLED
                      • 6BW6
                        Win7 Performance test stops
                        by 6BW6
                        I had a dodgy Molex Sata lead go bad that cause crashes once in a while, after repairing all is well with no crashing BUT.... Windows performance test stops. I get-:
                        Problem signature:
                        Problem Event Name: APPCRASH
                        Application Name: WinSAT.exe
                        Application Version: 6.1.7601.17514
                        Application Timestamp: 4ce798fc
                        Fault Module Name: atiuxp64.dll
                        Fault Module Version: 8.14.1.6463
                        Fault Module Timestamp: 56254af6
                        Exception Code: c0000005
                        Exception Offset: 000000000000dc14
                        OS Version: 6.1.7601.2.1.0.256.48...
                        05-29-2023, 04:21 PM
                      • computerbacon79
                        Dell Inspiron 3480 All in One corrupt Bios issue: reaches Dell logo and stops
                        by computerbacon79
                        The Dell Inspiron 3480 I own (the all in one, not the laptop) is not wanting to turn on at all. It goes right to a dell logo, but it stays there forever with no other information on the screen. Holding the automatic Bios repair key combo (ctrl+esc) that should let it read a recovery file off a USB drive gets stuck on a black screen and does nothing. No amount of resetting anything so far has worked, and Dell's own support downloads have not really helped. Ive tried another BIN file I found online using my CH341A, and this got me slightly more, that time it displayed a loading bar that never moved...
                        05-06-2025, 06:43 PM
                      • Caimano
                        Asus P2520L starts and stops ok but no display
                        by Caimano
                        Model Asus P2520L
                        MB P552LA_LJ Rev 2.1 with soldered I3 5010U processor
                        The laptop charges battery and seem to react to power on, power off, reset regularly, but nothing appears on screen or HDMI or VGA monitor.
                        Same behaviour when running on battery only, on mains only or on both.
                        Battery charges fine. RTC battery ok at 3.025V.
                        When powered on the power on led lits, after a short while the HDD led flashes, but no video. All voltages seem present. ALL_SYSTEM_PWRGD is present, BUFF_PLT_RST# goes high. CPU warms up and fan starts and stop from time to time....
                        03-29-2023, 03:05 AM
                      • someonenotyou
                        Lenovo A485/T480 USB stops working when USB2.0 is plugged.
                        by someonenotyou
                        Hi.
                        I have 2 Lenovo laptops (A485 and T480) with identical USB problem.
                        When I plug in a USB 3.x device (USB storage), the USB ports are working normal.
                        But as soon I plug in USB 2.0 device (mouse, USB storage), all the USB ports stop working. Even if I plug in USB 3.x device.
                        The only way to get USB working again is disconnect battery and reset BIOS.
                        Has anyone had anything similar?
                        I have not yet tried another BIOS, but would that be the problem with USB?
                        Thank you.
                        03-19-2025, 12:15 PM
                      • mrkmpn
                        s340-15IWL Laptop stops charging until AC and battery are disconnected
                        by mrkmpn
                        I have a Lenovo IdePad s340-15IWL that will charge fine to 100%, but if you let the battery drain to around 50% (give or take) and plug the AC adapter back in, it will no longer charge and the only way to resolve the issue is to disconnect the AC adapter, disconnect the battery, plug the battery back in, and then the AC adapter, and then it will once again charge the battery back to 100%.
                        If you unplug the AC adapter and let it drain down a little and plug it back in, charging still works fine. I'm not 100% sure where the cutoff is where it stops working, but I think it's down...
                        03-10-2023, 05:42 PM
