Can CPU Sockets be Purchased
  • hairykiore
    • Mar 2012
    • 83
    • New Zealand
    Hi..Can CPU Sockets be Purchased?? I have googled this and cannot find an answer so I am posting this thread ...Does anybody have an answer Please...
    Thanks hk
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Re: Can CPU Sockets be Purchased
    i'm sure technically, yes, but replacing them, i'm sure is somewhat insanely difficult
    • hairykiore
      • Mar 2012
      • 83
      • New Zealand
      Exactly ? I am well aware of that ... so maybe it needs a completely different approach and I am happy to say I have now found where they can be purchased ..thanks
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        If you've had enough BGA rework experience and a proper BGA rework machine, it's no different than replacing other BGA chips.
        • Uranium-235
          Comrade Glimmer
          • Aug 2007
          • 5042
          • US
          but isn't there plastic right under the lga pins?
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            It's heat resistant plastic IIRC. Won't melt at the temperatures used for soldering/reworking, but if you overheat it, then it will melt. Most onboard connectors and slots are like that too.
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              Interesting, I did not notice that. I will try it some day.
              • brethin
                • Dec 2008
                • 1907
                Mind sharing where you found them forsale? I have a board I would like to get a new socket for.
                • LLLlllou
                  • May 2011
                  • 201
                  There are dozens of sellers on ebay selling them.
                  • Mots06
                    Old Dell E5400 Laptop ( Purchased in the year 2008)
                    by Mots06
                    Hi, I'm unable to find the motherboard number (PPID number) or the board view for this old laptop. My laptop won't start, and when I enter the serial number on the Dell website, it says the number is invalid. The sticker on the bottom is unreadable because it has faded over time. Unfortunately, I'm unable to start the laptop to use the power cell or explore other options.I needed the CMOS Cell & it also seems the Laptop will not start now because of the power switch issue, which is yet to be detected.
                    07-19-2025, 01:56 AM
                  • tony359
                    good quality DIP sockets
                    by tony359
                    Hi there,
                    Can anybody recommend a source of good quality DIP sockets please? I'm getting mine from Ebay and they feel very flimsy. If I plug a previously desoldered chip, the sockets get permanently deformed and the pins to solder through the PCB are very, very flimsy...
                    Thanks!
                    Tony
                    11-05-2021, 06:00 AM
                  • dicky96
                    Need to Replace small QFN very close to DIMM sockets - suggestions?
                    by dicky96
                    Hi guys
                    You can see the attached pic - the QFN is faulty and needs changing. It is closer than 1cm to the DIMM sockets and of course I must not damage these
                    So.... best suggestions and techniques please. Desolder and Resolder. I have some thoughts myself but don't want to distort the responses...
                    04-16-2021, 03:02 AM
                    RJ45 Block Diagram / Schematic
                    RJ45 network connectors are most commonly found at either end of an Ethernet (wired internet) connection. At first glance, they appear similar to the familiar telephone plugs and jacks which connect landlines to walls or switchboards. However, RJ45 connectors are typically slightly larger.
                    The term RJ45 connector is widely used today to describe both male RJ45 plugs and female RJ45 sockets. The plugs, sometimes called modular connectors, are usually found on the end of Ethernet cables. The sockets or jacks are generally embedded in the device...
                    10-31-2024, 04:18 AM
                  • dicky96
                    Best solvent for removing thermal paste from LGA sockets?
                    by dicky96
                    So I have TUF Z390 mobo with a bit of the grey thermal paste in the LGA 1151 socket right near one edge. probably from when the clamp was fastened down without a CPU fitted, and there was a bit of paste on the clamp.
                    The motherboard actually works fine (you can see there is no thermal paste on the ends of the pins themselves), but it would be nice to clean it out.
                    I've done a bit of googling and found suggestions from using this stuff....
                    https://www.ebay.co.uk/itm/Arctic-Si...er/27411405412...
                    02-09-2021, 11:46 AM
