good quality DIP sockets
  • tony359
    • Oct 2018
    • 256
    Hi there,
    Can anybody recommend a source of good quality DIP sockets please? I'm getting mine from Ebay and they feel very flimsy. If I plug a previously desoldered chip, the sockets get permanently deformed and the pins to solder through the PCB are very, very flimsy...
    Thanks!
    Tony
    Great Sage ι½Šε€©ε€§θ–
    • 30944
    Re: good quality DIP sockets
    turned pin / machined pin sockets.
    RS or Rapid.
    https://www.rapidonline.com/dil-dual...-sockets-82699
    if your using pulled chips you need to get the pins smooth - i rub them gently across a file
    • tony359
      • Oct 2018
      • 256
      Thanks appreciated.
      I've always felt a bit cautious about turned pin sockets as aren't they designed to accept round pins? I don't doubt they may work but logically a flat pin doesn't work very well in a round hole in my brain πŸ™‚
      What's your thought about that?
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8676
        They work fine, have seen/used tons of them for flat DIP pins and never had any issues with them. Don't try to plug TO-220 pins into them however, won't work.
        Only PGA pins are round anyway, and fortunately they use machined pins for those.
        • tony359
          • Oct 2018
          • 256
          Yes I did a little research and I didn't know those sockets still have a spring mechanism inside so it won't matter whether the IC has round or flat pins.
          I guess I'll start using them. Thanks for the advice.
