RJ45 Block Diagram / Schematic
    RJ45 network connectors are most commonly found at either end of an Ethernet (wired internet) connection. At first glance, they appear similar to the familiar telephone plugs and jacks which connect landlines to walls or switchboards. However, RJ45 connectors are typically slightly larger.
    The term RJ45 connector is widely used today to describe both male RJ45 plugs and female RJ45 sockets. The plugs, sometimes called modular connectors, are usually found on the end of Ethernet cables. The sockets or jacks are generally embedded in the device that is being hooked up or mounted to a fixed wall panel. Definition of an RJ45 Connector
    RJ45 are for telecoms network interfaces. Their job is to link various types of voice and data equipment either to a central hub or directly to each other.
    In modern domestic and commercial environments, RJ45 connectors are primarily used for plugging an internet-enabled device directly into hardware such as a modem, router, or server. The connectors themselves are the modular sets of fittings at either end of the physical data connection (Ethernet cable) joining one networked device to another.
    As previously mentioned, the term RJ45 connector can broadly refer to both male and female versions of these jacks and plugs. In the case of Ethernet networking, the plug fixtures on cable ends are the RJ45 male parts, while the sockets found on the devices themselves are RJ45 female parts.
  • hs5424
    Dynacord powermate 1600 block diagram.
    by hs5424
    Hi All,
    I obtained a schematic diagram for the above mixer but I am wondering if a block diagram exists as I am trying to fix a problem in the protection circuit which I find a little confusing using a circuit diagram only. In the good old days the workshop manuals always had a block diagram with a circuit discription. Very useful for fault finding.
    The protection light is perminently on. The right sode has a -80DC on the feed to the speaker, hence the protection led on. I have removed all the O/P transistors which checked out OK. I tested all other transistors in circuit which seem...
    07-31-2025, 01:35 PM
  • sheffieldyorky
    ZAB/ZAB A,B/ZYJA BLOCK DIAGRAM Acer Aspire
    by sheffieldyorky
    Hey there people
    While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
    This is what I tried, but not in any order.
    Google
    YouTube
    BIOS
    Command Prompt (administrator privileges)
    On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...
    10-25-2025, 02:22 AM
  • arielomc
    Samsung Galaxy Book2 Pro 360 - Block Diagram and Schematics
    by arielomc
    If anyone has these files, please upload and share them.
    I ruined my laptop with coffee and now I need to fix this guy, but I can't find the schematics anywhere.
    I will be really grateful to the person who posts these files.
    In the picture, the "AZTP 439" chip appears to be the problem, but I have no idea what it is. I think it could possibly be a voltage regulator, but it is very small.
    Thanks in advance!
    AMC
    07-21-2024, 02:22 AM
  • magik20
    Wine Enthusiast 170 Bottle N'Finity Wine Cellar Model # 273 02 70
    by magik20
    I'm hoping someone might be able to offer some guidance on repairing a Wine Enthusiast N'finity 170 bottle wine cellar, model 273 02 70.
    I recently acquired this unit for free via Facebook Marketplace, hoping to fix it up as a gift for my wife. I have some basic electronic skills (comfortable with a multimeter, basic soldering, identifying components) but I'm definitely not an advanced technician.
    The main challenge is that when I picked up the unit, the main control/power board had already been removed and the previous owner said it needs a...
    04-30-2025, 04:46 PM
