Best solvent for removing thermal paste from LGA sockets?
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    So I have TUF Z390 mobo with a bit of the grey thermal paste in the LGA 1151 socket right near one edge. probably from when the clamp was fastened down without a CPU fitted, and there was a bit of paste on the clamp.
    The motherboard actually works fine (you can see there is no thermal paste on the ends of the pins themselves), but it would be nice to clean it out.
    I've done a bit of googling and found suggestions from using this stuff....
    https://www.ebay.co.uk/itm/Arctic-Si...EAAOSwAOBd2~4T
    To using Rubbing Alcohol, Isopropyl, and WD40 (followed by Isopropyl)
    I guess electrical contact cleaner/switch cleaner would also be a possibility, though I didn't see that suggested anywhere
    I'm thinking someone else here already does this - so what do you use to flush the paste out? Also do you remove the metal surround from the LGA socket first to make it easier to get to the pins at the edge?
    Follow me on YouTube
    Learn Electronics Repair
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3266
    • Singapore
    Re: Best solvent for removing thermal paste from LGA sockets?
    i just use zippo and ronsonol lighter fluid for cleaning up thermal paste. just drip it on some q-tips for cleaning/reaching hard to reach areas. arcticlean and isopropyl alcohol works too.
    • dicky96
      Sun Seeker
      • Mar 2017
      • 1825
      • Spain
      @chaoslegionnaire
      Damn don't tell me I have to take up smoking first
      • zen
        • 511
        Great tip , regards the lighter fluid . Would have never thought of that.
        Will test out .
        Thanks .
          master hoarder
          • May 2008
          • 12175
          If there's thermal compound inside the socket between the pins, I carefully try to pick it off with a needle and fine tweezers (don't slip! ) After that, just drip some IPA in there if really needed... but I've only had to do this once or twice. And like in your case, the motherboards were working fine. I just have the OCD to get the TC out of there.
          • dicky96
            Sun Seeker
            • Mar 2017
            • 1825
            • Spain
            Yeah it is between/under the pins on one edge and it is gooey grey stuff. The gold tips of the pins are clean and the motherboard works fine. I did try to drag some of it out with a needle but as it is gooey that just stirs it up a bit and does not seem to help.
            • ChaosLegionnaire
              HC Overclocker
              • Jul 2012
              • 3266
              • Singapore
              Originally posted by dicky96
              @chaoslegionnaire
              lol! obviously, dont smoke or use the soldering iron when cleaning with zippo and ronsonol! lol! dont want to bbq the board more than it already is! haha! its also good for pouring on and burning away unwanted documents u dont want others or the gov to find! hehehe!
              • petehall347
                • Jan 2015
                • 4445
                blast it with 150 psi air
                  • Jul 2011
                  • 6070
                  You can also use a small amount of brake cleaner work very well
                  one note spray it into a paper towel first then clean your heat sink ( this work best )
                  I personally have done this many times in the past with out no issues doing it
                  Just make sure that you do not have any plastic parts near the brake cleaner because a lot of plastic do not like brake cleaner the plastic becomes cloudy looking ( sometimes if you spray the brake cleaner into a paper towel first you can get way with using it on plastic parts but not always )
                  I have also used rubbing alcohol for this purpose really do not like doing this unless I do not have brake cleaner
                  I find that you use more rubbing alcohol than you would use brake cleaner is why prefer to use the brake cleaner
                  • Veyron7887
                    Laptop overheating after replacement thermal paste
                    by Veyron7887
                    Hi. I have Asus X55C laptop from year 2013. It has i3-2328M CPU. I replaced stock thermal paste with high quality thermal paste. Before thermal paste replacement, I measured CPU temperature Around 65-70 degrees Celcius with stock thermal paste. If after the replace thermal paste, I measured CPU temperature around 80-84 degrees Celcius and fan don't stop when system is idle. I replaced the thermal paste several times but still did not change. Where is the problem?
                    11-24-2024, 05:08 AM
                  • caspian
                    Can thermal paste cause corrosion?
                    by caspian
                    Dear members,
                    I have got an ordinary gray thermal paste that has no name/model on the box.
                    I put some of this thermal paste on a 128-pin QFP IC. A bit of this thermal paste was put on pins of the IC.
                    I tried to clean the pins by thinner but the thermal paste cannot be cleaned from the pins properly. because the pins are tiny and the thermal paste is stuck between them.
                    Is it possible that the thermal paste damages pins of the IC in long term by creating corrosion or something?
                    Is it safe to leave the thermal paste on the pins?
                    I guess the thermal paste...
                    06-19-2020, 10:47 AM
                  • Fobo
                    What kind of Thermal Paste is this?
                    by Fobo
                    I bought a laptop in parts and was going to assemble it and looked on youtube and saw that it was some type of Thermal Paste on the vrams
                    What kind of Thermal Paste is this on the vrams insted of thermal pads?
                    the picture is taken from youtube movie
                    11-22-2023, 06:20 PM
                  • magneh
                    Liquid Metal Thermal Paste + Alienware = KO
                    by magneh
                    Hey guys !
                    Funny one to share.
                    What would be an IC replacement due to conductive thermal paste, revealed to be something more...
                    Long story short, owner contacted for burned IC due to thermal paste accident, and when I put my eyes on it ... sweet god!
                    Theres this liquid thermal paste everywhere under the chips... GPU, ram ic's...
                    So sad...
                    Someone had some kind of similar case?
                    Can this be blown off with compressed air or something? or only way is lifting the BGA's?
                    I can lift the ram chips and reball, but I dont have BGA...
                    04-29-2020, 01:51 PM
                  • corrize
                    Asus Zenbook DUO UX481F – small water damage and thermal paste
                    by corrize
                    Hello, the laptop has a resistor cdamaged by water and dead (open line) close the charging chip. I will replace it soon.
                    I found a lot of thermal paste on coils and componets close CPU.
                    With meter, I saw 2,6 Ohms between ground and shunt resistor close power jack. So I guess it's too low.
                    I don't find true short (0 Ohms) on the board, no coil shorted.
                    I don't found bad mosfet (shorted drain-source). I found 2,6 Ohms to the « output » of the second mosfet close power jack.
                    I found a coil (close CPU) at 2,6 Ohms.
                    I measured between the output of 2sd mosfet...
                    04-11-2022, 03:02 PM
