this took forever but i have figured out how!
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    i have the old win2k theam in windows xp without access to the CPL at my school
    1: logon
    2:press ALT+SHIFT+PRINTSCREEN
    3: log off
    4:log back on and have the old win2k look!
    Follow the white rabbit.
  • Elysarian
    • Mar 2013
    • 200
    Re: this took forever but i have figured out how!
    ALT+SHIFT+PRINTSCREEN usually switches to and from high contrast mode (to allow visually impaired users to switch to that mode without having to go through display properties which they would struggle with).
    Perhaps the theme has been disabled and when Windows can't find the relevant files it defaults to "windows classic"?
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      maybe.. anyway i always liked the win2k look over xp's so i am very happy with it
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5045
        • US
        I like the XP theme in silver, only use the classic theme on older end computers, cause the themes service has to be enabled and that takes up some memory
        • goontron
          5000!
          • Dec 2011
          • 4108
          • US
          XP theme in silver? sorry longtime linuxer here only seen blue luna. well at least i think thats what it is called?
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            Yeah Luna, you can change it to silver in the display settings. Royale looks cool too...you can download it. But yeah the stock XP looks kinda lame, or maybe just because I've seen it so many times...haha
            • Elysarian
              • Mar 2013
              • 200
              Luna was the primary reason that I never (voluntarily) used XP...
              I had Win2k Advanced server on my desktop, Pro on my laptop until server 2003 & that went on my desktop (laptop was dead by then)...
              Moved to Vista and actually got along fine with that but upgraded through 7 to 8 which is now my primary OS (though the current laptop has 7 on it)
              I dunno, 2k was stable and, with a few tweaks, would run everything that XP did and didn't default to "tellytubby land"
              As an aside, is anyone else as anal as me and noticed the internal version numbers of windows over the years?
              95 = 4.0.xxxx
              98 = 4.10.xxxx
              Me = 4.9.xxxx
              2000 = 5.0.xxxx
              XP = 5.1.xxxx
              XPx64 = 5.2.xxxx
              Vista = 6.xxxx
              Win7 = 6.1.xxxx
              Win8 = 6.2.xxxx
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                95 = 4.0.xxxx
                98 = 4.10.xxxx
                Me = 4.9.xxxx
                2000 = 5.0.xxxx
                XP = 5.1.xxxx
                XPx64 = 5.2.xxxx
                Vista = 6.xxxx
                Win7 = 6.1.xxxx
                Win8 = 6.2.xxxx
                9x +ME don't correlate. 95 is the successor to windows 3.1, hence the 4.0 and so on with 98 and ME
                2000 (NT kernel 5) is the successor to win NT (NT kernel 4.0) which is the sucessor to windows for workgroups 3.1, hence the numbe scheme. Other than both being more or less successors to windows 3.0 (an addon to DOS like 1.1 and 2.0), the numbering working out was pure coincidence.
                sigpic
                (Insert witty quote here)
                • severach
                  • Aug 2007
                  • 1055
                  I got used to Luna so long as all the FX were turned off. Windows 7 has a number of TreeView based windows that won't give up their animation.
                  sig files are for morons
                  • cheapie
                    null
                    • Jul 2010
                    • 849
                    There's also "olive green" which looks like .
                      master hoarder
                      • May 2008
                      • 12175
                      ^ That exactly.
                      One of the first things I do on any XP computer running the Luna theme is to turn off those stupid fade/slide/shadows effects. They take so many resources and only get in the way by having to wait for menus to fade in, fade out, or slide.
                      I wouldn't have minded that Luna theme so much if I haven't seen it so overused. In the last few years, I have set up a countless number of XP computers, and it's at the point where I nearly gag every time I see it now. Could even say I probably have eye burn-in from it .
                      All of my flash drives have a folder in them called "themes" where I have various saved XP and (mostly) classic themes. Just copy to computer I want to change the theme on, double-click, and enjoy.
                      That's one reason why I'm still hesitating to switch to 7 (primary reason, of course, is I don't have any capable hardware for it ).
                      Vista seems to be a little better in that department, at least from my limited experience with it.
                      • Pentium4
                        CapXon Be Gone
                        • Sep 2011
                        • 3741
                        7 is a lot more efficient hardware wise than Vista is. What are you running? Cause I've run Windows 7 on a Northwood P4/Athlon 64 and it's easily fast enough for basic computing as long as you have more than a gig of RAM.
                          master hoarder
                          • May 2008
                          • 12175
                          I got several P4s, all with about 1 GB of RAM. I've optimized 64-bit 7 before to run on as low as 400 MB, so I could actually run 7 on 1 GB of RAM without problems... but I don't really want to . XP feels nice and cozy.
                          • playit
                            broadband ut300r2u modem,link light stays on forever
                            by playit
                            ut300r2u modem,link light stays on forever no matter if if dsl phone wire connected or not.i dint mess with any firmware ,it started to be like this for past few months until it stopped all together to work anymore,so learned that flashing might help, need dump file for this modem, i have only ch34a1 programmer.so i erased and flashed with few bin or ras files i got from internet but nothing worked.so further reading let me know that have to flash a whole full dump .if any idea, pls share, thank you.
                            08-11-2022, 01:44 AM
                          • Dannyx
                            Looking to buy a microscope
                            by Dannyx
                            Good day and a belated happy New Year folks !
                            Wow....feels like forever since I've had a chat with all the wonderful folks we got here - guess you could say I grew up and can look after myself now
                            In all seriousness, I'm in need of some assistance choosing a microscope. I decided it's time I finally got one and I might as well put some of the money I earned caroling this year to good use
                            The reason I'm turning to our community for advice is because I'd like to hear some thoughts from people who actually own a microscope already or at least worked with them hands-on,...
                            01-09-2023, 01:16 PM
                          • Jidis
                            Need T-Con Advice (Vizio P602ui-B3)
                            by Jidis
                            I made a big-ass mess here of my father's beloved P602, and I'm trying to figure out if I should order a batch of overpriced ribbons or if I'd just be throwing more good money at the bad.
                            He woke up recently to a bunch of white bars going down the right side of the screen. From what I'd seen in these places, I figured the T-con board has gone out or has a bad connection. I took the back off and gently poked at the socketed ribbons and sure enough, got the image back. It was mainly the far left ribbon, and it would snap back to stripes if I let off the pressure....
                            09-22-2025, 05:10 PM
                          • roxboy1984
                            Apple cinema display A1316 takes forever to turn on!
                            by roxboy1984
                            Please could someone help or advise. I have an Apple Cinema Display A1316 and it all of a sudden is taking a really long time to come on. I assume it's probably a capacitor related issue on the power board, I'm just wondering if anyone has experienced something similar and if these monitors are easy and or worth trying to get repaired. Thanks in advance for the help.
                            12-12-2022, 01:14 PM
                          • eccerr0r
                            socket 775 forever... no, no, no...
                            by eccerr0r
                            Sigh. Now I'm getting a whole bunch of S775 boards. Luckily I got rid of one...
                            Wondering what people thinks about chipsets for S775 boards and their long term longevity. I had a few boards that failed.
                            MSI Neo3 (865) - gone but it was working (ATX)
                            Asus ??? (915) - crashes randomly (ATX)
                            Foxconn G9657MA (G965, onboard graphics) - dead (µATX)
                            Gigabyte EP43-UD3L (P43) - bad USB ports but otherwise still works (ATX)
                            Gigabyte G41M(???) (G41) - still working (µATX, only 2 DDR2's)
                            Intel DQ45CB (Q45, onboard graphics) - still working (µATX)...
                            02-22-2022, 03:56 AM
