Looking to buy a microscope
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3913
    • Electronics, Cars, PCs, Girls, Anime
    Good day and a belated happy New Year folks !
    Wow....feels like forever since I've had a chat with all the wonderful folks we got here - guess you could say I grew up and can look after myself now
    In all seriousness, I'm in need of some assistance choosing a microscope. I decided it's time I finally got one and I might as well put some of the money I earned caroling this year to good use
    The reason I'm turning to our community for advice is because I'd like to hear some thoughts from people who actually own a microscope already or at least worked with them hands-on, as opposed to relying strictly on specs and numbers the manufacturers list (or sometimes DON'T list !).
    I'm aware most 'scopes (on Aliexpress at least) are pretty much identical. The only thing that's different is the "brand" (if we can even call it that, since it's the same product all around, just under a different name) and the countless combinations of stands, lenses and cameras which you can mix and match to fit your needs (and budget !). I'm not interested in a camera, at least not yet, so I left that out of the equation. Still, I DO know I want a trinocular 'scope, just in case I decide to add one later on.
    The work distance is what I'm particularly interested in (the usable space between the ring light and the workpiece). It appears to be 4" (100mm) for most of them, HOWEVER (and this is what inspired me to start this discussion in the first place), some boast a distance of 8" (200mm) and I even saw a 300mm one, despite the heads not looking any different - maybe the optics inside ARE different ? The thing some sellers don't quite make clear is whether this is measured with or without a Barlow lens in place and the value it's got. Some have a table where they list the various combinations of lenses and oculars for a given zoom level and also work distance. I know a Barlow lens alters the work distance and the maximum/minimum "zoom", as well as the field of view - apparently, the higher the value of the Barlow lens, the higher the MAX zoom, the lower the work distance. Most sets seem to come standard with a 0.5x and 2.0x lens, so what are your thoughts on these ? Favourite combinations for "everyday" work ? Any additional lenses I should invest in at a later date ? The 0.5x one makes most sense, as it bumps the distance up to 165mm according to some sellers. Makes me wonder on what basis the ones with 200+mm work distances are being "judged"...and if it's worth the higher asking prices
    I'd also like some thoughts on the stands: articulated arm vs. boom (single/double pipe) ? Louis Rossmann did several videos on the microscopes he uses and to be honest, I'd go with the boom stand, rather than an articulated one, since it appears to take up less space and is less susceptible to accidental movements.
    "Amscope" seems to be a popular brand, though again, I take the word "brand" with a grain of salt here. I was able to find a set for around 320$, including shipping, without a camera, 2 barlow lenses and a single-bar stand. The stand doesn't inspire particular confidence with this one.
    There's also THIS Amscope one, which is considerably more expensive, but boasts that 8" work distance. After a chat with the seller, they said this is with a Barlow lens fitted, which I figured, but they didn't give any numbers here, so once again, I've drawn a bit of blank figuring out whether the work distance is influenced solely by the lens or the optics in the heads themselves differ internally as well...
    Just for reference, since it's insanely expensive, there's also this big beast, which aside from the very steep price and the fiber-optic illuminator and sturdier arm which I'd love to have, claims an even more impressive distance of 14" (350mm) ! This one COULD be different indeed, because if you look closely at the head, you'll see it differs a bit, but again, there's probably a Barlow lens on there to get that sort of number !
    Wattevah...
    • 32068
    Re: Looking to buy a microscope
    with the intentional destruction of technical manufacturing, i'm surprised you cant find cheap scopes in industrial auctions.
    • megaraider
      • Jul 2015
      • 311
      • Portugal
      Everyday is a learning process
      • jareksniper
        • Jan 2023
        • Poland
        soo true...
        • alfatv
          • Sep 2020
          • 353
          For few hundred bucks Amscope is a way to go.
          I don't know how things are in Europe, but in US you can buy it directly from Amscope, all kinds of configurations and accessories are available,
          I used one with ~7x-42x zoom, but also added 0.5x Barlow lens to get larger field of view.
          Had to buy separate metallic adapter as original plastic was crap.
          Because of increased distance to PCB with 0.5x lens, had to get tall chair.
          Other than that it did what it supposed to go.
            • 32068
            anything from the u.s. to europe is a nightmare.
            first the couriors fuck you over and then you get raped by customs
            • harp
              • Jun 2022
              • 742
              • Planet Earth
              Maybe helps:
              Stereo Microscopes to BUY and to AVOID
              https://engraverscafe.com/threads/st...to-avoid.3451/
              • stormanimal83
                • May 2014
                • 74
                have a look at the hdmi microscope that alex from "nothridgefix.com" uses... he has a repair shop and only sells tools he uses himself.
                check out youtubechannel of northridgefix. if i was in us and not in germany i already would have bought one from him....
                • HellasTechn1
                  • Sep 2015
                  • 176
                  • Greece
                  I have a Euromex stereo blue and i really love it, it is awesome. It gives me a very good sense when moving my hands and tools. Googling revealed that there also is a stereo blue with a built in digital camera.
                  • lcdcaps1
                    INSKAM 10.1-Inch IPS, digital microscope
                    by lcdcaps1
                    Hi
                    All
                    Hope everyone is all well
                    I have an INSKAM 10.1-Inch IPS, digital microscope that I ordered from Temu
                    I can see that this same microscope is being sold on different sites but rebranded but looks identical
                    I have attached some photos of the microscope
                    The issue I have is that it keeps turning itself on its own
                    I have disabled the screensaver in the settings and the auto shut off
                    I have tried different chargers and cables and outlets
                    I left the battery on charge for hours and same thing
                    The light changes from...
                    05-10-2026, 08:08 AM
                  • lcdcaps1
                    INSKAM Microscope USB port issue
                    by lcdcaps1
                    Hi
                    All
                    Does anyone have a INSKAM 7 inch LCD digital microscope
                    I have a weird issue on the one I have where the USB port does not output enough power because when I connect a USB light or the ring light the light output is always really dim
                    The ring light when connected to the microscope USB port is at the lowest brightness and turning the brightness knob makes no difference
                    I have tried different cables and different USB power adapters
                    I have confirmed there is nothing wrong with the ring light and the other USB light by plugging them into another...
                    04-18-2025, 04:16 AM
                  • smort
                    Backlight Polkadarks
                    by smort
                    Soooo, I found someone giving away their 70" Vizio TV because it wouldn't turn on. Hoping it would be just some bad caps, I snapped it up. No dice. No bulging caps. TV would start consuming about 7W immediately after plugging it in, but no response from the remote or power button. Thermal showed the main chip on the mobo getting warm and nothing else. Power supply appeared to deliver stable 12V to the mainboard.
                    I ordered a replacement mobo(actually both mobo and PSU just to be sure) and popped it in. Picture! Sound! Endorphins! Then I noticed three long dark strips. Hmmm, had...
                    03-11-2025, 12:33 AM
                  • chegueva
                    My Andonstar ADSM201 Microscope Review
                    by chegueva
                    Hi everyone. i'v started learning electronics before the corona hit so that's not very long time ago. but anyways i started with only a multi-meter then i started getting into micro-soldering and soldering in general, got myself hot air station a bench Power-supply and last but not least a microscope.
                    About the microscope at first i just wanted to get those 15 usd USB digital microscopes to try but some people talked me outta of it and i decided to go for something better but not professional as i'm just starting out.
                    So i had a choice between a binocular & camera , i wanted...
                    08-14-2020, 11:08 AM
                  • caspian
                    Weak Vision due to Eye Strain when using Microscope
                    by caspian
                    Dear Forum Members,
                    Microscope is required for micro-soldering and for measuring tiny components on a mainboard. I have to use microscope because my eyes are not that strong to see tiny IC pins.
                    My microscope has light to improve vision. I have attached a photo of my microscope.
                    Looking through a microscope gives us eye strain. After using microscope for 5 to 10 minues, my eyes get a bit weak in recognizing close objects. that means close objects look a bit blur. Then, I have to wait for 5 to 10 hours til my eyes get back to normal.
                    1. Do you experience...
                    08-14-2019, 02:28 AM
