Hello to all, first post and nc8230 hell
  • Dreamer
    • Nov 2006
    Hi everybody.
    I am having some weird problems with my friend's hp/compaq nc8230. To cut a very long story short, the laptop won't boot 9 out of 10 times. It does not even reach post- just blank screen, but power led is on and fan spins.
    now, a firm twisting of the laptop will increase the boot sucesses to about 6-7 out of 10. Once booted laptop works normally.
    my friend has had the laptop for about 1 year w/o problems. MB has been replaced by vendor. Problems started about 1 month ago with original MB and the new MB has worked for 3 weeks before doing exactly the same symptoms.
    i have tried the following:
    with battery, with adapter, battery only, adapter only, swap memory modules, only one module, no modules. all cards removed: modem, wireless, btooth, cdrom drive, hdd, lcd ( use external vga output) .
    i have tried all the parts in another laptop and everything works. i have replaced memory, processor, wireless , bluetooth ,modem and adapter with known good parts and it does not solve the problem.
    there is no external visible signs of damage on the motherboard at all.
    I have even tried the MB out of the laptop case, no luck!!
    Can anybody help me or point me in the right direction?
    thanks in advance,
    D
  • Dreamer
    • Nov 2006
    Re: Hello to all, first post and nc8230 hell
    Hey guys, anybody thinks this could be due to bad caps on MB?
    Please help me out
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16958
      Sounds like a cold solder joint or a bad connector somewhere. The 'twisting' part was a dead ringer for that.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • gonzo0815
        • Feb 2006
        • 1600
        may be a bad solder joint or kontackt in the bios flash chip area. This is probably the only part, wich is only for boot up necesarry.
        • arneson
          • Sep 2005
          • 1267
          The fact that this happened to two boards makes me think it could be a design problem.
          I did a search on one laptop and discovered that the model was prone to the same problem and hundreds of others, twist and shutdown.
          I not only found the problem but the fix as well.
          It was a Dell. A cover piece was making contact with a chip.
          Jim
          • Dreamer
            • Nov 2006
            Thanks for your input guys, i will look for cold solder joints around BIOS chip and try to remedy these to the best of my ability. Will keep you guys posted.
            Do you think I can rule out bad caps? ( since the laptop works fine if i managed to get it started )
            regards to all,
            D
            • VILE DISRUPTION
              • Jun 2006
              • 47
              well i dont think bad caps would be the problem. Arneson has a point. get the covers off and try some attempts at raising the bottom down from the motherboard. maybe some aluminum can help with that. if the motherboard is mounted on the case, trim down some normal motherboard risers to size and then the trick is getting the same size.
              Stats Reset Every Month.
              My Forums
              • kuzeydogun
                • Dec 2008
                hi badcaps people
                this is an old post but i exactly have the same problem with the same notebook. I tried to send private message and emailed to the topic starter(dreamer), but could not get in contact with, so i am writing here...
                Does any of you know what this guy did with his nc8230...
                I cannot come with any solutions to this wierd problem and have no idea what to do with it...tried everything
                • crocodile2009
                  • Sep 2009
                  • 5
                  Got a laptop with exact same problem however I have the solution on how to fix it!
                  http://h10025.www1.hp.com/ewfrf/wc/d...77&lc=en&cc=us
                  HP/Compaq have made a ton of dodgy laptops(yes designed poorly!) all with 3rd party graphic chipsets, so if your laptop has a Nvidia or ATi graphics chipset you will be prone to the same problem.
                  The problem is not with the graphic chipsets themselves, but the cooling. HP has these chipsets connected to the heatsink, but inbetween the chipsets and heatsink they always put a "heat transfer pad" which depending on the model is from 1mm to 5mm thick, and quite frankly they are cr4p at transferring heat.
                  So after a while your HP/Compaq Laptop graphics chipset gets very very hot, very quickly, unable to dissapate the heat due to the flawed heating pad design.
                  With all these new graphics chipsets they do not use pins, but rather hundreds of solder contacts on the base of the chipset that simply "sticks" to the motherboard via solder points. As the chipset heats up, the lead solder underneith begins to oxidize/melt and contact is lost between the motherboard. This is the same issue that Xbox 360's have with their red ring of death problem.
                  The solution? You need to pull the offending laptop apart, remove the motherboard and use a special hot air soldering gun(don't use a normal heat gun you can't control the heat) and reheat the graphics chipset for 3 minutes at the 300C tip setting. My friend who does this for me has fixed 2 out of 2 "turns on, black screen" HP Laptops so far and it's fixed both first go.
                  Seems HP has some explaining to do on this issue.
                  • jean luc ferre
                    laptop hp g72 b52sf screen problems
                    by jean luc ferre
                    on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                    the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                    i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                    i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                    06-07-2025, 03:27 PM
                  • Hondaman
                    USB problems?
                    by Hondaman
                    Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
                    (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
                    I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
                    08-12-2024, 03:26 PM
                  • ongobongo
                    Ram Modules with undderfill - tricks for desoldering
                    by ongobongo
                    I'm working on another Lenovo E14 gen 2 AMD here which has a ton of errors with the factory soldered DDR4 ram chips. I do have a donor board here from which I'd like to use the modules and swap them. Unfortunately, the modules are glued down with underfill, which i have never worked with before.
                    I tried with a lot of heat on the donor board but the modules won't come loose.
                    Are there any hint or tricks when it comes to dealing with underfilled chips/ic that could help here
                    Ongo
                    06-02-2024, 02:18 AM
                  • gabrielA7
                    Zotac GTX 1080 8GB / No video / Error reported on all memory modules!
                    by gabrielA7
                    Hi guys!!
                    I have this video card on my bench, it turns on and the screen goes black!
                    I used MATS but it showed an error in all memory modules, when writing!
                    I once got a 1060 with the same symptom, all modules were defective, I rebaled the GPU and it stayed the same.
                    Remember that I have all the debts ok, 1.35 Vram and such!
                    Could the problem really be in the GPU?
                    Could it be the BIOS?
                    Thank you in advance!​
                    06-05-2025, 09:04 AM
                  • clabr
                    Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
                    by clabr
                    Need help to solve some problems with this laptop.
                    After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
                    After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
                    Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
                    Before this had happened I observed some other problems:
                    When I tried replacing original mecanical HDD with a SSD HDD could not get them...
                    12-02-2021, 08:09 AM
