CPU 1156 Socket expertise required...
  • hairykiore
    • Mar 2012
    • 83
    • New Zealand
    Hi...I have attached photos of a Gigabyte GA H55M-S2H M/B 1156 socket..If there is somebody with socket expertise I would be grateful if they could study the photos and give an opinion....
    Without going into meaningless history ...to my eye the upper segment pins "especially" ones down the right had side have twisted slightly in alignment when compered to the lower segment....
    Now I can actually see two pins that could be touching and I have yet to address this...
    My main concern is this....are the upper pins twisted (although only marginally) out of alignment to a degree that the contact points would have trouble contacting "their" contact pad on the i7 CPU.....I do have a photo of a perfect socket that I could post ?? https://www.badcaps.net/forum/images...s/icon_mad.gif
    Thanks hk
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    Re: CPU 1156 Socket expertise required...
    I don't see a problem here, but then again I'm not looking at the pins closely unless there is a problem.
    Perhaps you can post comparison photo since I don't have any 1156 on hand to look at.
    • spleenharvester
      • Mar 2010
      • 913
      Same, I can't see a problem here. Is the board in question functioning?
      Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
      • 370forlife
        Large Marge
        • Aug 2008
        • 3112
        I see no problems either. The ones on the right look like they are maybe off by a few thousands of a inch compared to the rest, but that effect could be had if you are not looking perfectly, directly down on the socket.
        • hairykiore
          • Mar 2012
          • 83
          • New Zealand
          Three replies ..this is great.....DSCN0836 is what I thought was the reason for the PC not posting IE the fan would go for up to 30 seconds,cut out and immediately power up again and keep repeating this sequence ..Then I found what I believe was a socket short...one can see the crossed over pin ..this was fixed..but the MB when re-installed did exactly the same...
          DSCN0851 is a 1156 socket from another Gigabyte MB which works.....
          Now just in case anybody thinks the picture was taken at an angle ..I covered this by using a poor mans peep hole to take the photo through. see DSCN0855 (.I used 2 tins of baked beans to get the camera in focus and my arms steady ???
          I am still convinced its a socket problem ...
          I did circle 2 pins in an earlier black and white enlarged photo ..I thought that its highly likely these pins touch especially with the CPU which compresses them down slightly when latched....Maybe its worth a try to move one slightly and put the board back in the unit and try again...
          Hk
          • trebo
            • 514
            • Wales, UK
            maybe the CPU got damaged when you had the short in the socket, when those pins touched.
            worth trying another CPU
            • hairykiore
              • Mar 2012
              • 83
              • New Zealand
              Hi..Yes I thought I had explained everything has been checked with alternative working components eg the MB when bought had an i7 in it..it has since been checked with an i3 that I know goes....I did try the original i7 in another Gigabyte MB and it failed BUT hopefully this was because I never knew at the time this can happen with no graphics card slotted....
              My main concern at the moment is the MB ..I have blown those pins up even more in an image viewer and I still think the two pins I circled in my original post could be touching .....Now its easy to separate them? but I thought it best to get some expertise comment on the pins which are clearly out of alignment in the upper segment especially down the right side...
              It seems by the comments this is not an issue and everybody thinks the contact points will touch the CPU pads properly....
              I have read of a MB being revived after 5 trys of checking/rechecking socket pins ??
              I will move that one pin I have concern about a degree away from its next door neighbour and put everything back in the case and power it up...basicly thats all I can do....I have tryed to send the socket photograph to Gigabyte for comment but it failed to attach???
              Of course if I was an expert ..there is probably a test one can do on the board itself to find any short...and the problem could be something else on the M/B ...its just that the way the fan starts up and fails apparantly is typical of a socket pin short... thanks hk
              • hairykiore
                • Mar 2012
                • 83
                • New Zealand
                Hi..Moved pin and Just did a simple bench test ...MB/cpu with PSU and started with touching the F socket Power pins with a screwdriver.... I actually thought it was gong to keep going..but after 35-40 seconds it rebooted ....The length between reboots is a worry ..I thought a short was a lot quicker between boots ....any comment is welcome ?? It may not be the socket..Hk
                • hairykiore
                  • Mar 2012
                  • 83
                  • New Zealand
                  Code:
                  I finally got ASUS tech support on the phone Monday; he had me strip everything off the motherboard except the power supply connected at the 24 pin and 8pin CPU mounts. Fortunately, the Rampage II extreme has a start button on board! Started up, and power supply fan cut off in 40-60 seconds indicating the usual failure. ASUS TS said it sounded like a ground fault, and could either be the motherboard or power supply. Long story short... Picked up new power supply from nearest town (1.5 hours each way), bench tested, success!
                  Hi I found this in another forum post via Google ..Similar problem so just in case I tryed another PSU ...Same result ...A ground fault ?? is this a short?? thanks Hk
                  PS I wonder if bench testing as I am doing with PSU and MB....if the audio speaker was plugged into the F Socket would it beep ?? So much to learn?
                  • Uranium-235
                    Comrade Glimmer
                    • Aug 2007
                    • 5042
                    • US
                    the VERY bent pin is 10:AR - Memory lane shorting to 10:AP ECC Memory lane (unsued for your CPU) - I'm not sure this would damage the CPU, or ram
                    however the ones that are circled that don't look bent are in the power section of the grid, they're actually VCC and ground. I'm not sure this is enough to kill your CPU VRM, but perhaps the chip's power regulation of the die itself. The i7 may really be dead, you should check that out
                    here is a clarksdale (xeon) lga 1156 pinout. It is essentially the same but there are some unused contacts like ECC and the like for all non-xeon sandy bridges
                    https://cdn.badcaps-static.com/pdfs/...7c44743e4e.pdf
                    • hairykiore
                      • Mar 2012
                      • 83
                      • New Zealand
                      Thanks for your reply...Of course at this stage its the MB I am trying to get going and I am using a perfectly good and tested i3 CPU.....and the MB will not go with it... Now I have taken photographs and enlarged them etc and MY concern is still what I see as the pin alignment on the right side of the socket ...the pins have been twisted anti clockwise ..Yes only by a small degree but when I look at a photo of the contact pads on a CPU ...there is no room for misalignment ....Hk
                      • Uranium-235
                        Comrade Glimmer
                        • Aug 2007
                        • 5042
                        • US
                        this is why I hate LGA. One of the many reasons anyways. That metal used in those pins is VERY stiff. I don't think I had one single fixed LGA socket in my life
                          master hoarder
                          • May 2008
                          • 12175
                          • Bulgaria
                          Not sure if this will work, but if you have nothing else to try...
                          Try coating the CPU pads with a very thin layer of flour (put the CPU with the pads facing up, then put some flour on your hands and clap them close to the CPU. This will create a cloud of flour. Let it settle and repeat again several more times to get a thin even layer.)
                          Then carefully put the CPU in the socket (try not to move it once in the socket) and close the latch.
                          Open the latch and again carefully remove the CPU from the socket. Look at the CPU pad side and see what scratch "pattern" the pins from the socket made. If any of them go outside the pads - particularly those from the "misaligned pins", then you may have a pin alignment problem.
                          Other than that, the CPU socket looks fine to me as well.
                          • seanc
                            • Nov 2008
                            • 1319
                            Check the mosfets for dark/discoloured ones, shorted or blown ones to the left of the CPU socket.
                            I've had multiple failures of the S2V boards.
                            • Isabella91
                              Possible to convert eMMC Socket to a micro SD Card socket?
                              by Isabella91
                              I have seen many posts where the eMMC can be read via a SD card reader, however can the opposite be achieved?
                              Read/Write a Micro SD Card from an eMMC Socket.
                              I have a Motherboard with a Kingston BGA153 ball socket, using HS400 bus mode, which is 8bit, as Micro SD is usually 1bit or 4bit mode, I accept that a loss of speed in read/write will occur, but I would sill like to convert.
                              Theoretically speaking, Im thinking if I hard solder DAT0-3 from eMMC to SD Card Reader, this should force 4-bit mode, or only DAT0 to force 1-bit mode.
                              Not to remove...
                              01-14-2024, 05:10 PM
                            • warsztat
                              Acer AN515-57-577G JDIMM1 socket not working.
                              by warsztat
                              Hello, Acer AN515-57-577G JDIMM1 socket does not work. GH51G LA-L181P, 2x DDR4 RAM, both good, both work well in JDIMM2, neither works in JDIMM1. The laptop displays BIOS, when the JDIMM2 socket is occupied, you can run Linux on USB, then everything seems to work ok, there is internet access and you can browse the contents of the 512 GB SSD in Windows, but starting Windows ends with an eternal spinning circle, maybe there are corrupted files. When the RAM is inserted into the JDIMM1 socket, the laptop starts but there is no image and the downloaded current does not change and the output is ~2.25A....
                              11-18-2024, 09:13 AM
                            • Geomih
                              CPU socket replacement soldering profile
                              by Geomih
                              Hi All - I am hoping someone can help with some pointers (complete noob here!)
                              I have recently purchased a Scotle HR460 BGA reball machine (it's a bit old and I think the company no longer exists either), but as far as I can tell it is a competent and unmolested machine that should be good enough for my needs.
                              My biggest problem is that it came with no profiles, and I must re-create all of them from scratch, something that is very scary for someone that doesn't really know what they are doing.
                              The simple stuff like a small memory module isn't a big deal because there are
                              12-11-2023, 11:07 AM
                            • Biessea
                              ASUS Sabertooth 990FX REV.2 bios chip problems, probably socket shorted?
                              by Biessea
                              Hi there,
                              I'm a technician and a computer/retro computer lover.
                              I just bought a great Sabertooth motherboard (I really love the colours and the ASUS military scheme) to install a nice FX-8320 from AMD and make a gaming computer with a Geforce GTX 970.
                              For the first time I had problems with the system, but I solved and then correctly booting, I installed Windows 10 and then I started to overclock the system. I reached a stable configuration of 4,8GHZ with 1,475v.
                              Then I saved fan configuration, and other parameters, and saved to the overclock profile...
                              03-01-2022, 03:57 AM
                            • thebeige
                              i need photos Hp X360 1030 G2- OLDMAN-6050A2848001 LVDS SOCKET
                              by thebeige
                              Hi.I need the socket pictures of this motherboard;(OLDMAN-6050A2848001). The device is in liquid contact and the socket is burnt. ...
                              02-26-2025, 05:45 AM
